Oracle's Avatar
Question How to remove a flathead screw
Hi,
I'll repaint the bumper of my beater truck but I'm stuck with those flathead screws.
If I try to undo the nut the screw turns..
How would you remove them? I don't mind destroying them cause I can replace with regular nut/bolt.
I have a die grinder @24K RPM is that enough or do I need to buy a dremmel... and what kind of attachment do I need? Or does anyone have any other ideas?
Thank
Jasper
We're all in the gutter,but some of us are looking at the stars.
-Oscar Wilde
Old 01-04-2007, 10:02 PM
Banned
m21sniper's Avatar
Air hammer/chisel baby.
Old 01-04-2007, 10:43 PM
JW Apostate
trekkor's Avatar
Weld a nut on the flat side so you hold a wrench on both sides.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 01-04-2007, 10:52 PM
JW Apostate
trekkor's Avatar
You can prolly use a grinder with a cut-off wheel on the domed surface of the bolt. Then punch it through.
KT
'01 Boxster
Old 01-04-2007, 10:55 PM
Registered abUser
TerryH's Avatar
Those have a square shoulder that are supposed to keep it from spinning, but it appears rust probably allows it to turn now.
Grind the center of the head down to about 10%, then take a punch and big ******* hammer (BFH) and drive it downward. The rest of the head should bust off.
'81 911SC Coupe SOLD
Old 01-05-2007, 03:54 AM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Drill it...engage an easy out bit...hold the nut...and unscrew it.
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 01-05-2007, 04:56 AM
canna change law physics
red-beard's Avatar
Grind a slot in it for a flat head screwdriver. If that doesn't work, grind off the rest of the head.
James
Red-beard for President, 2020
Old 01-05-2007, 05:00 AM
The Unsettler
stomachmonkey's Avatar
leave it, paint over it, spend energy saved on a beer.
"I want my two dollars"
"Brandon Won"
Old 01-05-2007, 05:36 AM
Yup, this is what I've done many times before. Cut off disc....big slot and big screwdriver.
Warren & Ron, may you rest in Peace.
Old 01-05-2007, 07:04 AM
Senior Member
You need a dremel anyway. Get the ball bearing version. Mine has lasted me since 1975 and still going strong.
Old 01-05-2007, 07:10 AM
Oracle's Avatar
Thank you all for your ideas.... I have to say I used them all from the air hammer/chisel to the grinder using the BFH and punch.
Finally the bumper is free and already painted... I don't have time to sand it and prep it I just cleaned all the loose paint and rust and painted over..
And I had to straighten the bumper... that was the main reason for the disassembly..
Thanks!!!
-J
-Oscar Wilde
Old 01-05-2007, 08:42 PM
