canna change law physics
red-beard's Avatar
Originally posted by Joeaksa
FB,
You should get a plan worked out and the materials together. Then supply all the beer and invite a load of Pelicans over for the weekend. Bet that there are a few guys in the area who would donate a day or so to help a Pelican who is about ready to retire and needs some help.
How about it guys?
Joe
Might not get anything done, but it would be fun...
James
Red-beard for President, 2020
Old 04-24-2007, 03:21 PM
Senior Member
We just did it here in Phoenix a month ago. Whole group of us got together and pulled a Pelican's engine and tranny, then proceeded to take the engine apart to see what went wrong inside.
Had a good time, and helped a friend in the process. Same thing could work here...
2013 Jag XF, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB
Old 04-24-2007, 03:25 PM
Flatbutt1's Avatar
Well I haven't been able to get a contractor to come out and look at the job. Guess its the busy season.
So if any of you guys are GCs and are interested in some work just PM me. Or maybe you know a GC you'd be comfortable recommending?
thanks gang
big blue tricycle
stare down the darkness and watch it fade
Old 05-11-2007, 11:50 AM
Senior Member
Superman's Avatar
I'd get under there with some screw jacks and some hydraulic jacks and big pieces of wood (and perhaps some beer and cigarettes) and jack it up. Dig. Place wet concrete or dry blocks. Voila!
Mocha 1978 911SC. "Coco"
Old 05-11-2007, 01:59 PM
Flatbutt1's Avatar
I wish I could Supe but it is beyond my physical capabilities.
big blue tricycle
Old 05-11-2007, 03:49 PM
Hey ya'll watch this
Hoots's Avatar
That's why he is SUPERMAN!!!
Hoots
Midvale School for the Gifted
Class of 1990.
Old 05-11-2007, 04:08 PM
Free minder
Aurel's Avatar
I`d like to be Superman too. He has a simple solution for every problem. Did not he fix broken studs on his SC, by just opening his engine, replacing the studs, button it back up and voila ! But since I am not Superman, what I would do with the house is take a reverse mortgage...
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 05-11-2007, 04:25 PM
You do not have permissi
john70t's Avatar
This probably won't help, but on one of the "fix-it" type shows (Holmes on Holmes?) there was a Canadian guy demonstrating a new sectional/segmented foundation repair tecnique on an older house that couldn't be lifted. Can't remember the name, sorry.
Old 05-11-2007, 05:57 PM
Information Junky
island911's Avatar
Wood structures are surprisingly flexible. (easily jacked) Superman and Steve both are on target. Furthermore "doing it right" is NOT a 200 year design solution. (tho' a 200 sol'n is likely what a contractor and/or code may push for.) Just tell the contractor that you're looking for a 40 year solution.
Old 05-11-2007, 10:57 PM
alf alf is offline
alf's Avatar
If I had taken advantage of it all when I WAS still chair bound all this would have been done.But the same pride and determination that got me out of the chair prevented me from accepting the program aid.
Kudos to you.
88 Carrera Coupe
Pelican Since 2002
All Zing, No Bling. ok, maybe a little bling.
The Roach
Old 05-11-2007, 11:38 PM
so if we figure this will take two weekends, 1 for demo and footings and 1 for construction, when are we doing this?
permits can be pulled by the homeowner in NJ if this is your primary residence.
Chris
the more i learn, the less i know
Old 05-12-2007, 04:44 AM
Flatbutt1's Avatar
Sure I can pull the permits but I need a digger , a rigger and a mason, not to mention someone to engineer the job.
big blue tricycle
Old 05-12-2007, 05:06 PM
with all these pelicans in the tri state area, i'm sure qualified people will chime in.
NWNJ, like the water gap?
Chris
Old 05-12-2007, 05:17 PM
Flatbutt1's Avatar
further East, Lake Hopatcong
big blue tricycle
Old 05-12-2007, 05:26 PM
