Custom User Title
Scientist burns salt water
http://www.foxnews.com/story/0,2933,296395,00.html
VERY cool stuff. I love hearing about discoveries like this! One of these days, energy is going to become VERY cheap, and the world will be revolutionized. This will happen because of SCIENCE, not legislation. |
Information Junky
WOW cold fussion is real!
no, really, pulling apart H2O into H's and O's (and letting them come back together to burn) is nothing new. In fact, I think there is a law about how that works.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Custom User Title
True, but isn't this the first time its been done through this method?
BTW- thanks for using my green for sarcasm trick- it makes me happy that I have had some type of impact on the world
Is this another cold fusion type thing ???
Marv Evans '69 911E |
He is also looking for government funding for his "research" -- he might just get it from the Bush administration! He's not likely to be getting funding from the private sector since it sounds like he is a crack-pot. ________________________________ Pennsylvania Man Claims to Burn Salt Water Tuesday , September 11, 2007 ERIE, Pa. — An Erie, Pa., cancer researcher says he has found a way to burn salt water, a novel invention that is being touted by a retired chemistry professor as the "most remarkable" water science discovery in a century. John Kanzius says he happened upon the discovery accidentally when he tried to desalinate seawater with a radio-frequency generator he says he developed to treat cancer. He discovered that as long as the salt water was exposed to the radio frequencies, it would burn. The discovery has scientists excited by the prospect of using salt water, the most abundant resource on earth, as a fuel. Rustum Roy, a Penn State University emeritus professor of chemistry, has held demonstrations at his State College, Pa., lab to confirm his own observations. [Roy is also a specialist in "whole person healing" and Christian sexuality.] The radio frequencies act to weaken the bonds between the elements that make up salt water, releasing the hydrogen, Roy said. Once ignited, the hydrogen will burn as long as it is exposed to the frequencies, he said. The discovery is "the most remarkable in water science in 100 years," Roy said. "This is the most abundant element in the world. It is everywhere," Roy said. "Seeing it burn gives me the chills." Roy will meet this week with officials from the Department of Energy and the Department of Defense to try to obtain research funding. Roy says the scientists want to find out whether the energy output from the burning hydrogen — which reached a heat of more than 3,000 degrees Fahrenheit — would be enough to power a car or other heavy machinery. "We will get our ideas together and check this out and see where it leads," Roy said. "The potential is huge." [Internet commentary upon Kanzius and Roy's assertion points out that creating fire from salt water is possible by first separating it into hydrogen, oxygen, sodium and chloride, then burning the sodium. However, such a process would consume much more energy than it produces.] |
Information Junky
The method used isn't so important unless it uses less energy. But those Laws of Physics say that you need a very specific amount of energy to pluck those molecules apart.
it's no water memory...
http://www.carnuts.us/viewtopic.php?t=1120
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Denny Klein, from Hydrogen Technologies
http://www.ksbitv.com/hotlinks/2856476.html Quote:
Custom User Title
I love this board sometimes! Interesting observations
It more than likely involves young boys.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Unregistered
It's hard to type while holding my breath and turning blue.
I like experimentation through science but unfortunately many of us know that while it may be possible in a laboratory, it won't work in real life. It just takes more energy to break the covalent bonds that you get back from the recombining. Even when using a radio-frequency generator. If I'm wrong I'll be the first to admit it but until then, color me skeptical. Professor Roy's career is fraught with controversy. some might say he has vision, others say he's a fringe crackpot. I'd tend to not put much stock into his credibility. He may be right or he may be fishing for a huge grant. BTW I have seen a fusion reactor up close. About 20 years ago at lawrence Livermore laboratories they had one. I asked about it and was told that it was purely a mock up and would not work based on physics. I asked why they went through the trouble to build one if they knew it couldn't work. "Because the government wanted us to do it and they paid us to do it". |
Unregistered
Besides, even if these things actually worked it would all be a waste of time.
The big oil companies would just buy the patents and file them away right next to the 200 mpg carburetor
For those who don't follow the subject, the real "200 mpg carburetors" are "fuel boilers" -- gasoline is boiled and mixed with air before being introduced into the cylinder. The method's goal is to not "burn" the fuel, but to run an extremely lean mixture and "detonate" the fuel, using the mechanical energy of the detonation (not the "heat expansion" of the burning gasses) to drive the piston in the cylinder. Of course, if you understand that description, then you know it is more than just the "carburetor" that makes the extreme fuel mileage possible -- it is overall motor design and operation at carefully controlled engine speeds (you have to keep the piston moving in unison with the shock-wave of the detonating fuel/air mixture). |
Un Chien Andalusia
I got shown this at work a week or two ago. My first question was "How much energy does the high frequency radio wave generator use?"
No doubt it's cool, but like the others have said above put me in the 'sceptic' catagory for now please.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
It follows the law of diminished or diminishing returns. Requires more energy to extract that it creates. Energy yield is in the negative side. Not good enough yet...Maybe someday?
1 bad 930 |
I just filled my gas tank with salt water. It didn't run to good afterwards.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Registered Usurper
[QUOTE=competentone;3473025] (What the he!! is "christian sexuality"?
No moral sex before marriage?
'82 SC RoW coupe |
Link to old thread:
New fuel source??? Video "Howard Agency" posted on John Kansas an inventor using R.F. to light water on fire............................... http://www.wewin.com/turns-Salt-Water-into-Auto-Fuel.aspx
