Physics question. Complicated. Centrifugal force.
Ok, here's a complicated physics question ya.
If I am in space, and I have a one pound weight, and I tie the weight to a rope that is three feet long and swing or rotate the weight, how fast must the weight rotate at the end of the rope in order to produce a one pound pull on the rope?
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Band.
It will be very hard to rotate because there's an elephant in the way.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
I believe you're looking for F=mass x w (angular speed in rads/sec)^2 x radius
couple that with F = mass x acc (centripetal) and you get acc (centr) (looking for 32f/s^2 here = w^2 x r so square root of 32/3 or 3.266 rads / sec which is about 1/2 rev per sec. I think that's correct, but not positive. Will have to check tomorrow after some sleep.
Tree-Hugging Member
Dredging into the archaeological recesses of memory.....
As I recall, it will depend on your mass. In space you will operate as a system rotating around your mutual center of mass; therefore, the "orbital" radius of the 1lbm object will be larger as your mass is larger. Iow, if your mass is also 1lbm, the radius of the orbit is 1.5ft. If your mass is infinite, the radius is 3ft. The force on the rope is: F = ( m * v^2) / r Combine with masraum's eq'ns. Not enough information to solve, though with a bit of time you could probably have a result that is expressed as a function of M2. It has been a long time since I last did that stuff. Jim .
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ Last edited by Jim727; 12-18-2007 at 08:51 AM.. Reason: Edited equation due to stupidity while tired |
![]() Of course, if you're in space (and I'm assuming by "space" you mean away from the influence of any gravitational fields) then your "one pound weight" doesn't weigh one pound. Weight is a function of mass acted upon by gravity. No gravity = no weight. I worked on the Spacelab program for about a decade and we used to do "microgravity" experiments in the shuttle on orbit. The interesting thing is that gravity on the shuttle in orbit is about the same as it is for people standing on the Earth's surface. The shuttle merely simulates zero-g by inducing a state of constant freefall when in orbit. It's not exactly zero-g, so they called it "micro" g. Sort of like the world's longest vomit comet ride. Probably common knowledge, but I always thought that was interesting.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
so if the shuttle stopped moving at it's orbit distance gravity would be same as on earth?
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
I don't think the gravitational attraction of the two bodies will have an appreciable effect on this situation. (assuming we are someplace with no gravity from a nearby planet or celestial body). And, yes, the 1 lb weight won't weigh anything, but it will still have the same mass in "slugs" (English unit of mass).
Either way, we are looking for the component of the angular acceleration perpendicular to the tanget to the circle that's described by the rotating mass to be 32ft/sec^2. I could definitely be wrong, it's been a long time, but I think you guys are making this much harder than it should be.
If the shuttle stopped moving, it would drop like a rock. In fact, that's how they change the orbit - speed up and they climb to higher orbit, slow down and they fall to a lower orbit. To de-orbit they slow down a bunch.
I think I was correct last night. Another way to do the problem that I think comes out with basically the same answer.
![]() again, set that equal to F=ma which if we are interested in weight would be weight equals mass times acceleration due to gravity 1lb = mass x 32ft/sec^2 so mass x 32 = mass x velocity ^2 / radius because the mass is the same you can cancel the masses from both sides. You end up with v^2 / 3 =32 v^2 = 96 v = √96 = 9.8 fps the circumference of the circle is 2πr which is 6π or about 18.85 feet so again, we are at just a tad more than half a rev per second to match accel due to gravity. If I'm wrong, please, someone let me know. Really. It's been a long time. I'm reasonable certain that my thinking is correct, but I may be wrong.
Tree-Hugging Member
Note to Self: "Self, don't do equations when tired" Sorry. Updated the equation.
~~~~~ Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners. ~~~~~ |
