uick question re: Remington 700 rifles
Anybody know how interchangeable bolts are on Rem 700 in different calibers? E.g., will bolt out of a .22-250 work in a .270?
Dtr's boyfriend got a new rifle and apparently the firing pin broke...won't fire. Can hear the trigger release but pin doesn't hit the primer of the cartridge. |
I'd never risk it, alot of back pressure in that chamber.. Shouldn't be too hard to fix..
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
Well a bolt out of an earlier 700 .270 should work, right?
Not fond of your daughter's boyfriend?
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Is there somebody that HAS to be shot tonight ??
When isn't there??
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos |
OK...I think I answered my own question...on the Remington website the part # for a 22-250 bolt and a 270 bolt are different....
Now on a mass produced rifle, I assume the bolts of a same caliber, same model are interchangeable... Last edited by Dueller; 12-24-2007 at 09:55 PM.. |
Remington will repair it for free quite quickly. The law was that you are allowed to ship directly to them (the manufacturer) and they can ship directly to you, if you are the owner. You can check that on their web site.
Who Dares, Wins! |
Registered Abuser
I think they may have different bolt faces. Different head space for sure, the firing pins maybe swappable. Use caution!
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
Around here we call things like that 'brother-in-law' guns.
'Daughter's boyfriend guns' convey the same but is harder to say. Jim
down to jap bikes that run and a dead Norton |
22-250 is the short action and 270 is the long action. Not interchangeable.
1986 911 Coupe - Now 3.6! 1985 911 Coupe - The start of the addiction - Sold |
firing pin on any rem long action or short action no matter the caliber is about " a NO BRAINER" as it comes to replace. can you put a car antenna back on? thats how simple it is.
tool of choice........... a nickel. use nickel to pry holding piece up and entire firing pin and spring will come out. wipe it down, lightly lube it. and replace. more than likely this occurred due to dry firing and not using a snap cap. dont dry fire weapons. hot ticket..........titanium firing pin! full race mofo with quicker lock times. LOL! |
Senior Member
Never mix parts in the receiver on any gun unless you are a gunsmith. Asking for a problem...
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Change the bolt and you'll possibly change headspace, which is what keeps all that pressure in. However, you should be able to swap firing pins, maybe need to stay in the same cartridge class (med lenght like 308/243/22-250 vs. long 270, 30-06, etc)...
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
A Man of Wealth and Taste
Now this is truly a Darwin moment. Lets see if he survives it?
Copyright "Some Observer" |
Dueller,
The bolt faces are the same as the .270 and 22/250 share the same case head. They are on different length actions so no interchange is possible. That goes for long vs. short firing pins as well. You can send it back to Remington directly (cheapest) or send it/take it to a competent gunsmith who can swap out the firing pin quickly (if that is the problem). Do not attempt to swap bolts, firing pins, or any of the sub-assemblies. Is the ammunition factory new from one of the major manufacurers? S/F, FOG |
I went to my gun case and realized I too had a 700 bdl in .270. We compared bolts and they were identical. Swapped and fired one round. Shipped his bolt to Remington for repair. He hunted with another gun.
Thanks all for your input. |
