Banned
I get this from a woman that flies A320's for United Airlines...
The world's airlines are in a BIG QUANDRY right now. The 777 is in the process of losing it's ETOPS certification. That means that it CANNOT fly the typical routes over the Atlantic or the Pacific that it has been flying. The long and short: The 777 autothrottle system DID NOT respond when the pilots applied full thrust. The autopilot system tried to increase thrust, and the thrust levers moved forward, but [B]nothing happened![B] It appears that this is the [B]first instance of the failure of the fly-by wire system.[B] The Airbus 320 pioneered the system where the flight controls were controlled not by wires and hydraulic motors, such as the power steering on our Porsches, but by actual electric servos, kind of like a model airplane. And one of the first A320's flew into trees at an airshow in Basle, Switzerland in 1988 as a result of that stupid system. All modern Airbuses are operated by "fly by wire" Including the new A380, which can carry 500+passengers. Stretched versions, if built, will cary 800 people. So we are all familiar with the debate about large airplanes with fly by wire. So what? they will save a lot of money.... But what happens when an airplane carrying 800 people crashes? We just watched a fly-by-wire attempt to kill a bunch of persons....! N! Last edited by Normy; 01-21-2008 at 05:45 PM.. |
Anyone on the list know how the flight controls work in a 777?
Rick 88 Cab |
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Sure thought I did... JR |
Sultan of Sawzall
So, just for fun, what happens next month when someone is supposed to fly UAL from ORD to LHR on a 777? (besides the obvious requisite prayer)?
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
So did I; so what? "...a woman that flies A320's for UAL..." knows exactly what happened on a BA 777 before the investigation has even really begun?? Uh huh...
It'll be legen-waitforit
The new Microsoft Sync in the cockpit must have blue screened taking down all the other windows systems
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Grip It & Rip It
Is everything computer controlled? or is there a direct electrical link to the servos that control the engines electrically and bypass the computers in an emergency?
82 911SC (sold) |
EEC- Electronic Engine Control, it is mounted on the engine and its the brain of the engine. Each engine has one. It is a computer that is used to do all the functions for the engine. it receives data from all the engine components and uses the data to make the engine operate at its optimum settings. It has two channels A and B. Every time the start switch is actuated the EEC channel changes. Only one channel is in control at a time. The EEC is always ready to take over in case of failure with the other channel. The other channel is monitoring the active channel to make sure they are both receiving the same data. The EEC operates on the ARINC 429 avionics data bus. The EEC is powered by the aircraft once the start switch is actuated or the EEC maintenance switch is on. Once the engine reaches a certain N1 or EPR setting then the EEC alternator powers the EEC. Meaning the engine itself is self powered by the alternator that is spinning. FADEC-Full Authority Digital Engine Control, This is what is called when an engine is Fly By Wire. That is, no mechanical controls. The EEC controls all engine operations. The goal of FADEC is to operate the engine at its highest efficiency in all flight aspects. AIMS- Aircraft Information Management System- On the 777 this is the brain of the aircraft. All data is brought in and through the AIMS system. There are two AIMS cabinets left and right. They are essentially the EEC of the 777 aircraft. The AIMS system makes the 777 what it is. It eliminates many avionics black boxes because the AIMS does those functions. As an example the Autothrottle computer which is found on most airliners is eliminated on the 777. The function of A/T is a function of AIMS. Other functions include, Primary Flight Displays, Flight Data Recorder System, Aicraft Conditioning System and other functions. The AIMS system receives and transmits data on four 629 buses. I could go on and on with AIMS. It is very complex and I just gave a quick description of it. EIDU- Engine Data Interface Unit- On the 777 there are two. One each for each engine. This box is what lets the AIMS system interface with the EEC. The EECs are on the 429 bus while the AIMS is on the 629 bus. In order for the system to communicate with each other the EDIU takes care of it. It converts the data coming from the EEC to a 629 signal for AIMS to use and vice versa convert 629 to a 429 signal for the EEC to use. This is the sole way for the flight deck to make the engine do what you want it to do. You bump the throttle up and the signal is sent to the AIMS which in turn sends it to the EDIU and then to the EEC which tells the engine to add some gas. The feedback is then sent back the same way it came. The EDIUs are three channel A, B, and C.
Thank you for your time, |
Snip #2:
From the engines' point of view, there is only one command...the thrust lever position. The autothrottle moves the thrust levers via servo, the flight crew does it via their arm, but the same chain happens. Thrust lever moves and updates resolver position, which commands AIMS, which commands EDIU, which commands EEC, which commands fuel/stator/etc.
Did you get the memo?
Goran, correct me if I'm wrong, but don't some FADEC engines still have a physical connection to the throttle? The autothrottles are still manipulated via servo, but there is an actual connection between the engine and throttle controls that is manipulated by FADEC?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Cue: Most BA 777's are equipped with GE engines, I read somewhere that this was the only one with Rollers. All this is of course pure speculation from my side.
Thank you for your time, Last edited by beepbeep; 01-22-2008 at 05:44 AM.. |
mechanic by night
I think it is important to note that the three major engine manufacturers (GE,Pratt,Rolls) have all had fly-by-wire engine controls for many years before the 777. As far as I can recall, and I work on these things, this has not happened before so this could be particularly problematic. However the 777's systems are very different from previous Boeing aircraft and this could be the issue. How different are the engine controls? I suspect similiar design convention but the 777 is a good bit different. They flew a good distance (I don't recall where this airplane departed from) the engines and autothrottle worked perfectly and they only have a problem on final. Odd. Maybe there were some problems with the engine/autothrottle system but I have not heard of any at this point. It will be interesting.
Senior Member
Lets settle down with the ideas about how this happened and why until the investigation is completed. Joe A (Ex-Factory pilot for Boeing, McDonnell Douglas and Bombardier for many years.)
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Why is the 777 losing it's ETOPS certification? Because of this?
Is she hot?
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Because some woman that flies A320's for UAL told him it is.
I believe crash happened beacuse somebody pulled the runway under the aircraft just as they were about to land...
least common denominator
My sister's best friend's aunt saw on the Internet that UFOs were spotted at the airport just before the accident.
Just sayin.
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
