Montana 911
Big Mistake - Laundry and iPod Touch don't mix
Made a bad mistake and when I started laundry of my work uniforms I failed to clear out all the pockets.* Inside my lower leg pant pockets was my iPod Touch that went through the entire wash cycle.In an effort to possibly save it, I placed it in a bin with rice to soak up the moisture...it will sit in there until next week.* I will let you know how this turns out.
EDIT: The iPod was on in sleep mode...so the odds are against me that it can be saved. Check back on 28 May as that is when I will give it a try and see if it works.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R Last edited by k9handler; 05-22-2008 at 02:59 PM.. |
Detached Member
I've heard of that, it's uncooked rice BTW, let us know how that works out for you.
Hugh |
Detached Member
Hugh |
Montana 911
yep uncooked.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
iRice?
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Gon fix it with me hammer
write off
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Monkey with a mouse
It will be after it's soaked up all the moisture from the iPod.
Dept store Quartermaster
iLump
FWIW, you can get desiccant crystals that suck moisture like Paris Hilton on a..... Well they do a much better job than rice anyway ![]()
Cornpoppin' Pony Soldier |
Monkey with a mouse
BTW, after the wash cycle I might have been tempted to dip/soak or thoroughly run rubbing alcohol through the iPod, then do the dry rice.
edit: Use the 99% alcohol solution. You want that sucker to dry with as few contaminants as possible. Since it has a solid state drive, I think there is a very good chance it will work after it dries thoroughly - the alcohol dip will displace water and the iPod should dry much faster. Of course, you don't want to start it up with any moisture inside. FWIW. Last edited by kstar; 05-22-2008 at 12:42 PM.. |
Monkey with a mouse
You should pop it open and remove the battery too.
http://www.appleinsider.com/articles/07/09/15/ipod_touch_tear_down_with_high_quality_internal_ph otos.html |
Monkey with a mouse
Many many stories of cell phones working after drops in toilets and wash cycles. I dropped my iPod in the surf, went home and rinsed it in alcohol and it still works. The surf swim was about three years ago.
No crack pipe needed. ![]() |
Monkey with a mouse
"maybe no" ???
Monkey with a mouse
BTW, if the Pod was powered on during its bath, it's probably dead. If not, I give it an excellent chance at recovery.
The Unsettler
Don't give up hope.
Wife was at our house construction site and dropped her month old Blackberry 8130. It was a couple of hours before she realized it was missing and found it. It was typical TX biblical rain and the BB had been lying in a puddle of mud for at least an hour. It was still on when she found it. Told her to turn it off and leave it. It was so mud encrusted she could not get the battery cover off. So later that night I took the entire thing apart, water and mud all the way to the core. Left everything to dry then took a soft bristle toothbrush and meticulously cleaned it. Works just fine.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Dog-faced pony soldier
Is it at least clean and fluffy now?
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
I'd try the freezer - it dehydrates.
David 1972 911T/S MFI Survivor |
Yes, but water expands when it freezes so any trapped water will break stuff.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Montana 911
well I am expecting the worst and will be happy if it works...if not I will then just replace it with a better (memory wise) one. Sucks that I may have done this and yeah they aren't cheap but it is just a material thing that can be replaced.
Thread Tools | |
Rate This Thread | |
