Did I just break my toe?
Hit it on a small Al step ladder. Hurts a lot.
Tru6 Restoration & Design |
Registered abUser
Break or dislocate or making a right turn?
Pull on it. Hard.
Time to call the Toe Truck? Just "body splint" it to the next toe, I think that's all you can do.
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
just tape it to the the next toe and tough it out until it heals. not much else you can do.
Most likely, tape it to the next toe that's about all you can do for it.
Tim Lynn 84 911 Carrera PCA E Stock #278 |
So how many times did you say the "F' word when it happened?
Man they look bad - did you hit all of them?
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
only once and then went on my way for the last 20 minutes, then it started to hurt. same as when I cut my face with a chain saw. the initial act didn't do much, but it hurt a wee bit more after a spell.
like Moses said, if you have the courage,
or contact Mule..he will gladly help. Like Craig said...tape it , wear comfy shoes for a few weeks. Rika |
In the "old" days a broken or dislocated toe was "set" by pulling on it and realigning it. Then you tape your little toe to it's neighbor.
I did this once. Hurt like hell, but healed fine. My OFFICIAL response is; Go see a doctor and let them figure it out.
Did you get the memo?
Doctor will pull on it, splint it, tape it to the next one and charge you $1000. DIY, send $500 to Moses and you'll still be ahead.
![]() Moses, my cut is $250.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Thanks Moses! and thank you all for the great advice. need to get back to work.
Step 1: Tie some cord around your desk leg, then around the toe. Must be tight! Don't pull, just kick back. 3 times and it was straight and felt great (comparatively) ![]() Step 2: wrap with some 1/2 inch Al bar stock.
Tru6 Restoration & Design Last edited by Shaun 84 Targa; 08-20-2008 at 08:30 AM.. |
Nice work!
Control Group
what he said, then tape 4th and 5th toes together
never mind put ice on it 20 minutes out of every hour I have those exact same running shoes
She was the kindest person I ever met Last edited by Tobra; 08-20-2008 at 08:30 AM.. Reason: too quick for me |
They are great shoes, aren't they!
Shaun ,if you place the splint on the bottom (sole) you will be able to get some shoes on.
oh..it's going to change color...purple,blue with a tint of yellow is common. Rika |
Friend of Warren
[QUOTE=Shaun 84 Targa;4130129]
Step 1: Tie some cord around your desk leg, then around the toe. Must be tight! Don't pull, just kick back. 3 times and it was straight and felt great (comparatively) [QUOTE] Shaun you are ******* nuts!
Kurt V No more Porsches, but a revolving number of motorcycles. |
[QUOTE=Kurt V;4130176][QUOTE=Shaun 84 Targa;4130129] Step 1: Tie some cord around your desk leg, then around the toe. Must be tight! Don't pull, just kick back. 3 times and it was straight and felt great (comparatively) Quote:
