You do not have permissi
john70t's Avatar
Why?
Non-political, please.
1. Why don't cars have oil and transmission fluid level gauges?
2. Why don't modern commercial airplanes have fuel flow gauges?
Old 08-24-2008, 01:33 PM
canna change law physics
red-beard's Avatar
And why no pre-lube pump?
James
Red-beard for President, 2020
Old 08-24-2008, 01:57 PM
MAGA
Tim Hancock's Avatar
Oil level does not matter too much until it gets WAY low and starts sucking air at the pickup tube which will trigger a low oil pressure check engine light, so in a way, most cars already have a warning system.
Don't know about all commercial aircraft, but in smaller aircraft most pilots lean the mixture based on EGT temps and or by watching the rpm start to fall off, then pushing mixture back in slightly. All aircraft have fuel gages and most pilots are capable of managing their fuel.
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne
0% Liberal
Men do not quit playing because they get old.... They get old because they quit playing.
Old 08-24-2008, 01:58 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
A lot of commercial passenger aircraft do in fact have fuel flow gauges. At least the Be99's I used to fly did and those were converted passenger liners.
Black Cars Matter
Old 08-24-2008, 02:00 PM
MAGA
Quite a smaller aircraft have them too, I guess I just don't see the importance what with all the other factors involved choosing power settings along with published fuel burn rates in the manuals.
0% Liberal
Old 08-24-2008, 02:13 PM
1. Why do people buy cars and never read the owner's manual?
2. Why, even when there are warning lights, do people drive around with cars when
the dash looks like a christmas tree light display?
3. Why do people buy cars with no service history, records, books, second key,
radio code, the locking wheel nut socket or all of those?
4. Why is it raining in Seattle in August?
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 08-24-2008, 02:16 PM
Danny_Ocean's Avatar
Barak Obama hates unecessary guages...
(sorry...had to do it)...
Old 08-24-2008, 02:17 PM
john70t's Avatar
3. Why are roof racks rounded? For warped sheets of drywall?
4. Why can't fuel/ignition go through an oil pressure switch? (referencing red-beard)
5. Why do windshield wipers park below the defrost outlet?
(Wayne, good to know some things are changing)
Old 08-24-2008, 02:34 PM
Bill is Dead.
cashflyer's Avatar
My 911 has an oil level gauge.
I'm with Bill
Jims5543's Avatar
My RX7 has a low oil level sensor that will alert me if I am a quart low. It will go off when I am Autocrossing and getting all the oil to one side of the pan its a light and a very loud buzzer.
It also has a coolant level sensor that triggers a light and the same loud buzzer if my coolant is more than 1/2" from the top of the radiator.
This car was built in 1987.
My sons E30 has the same deal for the oil, it will tell you if your a quart low. I am not sure about the coolant and suspect it does not because right after he bought it and we got it home we pulled the radiator and in only had a liter of water in it.
As far as a gauge goes I think that would be overkill and sensor that indicates your at your low limit seems to work just fine.
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 08-24-2008, 02:40 PM
old man neri's Avatar
So if your oil pressure drops then your ignition cuts out? Is this what you are suggesting? I don't think that would be a good idea. Having your power cut when you are in the fast lane of your free way would be a major safetly thing, also your power assist on your brakes would be gone. I wouldn't want that to happen to me out of the blue.
As for modern aircraft, they have all sorts of computers and software managing the fuel. If you look at the major incidents behind aircraft running out of fuel there were reasons. 1) Gimli glider: They knew their fuel monitoring computer was not working but took off, someone made a mistake converting imperial to metric. Not enough fuel on board. 2) Avianco flight: They knew exactly how much fuel they had and they knew they were in trouble. Decided not to declare a fuel emergency. 3) Air transat: Fuel leak, didn't follow procedures exactly either. By the time they realized what had happened it was too late.
As for transmission fluid. Well transmissions don't 'burn' oil/fluid like a car does. Automatic transmissions have a dipstick just like for the oil and a leak in a manual gear box is a very rare thing so the manufacturers probably don't want to spend the money. Think about it; if you, as an engineer, find away to save $10 off the manufacturing of each transmission you have probably earned your salary for the next decade.
-matt
Old 08-24-2008, 04:13 PM
Barack Obama only wants us to have tire pressure gauges.
Oh wait. That was political, wasn't it?
Black Cars Matter
Old 08-24-2008, 04:41 PM
Bill is Dead.
cashflyer's Avatar
I used to own an Oldsmobile Cutlass Calais that had an ignition cutoff for low oil pressure.
Old 08-24-2008, 04:56 PM
Tree-Hugging Member
Jim727's Avatar
Transport category aircraft have fuel flow gauges.
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 08-24-2008, 04:58 PM
abit off center
cgarr's Avatar
Why do people launder washcloths?
______________________
Craig
G2Performance
Old 08-24-2008, 05:30 PM
meister member
speedracing944's Avatar
Why do people use washcloths when they harness 10X the bacteria of what it is washing?
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-24-2008, 06:06 PM
Zeke's Avatar
Someone had to ask. I don't know about you, but mine gets soap build up that only detergent removes.
Trans gauges? Well, automatics have to be checked warm and running like the oil on a 911. Not many understand that anymore, I suppose. But the trick would be to have the whole series of sensors that would tell the gauge when it can read and report. Too much trouble and expense as Wayne suggests.
Manuals? Well, when was the last time you checked the diff on your RWD? They just don't require that much attention and neither do manual trannies.
Old 08-24-2008, 06:09 PM
Virginia Rocks!
VaSteve's Avatar
My BMW has a low windshield fluid light. My Porsches don't. Funny thing is in all 3 cars, it works the same when low...just stops spraying.
I do a terrible job of checking things on the daily driver. The Porsches I'm either flogging or scared they are going to break down on me so I look a little more often.
I have an old BMW motorcycle....many of the guys in the club have much newer ones with all kinds of warning lights and stuff. When something breaks on mine, it just stops running. That's how I know it needs attention...every component is important.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 08-24-2008, 06:49 PM
Non Compos Mentis
My airplane has a fuel totalizer that tells me:
-Fuel used
-Fuel remaining
-Endurance at current fuel flow
-Current consumption
-Fuel needed to destination
-Fuel remaining at destination
-Yada yada.....
Plus the back-up analog gallons-per-hour guage, and the separate gas guages for each of the tanks.
If I EVER run my airplane out of gas, I have no business ever flying it again.
My airplane has no tranny fluid level guage at all. I guess that's because it has no transmission.
Old 08-24-2008, 06:56 PM
My 81 Rx-7 has these features also. Of course it does pump oil into the carburetor and by design uses a quart every thousand miles.
Overheat will instantly kill them also.
Rick
88 Cab
Old 08-24-2008, 07:01 PM
