9dreizig's Avatar
Send a message via AIM to 9dreizig
98 Tahoe wiring help
My power door locks don't work ( any of them) I've checked all the fuses, it looks like there's a relay in the circuit somewhere but I can't seem to find it.. Any suggestions ? I've checked all of the fuse/ relay boxes that I can find,,
Todd
"Todd"
98 Tahoe ,2007 Saturn Vue
86 930 black and stock, 80 930 blue tracdog
91 Spec Miata (yeah I race a chick car)
"life"ll kill ya" Warren Zevon
Old 11-07-2008, 04:10 PM
Retired Member
Brian 162's Avatar
It's possible there could be a broken wire in the harness in the rubber boot where it passes through the door to the switch.
80 911 SC sold
17 Tahoe
07 Z06 Corvette
Old 11-07-2008, 06:40 PM
Shaun @ Tru6's Avatar
http://www.tahoeforum.com/showthread.php?p=4671
Tru6 Restoration & Design
Old 11-07-2008, 06:55 PM
lm6y's Avatar
Todd, there is a door lock relay under the center of the dash. It has six wires, ORANGE, TAN, WHITE, LT BLUE, GREY, and BLACK.
Orange: is constant hot.
Tan: goes to terminal "A" on all of the lock actuators.
White: goes to the unlock terminals on each door switch, and also to terminal "D"
on the door lock control module (Front of Left Rear Wheelhouse).
Lt Blue: goes to the lock terminal on the door switches, and terminal "C" on the lock module.
Grey: Goes to the "B" terminal on the lock actuators.
Black: is ground.
The orange wire runs to a constant hot, 30A fuse, PWR ACCY / CB , in the instrument panel fuse block (left hand side of the dash).
I can try to send you a schematic if you want, it might be too small to use though.
Old 11-07-2008, 07:23 PM
9dreizig's Avatar
Thanks Shaun,, I was on GMtruck.com but it sucked... Damn you can really appreciate this forum with the amount of inactivity on the others..
"Todd"
Old 11-07-2008, 07:33 PM
9dreizig's Avatar
LM6,, I have the schematic thanks,, and just found the relay with the info Shaun gave me. I'll figure it out tomorrow in the light..
"Todd"
Old 11-07-2008, 07:34 PM
Todd, you back here for Thanksgiving?
Old 11-07-2008, 07:36 PM
9dreizig's Avatar
I am, should be getting into Manch the Friday before and hanging out till Tue after.. let's get together!
"Todd"
Old 11-07-2008, 07:49 PM
Irrationally exuberant
ChrisBennet's Avatar
Saturday is Thanksgiving with Chris&Janus. C'mon down!
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 11-08-2008, 08:41 AM
9dreizig's Avatar
-Chris
Sat before or Sat after TG ? Either way I'm in!!!! Hey any luck getting the VW running ??
T
"Todd"
Old 11-08-2008, 08:45 AM
Cool, see you then! I'm not going to MN this year.
Old 11-08-2008, 10:12 AM
9dreizig's Avatar
Ok guys, I picked up a new door lock relay and no luck.. Here's a wiring diagram.. I have 12 volts on the orange to the relay ( it's a 4 door so look at the relay on the right).. When I short the orange to the tan or light blue it does activate the door locks).. I don't get a full short on the black to ground conductivity check. So now where do I look for a broken wire?? I'm thinking maybe the black wire?? Suggestions ?
"Todd"
Old 11-09-2008, 10:58 AM
Hey Todd,
Do you have 12V on the other orange (to the door lock switches)No power there would cause a no go condition. Using a meter, are you grounding on the chassis, or grounding on the black wire on the relay? By trying both ways, you can tell if your black is broken.
Orange --> meter --> chassis = 12V
Orange --> meter --> black wire = ??
On the output of the switches (coming into the relay) do you see 12V???
Old 11-13-2008, 10:55 AM
9dreizig's Avatar
Charles, yes 12 on the orange, I'll make some measurments tomorrow and comment.., thank Nicole for letting you look at this for me
"Todd"
Old 11-13-2008, 08:31 PM
