Oil filter of choice
No seriously!
Got bored this weekend and decided to compare a Fram to the Bosch I usually use on VW diesels http://www.jakesgarage.ca/2008/12/oil-filters-more-than-you-ever-wanted.html Pretty surprising what a difference there was!
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Wonder how the Mahle compares?
Gator 99 996 c4 |
I prefer Wix...
I turn away with fear and horror from this lamentable sore of continuous functions without derivatives. --Charles Hermite Fakelife.com Nothing to do with archery anymore. Porsche/BMW/Ferrari/Honda videos |
Put it this way. Wix or fram will void the warranty on a cummins diesel motor. We use Fleetguard on the trucks and then factory spec brands on everthing else. Mahle on the Porsche. Mann on the VW and Toyota brand on the corolla.
Registered Abuser
Very Close to the Bosch in construction. I carved one up last fall looking for metal. Glad I did not find any. I was impressed. Opened a Mahle fuel filter this spring found some grit but not much, it's good stuff. I don't think I would use anything else.
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
Now in 993 land ...
Mahle OEM for the 993. Motorcraft for the Ford trucks in the family, including the Powerstroke Diesel.
George |
I like Wix, surprised that they void warranty on a Cummins.
drew1 wife has 924 turbo |
Did you get the memo?
Further reason why I don't use Fram. For me, it's always OEM or equivalent like Bosch.
‘07 Mazda RX8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
One thing I like about my MB is the cartridge-style filter. I get to see the actual filter instead of spinning on a "mystery can". I use Mann on the MB, but for the VWs I've always used Bosch because they are known as a good filter and Canadian Tire stocks them.
FWIW, the Fram was $6.11, the Bosch was $5.89. Maybe orange paint is more expensive than black. Of all the differences between the two, the low quality of the Fram's paper was the most shocking to me. It felt was really brittle and worn... like cardboard that had been wet. It's hard to imagine it staying intact in use. It was tearing apart just from stretching it out for the pictures.
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats Last edited by notfarnow; 12-09-2008 at 05:36 AM.. |
Agreed Jake, I like the MB cartridge. My BMWs always had it too. Easy to see if there's anything nasty circulating in your oil.
I think VW uses that type now too, don't they? The other advantage of that setup is quick oil & filter changes. I have a vacuum pump & tank, and just run a thin line down the dipstick tube and suck it all out while I swap the filter. I can do the whole thing in my nice clothes in under 5 minutes.
Cars & Coffee Killer
Fram!?
![]() When I bought my new truck, I had to go to three auto parts stores before I found one that didn't stock exclusively Fram.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
canna change law physics
Shouldn't this be in the PARF section, right next to the Swepco threads?
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
![]() Never tried the pump method, but I know it's quick and easy. The only plus to laying on your back under your car is that you have time to take a look around. Leaks, missing fasteners, worn suspension bushings, they're all easy to see during an oil change.
Oh well I am forever underneath the car anyway, pulling out bent and broken parts, chunks of curb, road signs, baby carriages, cyclists, small shrubs...
Slumlord
bobistheoilguy used to have a good comparison posted. Now it appears to be gone. and the website looks a bit 'professional', so my guess is bob sold out.
Anyway, here is a bit of info: http://www.calsci.com/motorcycleinfo/Filters.html#OilFilters and here: http://minimopar.knizefamily.net/oilfilters/reference.html
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
Friend of Warren
Jake, I wish I had half your energy, seriously. I just looked at your garage blog. Some good, entertaining stuff and you have a radio show!
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks Kurt! The car blog kinda just made sense, because I read and write a fair bit on these forums, so I figured I might as well try sticking it all together somewhere. Some of the stuff I have there is stuff I post on this, or other, car forums. I'm playing around with the format & navigation a bit, so it's a bit rough still.
The radio column came about when I got a scare at work a while ago, and decided to put some "feelers" out for stuff I really enjoy. One of them was at the CBC. They loved the idea of a weekly car column, and gave me a prime spot... 4:50 on Fridays and I can basically talk about ANYTHING I want. I used to do some freelance commentary writing, where I 'd just go in solo and record a 3-4 minute bit. Doing interview-style is an adjustment, because they will try to stretch it out or condense it to fit it in at the end of the hour. Takes some getting used to and a couple of them have been a bit rough, but it's still a ton of fun. I don't know that I'm great at it, but I am starting to get comfortable with the format and it gives me some neat opportunities. I get to test-drive the new MB s-class next week!
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats Last edited by notfarnow; 12-09-2008 at 07:39 AM.. |
