Band.
If it's the optical sensor, can you just tape the reflector to the face of the eye and call it a day?
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 12-28-2008, 08:55 AM
ruf-porsche's Avatar
I see a backdate thread for garage openers coming on this forum.
Old 12-28-2008, 09:16 AM
K9Torro's Avatar
Guys depending on the type of sensor you have, Chamberlain door brackets are really well made and just clip on to your track or can be nailed to the door frame, here is a link.
Todd
http://www.liftmaster.com/consumerweb/pdfdocs/114A3398.pdf
Page 35 and part number 13 comes in set of two.
Old 12-28-2008, 11:32 AM
Did you get the memo?
onewhippedpuppy's Avatar
Mount them facing each other about 1" apart. They're a worthless feature anyway, all modern doors have an auto-reverse feature.
‘07 Mazda RX8-8
Old 12-28-2008, 11:34 AM
carreradpt's Avatar
I just installed them in the attic out of the way. I have a key pad outside that I use alot when working in the garage or outside it. The sensors were just a hassle when trying to close the door and then walk thru it.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 12-28-2008, 04:11 PM
3.2 CAB's Avatar
Some auto-reversing doors can still press with enough to possibly do damage to fragile things, like the neck of a toddler??
I have the liftmaster doors like the ones in the link, with the same type sensors. I have never had any type of problem with them. I have banged things into them, more times than I can remember, but they have always functioned correctly. I have hit them with hand truck wheels, riding mowers, etc. no problems. I guess I happened to get one of the better designed type sensors and mounts. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-28-2008, 05:09 PM
