Computer monitor went black. Fixable?
So last night I was in the middle of typing a reply on Pelican when the monitor went black and I cannot get it to turn back on. It's like there is absolutely no power coming in. I ran to Crapmart and bought a new one but I wouldn't mind keeping the old one for a spare or for the kids to use.
It's just a flat screen Dell but is there a way to fix these without costing a ton? Thanks,
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
unindicted co-conspirator
I had the same thing happen to me.
mine was a Dell also, it's most likely done. it's cheaper to replace it than to fix it.
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
Dog-faced pony soldier
Throwaway society.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
So I suppose I won't hurt it any further by taking it apart.
Slackerous Maximus
If you happen to own a firearm, I have a fun activity in mind that will certainly 'take it apart'.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Check your connections?
I had one do that, took the case off and the power connection inside had pulled apart. (Be VERY careful inside there, touch nothing else - there is huge voltage in there). Fixed. |
True - if you feel the need to tinker (not recommended - waste of time IMHO), discharge the caps first.
I recently found out that there is one extended warranty that comes in handy....Dell's.
I planned on not having it plugged in while tinkering. Am I missing something?
Information Junky
I had the same happen back in the 90's . . .it was a fuse on the PCB (labeled "F1") I replaced it with a car-radio/ inline type of fuse holder. kind of getto, (fuse hanging out the back) but is still going strong today.
btw, big caps in an LCD ?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2˘ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Yes, certain electrical components keep their charge even when unplugged and can seriously hurt you. I don't know what they are or what they look like but I do know they are out there and to be careful.
Had this happen once, it was a bad capacitor.
If you do crack it open and if there is a bad capacitor you will need a soldering iron to remove the old one and install the new one. You should be able to tell by looking at the top of them, they should be flat, typically when a cap is about to go bad or has gone bad they will be "bulging" or "raised". ![]() If you find a bad cap it will have the capacity and voltage rating written on it (1000uf 16V ) stores like radio shack will carry a replacement for around a $1. Other than the power supply I don't believe there are any big caps(voltage wise) on the board. Discharging a cap just means releasing the stored up voltage in it, the smaller voltage ones can be discharged with a small screwdriver (touching the two leads) The larger ones I try to stay away from but there are proper ways to discharge them.Go for it, hell it's not working any who, just be careful!
Rob 87 944 * 89 951 "When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car." |
Too late, I already opened her up. I found a fuse that was burnt as well as some other small bits that look like they got hot. It's in the junk now.
My son grabbed some of the bits and pieces so that he can put them on his robot.
There is an inverter that powers both laptop screens and flat panels. They run very hot and usually fail first.
When I repaired Toshiba laptops, the inverter usually cost around $150.00. You can buy a smaller WS flat panel for about that these days.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Yup, I bought one a Dell at Clownmart that night for 128.00. It's a WS 18 inch.
Hook up a capacitor backwards and see what happens. Actually, don't do this. But next time I see you I'll tell you a story...
Bill 997.2 |
