POS Briggs and Stratton engine!
My wife was cutting the grass this evening (just another example of what a great wife she is) when the engine shut off on our Cub Cadet Zero-turn mower. I checked out a few things then ran a compression check and had zero pressure. Turns out that the piston is stationary inside the cylinder while the engine spins, so it appears that either the con-rod snapped or the cap on the con-rod broke.
Regardless, I'm screwed because the engine (22hp V-Twin) is 1.5 years out of warranty.............I'm so f'ing made because the engine only had 250 hours on it!!!
2015 GLK (Momma's ride) 2016 F-250 2001 BMW M5 65 CSX 427 Roadster |
Where'd ya buy it?
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
Did you get the memo?
I have a Toro with a "guaranteed to start" B&S motor. Sometimes it doesn't start. Define irony.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Son of a Son of a Sailor
Am I correct in thinking I heard some time back that the Cub Cadets we have today -- and about 2-years ago when you bought yours -- are in no way, shape or form our Dad's Cub Cadets which I still see some of operating today? Old, reliable with a zillion hours on them. Built like tanks, not like Tonka Toys.... Just curious as to where they're made now. Cudos on the wife, too! |
one of gods prototypes
Sounds like it's time for an engine swap......what would it take to swap in something else?
Brought to you by Carl's Jr. |
Like many people, I bought mine at Lowes and after trying to replace the blades, belts, and filters, I have learned my lesson……Lowes is a great hardware store, but they need to make a SIGNIFICANT commitment in supporting the mowers they sell, or they should get out of the business. A few years ago the CEO from Snapper walked away from Walley World because Snapper was trying to sell a quality mower through mass retailers and figured out that it was a bad idea, so I guess I should have paid more attention to his story.
I’ve had some time to cool-off and this morning I took another look at the mower. I’m ashamed to say that the oil is low but I don’t think it should have thrown a rod because of low oil. If I say anything to the wife about not checking the oil, then I will have witnessed the last time that she will ever cut the grass……so the bottom line is that I dinked-up on this one (if the low oil caused the damage). I talked with the local Cadet dealer and he told me that he’s seen a few with broken rods and of those, only a small percentage of the engines have catastrophic damage (i.e. rod through the crankcase). He told me that I could repair it for a few hundred $$$ but I won’t have time to fool with it for several weeks……….I’m having surgery on a torn-rotator cuff in the morning. I guess things could always be worse!
Canucks Fan
Briggs and Scrapiron
Thread Killer
Low oil can definitely be a cause.
I have rebuilt many B&S engines with broken con-rods, and most were due to to low oil (and it's always black and smelly because it was never changed). The worst case would also require replacement of the crankshaft due to bearing failure. If you got lucky, it was just the con-rod that broke, which is a simple repair (assuming it didn't do other internal damage or punch a hole in the case). The upside is that if it can be repaired (cost effectively), it should be fine.
Allen '85 911 Coupe '75 BMW 2002 '02 Ducati Monster 900ie '18 GMC Sierra Denali 6.2L 4wd |
I used to race a kart series that used B&S 5 hp lawnmower engines as a base.
The engines had been cammend had a modified carb and ran on methanol making around 10 hp. We ran these engines 6 hours straight against 20 other teams with the same spec engine. A few of them would fail, but not many. I did see a few blocks that had been "windowed" by a failing conrod! and I saw a few that had been patched with JB weld!
" Formerly we suffered from crime. Today we suffer from laws" (55-120) Tacitus |
Cars & Coffee Killer
I bought a Yard Machine from Wal Mart with a B&S engine when I first bought my house. The mower cost around $100. Within the first year the carb needed to be replaced because the geniuses at Yard Machine had decided to paint the INSIDE of the metal gas tank with a paint that gasoline will slowly dissolve.
Now, I change the oil, spark plug, and air filter EVERY YEAR on my mowers, so lack of maintenance is not a concern... A month after paying $90 for a new carb (installed), the conrod broke. It was going to be another $70 for just the part. I tossed the mower and bought a Craftsman with a Honda engine. It's been trouble-free for 5 years.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
canna change law physics
My power washer with the Briggs and Stratton Engine, runs and runs and runs. It is kept outside and abused. It was hard to start, so I changed the oil and put in a new plug. Runs great again. The problem I always had with mowers, were the decks would crack and fall apart. In highschool, my parents bought a used "Good-All" mower with a cast alumnium deck. I inherited after college. I lost compression in the B&S engine, but the garbage transfer-station always had plenty of extra engines lying around, for free. I think I stripped a plug one time, and I just swapped out the head. It is hard to kill those things.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
unindicted co-conspirator
swap it out for a harley v-twin
oh wait, you said you wanted something reliable ![]()
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution ‘86 928S3 - barn find project car |
If you buy your lawn mower at lowes, WM, HD, they all suck. Go buy a Cub ZTR from and independent dealer. The Tank is still built like a tank and is all but bullet proof. Honda motor that fires every time. Don't go buy you equipment at a Hardware store. Buy it from a lawn equip store.
Used to be Singpilot...
Location: Sioux Falls, SD is what the reg says on the bus.
Oil is the lifeblood in these engines. Every winter evrything gets an oil change, even if it does not need it. Is an easy process once you get started.
Power washer (Honda), log splitter (Honda), 10K Generator (Kohler V-twin), mower (B&S), 2 small generators (EUi2000 Honda and 1kw Honda suitcase). 3 motorcycles, two vehicles, and an RV. All in a single day. The vehicles are mileage driven, and so are done more frequently, and if the gens are used, they get done every 100 hours. Even so, you'd think in your case, a replacement motor is a good investment. |
17 summers ago I "invested" in a Lawn Boy M series mower. It has a magnesium frame and like a motorcycle it has a separate tank for the oil. It is a two stroke that starts real easy. I had to replace the wheels this summer because the old ones were worn down and bald. I paid more for that mower than I paid for my first car. It may be a two stroke engine but it uses way less oil than my old four stroke engine
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
i had rotator done a few years ago. start moving as soon as posible, dont use, just move it around. i thought i tore it again right after i did the surgery. we had an aligator in our lake, that night i dreamed the gator came out of the lake to get me so in my sleep i reached back, withe the bad arm, and tried to get away. hurt like a mother. i layed there in pain for about a half hour. i still cant sleep on that side, it gets stiff, but it is much better.
here is something that people dont realize. take the john dear dealer, they sell they same mower lowes sells and for the same price, but were do you think you will get the best service if it breaks? another thing about lowes, and the others, they sell a product but when it is time to start fixing things they dont support it.
86 930 94kmiles [_ ![]() 88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ ![]() 01 suburban 330K:: [_ ![]() RACE CAR:: sold |
Bollweevil
Don't think you will get that at Lowes or HD.
Jack 74 911 Coupe 2.7L - K21 Option - S suspension |
A few years ago we bought a diesel Cub mower/tractor with a Kubota engine from a Cub dealer. It was one of the worst pieces of crap I ever bought. It overheated almost from the get go among other problems. The Cub dealer didn't have access to the Kubota parts or manuals - had to get them from the Kubota dealer who didn't really care about a Cub mower. One cylinder got low compression and blow by after about 3 years - parts were really expensive - so we sold it for about a tenth of what we paid for it - rather than fix it.
I will never buy a Cub again. Should have been the last mower we ever bought instead it lasted a couple of years. I chaulk it all up to poor design. We bought a Toro Commercial Z-turn. It is a nice machine and has run trouble free. Jeb
Jeb '79 930 |
Caveman Hammer Mechanic
Hello,
I bought a Kubota 21" self propelled mower in 1981, mow the weeds every week on our 1/3 acre plot, change the oil yearly, same spark plug from new(go figger, I keep gapping it closer), run some carb cleaner when I think about it. I finally had to replace the blade clutch, mowed a few too many rocks(2nd blade). Get this, the Sears parts house had the clutch and it was $100.00 cheaper than the Kubota dealer! Hola eric
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Thread Tools | |
Rate This Thread | |
