AutoBahned
RWebb's Avatar
What can I run off a 1 gal. Senco compressor?
those things are tiny - I'm wondering what air tools I can run of of it?
(it was so cheap I could not resist buying the thing - main use is for finish carpentry & it drives the 18 Ga. brad nailer just fine)
now I'm wondering if it will run an impact gun...
Old 01-16-2010, 02:47 PM
williecoyote's Avatar
I doubt it.
Will
85 carrera
Old 01-16-2010, 03:18 PM
Navin Johnson
TimT's Avatar
for a few seconds.. then the pump will kick on and try to keep up...
'69 911 GT-5
'75 914 GT-3
and others
David's Avatar
Guns and impacts on a very short duty cycle. Any sanding, cutting, drilling, painting would be out.
Old 01-16-2010, 03:25 PM
Fill up bike tires? That might not even be enough to fill car tires without a cycle....
Old 01-16-2010, 03:55 PM
Hell Belcho
Nostril Cheese's Avatar
You can use small nailers and other quick use stuff. An impact would need at least a 20 or 30 gallon tank to run somewhat well.
Have you looked into electric impact wrenches? They keep getting better every year. Mine has loosened nuts torqued down over 200 ft/lbs.
http://www.dewalt.com/us/products/tool_detail.asp?productID=10452
Old 01-16-2010, 04:24 PM
You do not have permissi
john70t's Avatar
You'll probably only get about two weak taps from that thing.
It always helps to use oil in the gun first.
Harbor Freight Tools - Quality Tools at the Lowest Prices has a $60 compressor f.s. for the occasional use.
I think there's a store coupon for ten bucks off that.
Old 01-16-2010, 05:32 PM
JW Apostate
trekkor's Avatar
I used a Campbell Hausfield 4 gallon, twin stack unit for about 9 years until the shaft on the end of the motor sheared off.
I used it for nail guns ( framing, roofing, finish ) air chisel, sander, impact gun, air ratchet and I just painted my lemons car until it finally broke.
I just bought a new 'Ridgid' twin stack ( $250 at Home Depot ) and used my air chisel for 4 hours straight on it's first day doing some tear-out.
Sure it would great to have a big tank unit, but I need portability.
KT
'74 914-6 2.6 SS #746
'01 Boxster
Old 01-16-2010, 06:20 PM
Double Trouble
targa911S's Avatar
air brush.
Old 01-17-2010, 05:44 AM
AutoBahned
RWebb's Avatar
portability is key - this lil' gizmo is only 20 lbs.
I may see if it will run borrowed air tools.
Old 01-17-2010, 11:41 AM
1980 911 SC
I had gotten a 4GAL 2.2HP Dual tank Dewalt really cheap, befoe I knew anything about compressors. The only thing I could use it for was to put air in the 911's tires. Non of the air tools that I bought would work properly. I couldn't run a cut off wheel for more than 10 seconds. The air wrench took longer to get lugs off than doing by hand.
So I sold it to a contractor for $75 to use with his nail gun. Its got two hose attachments and he could "hammer" nails all day long.
Next I bought a 28Gal 3.5 HP for next to nothing thinking that would do the job. It doesn't wiegh too much either. It works better but still isn't enough to run the cut off wheel at full capacity.
Its all in the SCFM's when running air tools. PSI doesn't really mean too much. You can have 150PSI but only 2SCFM and it won't do too much with air tools.
I'm going for a 10-15 SCFM minimum next go around.
For air nailers you can't beat a little pancake compressor for portability.
Just my $.02
Life's a Beach
Old 01-17-2010, 03:10 PM
AutoBahned
RWebb's Avatar
what is the S in SCFM?
Old 01-17-2010, 04:21 PM
Old 01-17-2010, 04:29 PM
Navin Johnson
TimT's Avatar
standard
'69 911 GT-5
'75 914 GT-3
and others
Did you get the memo?
onewhippedpuppy's Avatar
My contractor father in law uses one for his finish and brad nailer. For small tasks it's awesome, nothing worse than lugging around a big compressor to nail on a single piece of baseboard.
‘07 Mazda RX8-8
Old 01-17-2010, 04:36 PM
Throw it on the ground!
Had one and sold it. Very handy for quick projects, light and easy to transport. BUT, very loud, long cycle time, gets really hot and had several poor user reviews (check Amazon). Enjoyed mine while I had it - stepped up to a 1/2 gallon Thomas (just because I'm very impusive when it comes to tools) The build quality of Thomas compressor's is unreal:
Thomas T-617HDN (26 lbs)
And, I've got one of these in the garage: T-30HP—1 1/4 HP Air Compressor (43 lbs)
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 01-17-2010, 06:24 PM
