i'm just a cook
lawnmower.......
Hydrofluoric acid - Wikipedia, the free encyclopedia Quote:
Senior Advisor
One of the local refineries use a lot of that stuff, very bad if it gets out of the box.
08 Cayenne Turbo |
HF is way too squirrely to work with. Conc H2SO4 is a lot better behaved. Probably good to have some NHO3 and toluene around as well in case you need to make some TNT.
I've used most every organic and other nasty chemical. I stay far away from HF... |
Unregistered
I had a very small delayed HF burn on my finger back in the late 80s. It took about 10 hours to show up but it hurt like heck. Evidently HF will eventually work it's way through 1/8" thick PVC gloves if you give it enough time. I had to get calcium glutanate shots into my knuckle. They mix it with KY jelly and keep it in the freezer so it's really thick, you can imagine the size of the needle they have to use. I passed out cold as a wedge during the third shot. Woke up on the floor with all kinds of doctors and nurses standing around. Felt like a girly-man that day. BTW, you know how aluminum polish turns black when you polish rims? Chances are that's HF melting away the top layer of aluminium oxide. HF in metal polish is really diluted (maybe a few PPM) but if it gets under your fingernails there's still a chance it can burn. Gud idea to wear gloves when polishing rims and keep it out of your eyes. I don't think polishing zombies would be a good idea unless you are into concourse zombies. Most-dead-in-show prize? |
You do not have permissi
Was told to use caution with Berrymans carb cleaner.
A guy I met said he nearly lost a liver/life after concentrated exposure. The bodies I could put in the freezer. Dang teenage cat's peristalsis are jet engines. |
Unregistered
I didn't think the Tesoro refinery up there has HF. HF has a boiling point somewhere around 58 degrees IIRC so unless it's really cold it turns into a cloud that hugs the ground and floats a long ways. If conditions are right it can go miles which on a good/bad scale would be way down on the bottom, next to bad. Hopefully you live upwind of that refinery. |
Some good suggestions here. My hogs might be appreciative, but I think the heavy equipment is most practical. Hmmm, I could fill in that low area out by the gazebo. Now to figure out how to lure the zombies over there before they're dispatched, so I don't have to collect them all.
I hear they like brains, but what else are they generally attracted to? I could invite over a few derelicts from the local bar to sleep out in the yard, but not sure the grey matter content would be high enough to trigger the desired response from the undead intruders. Ideas?
Early 911S Registry # 1 SCCA F Mod National Champion 1995, and once more before I stop |
Detached Member
They used to use HF at the Powerine and Mobil refineries in LA. Nasty stuff, had water deluge systems which I doubt would have worked because it would had destroyed the operators before the homeowners about 100 feet away. I did some Gaussian plume dispersion modeling on Powerine in the 80's and the catalysmic release spill scenario was a lethal dose area that was something scary like five miles across and 10 miles downwind. I mean everything dead, dead, dead.
Hugh |
Senior Advisor
Sammy it's the tesoro refinerey (now philips 66) close to Ferndale, I stay away! 95% bad juju. There trying to change there prosess after several had to have there fingers amputated following a small release several years ago.
08 Cayenne Turbo Last edited by James Brown; 03-10-2010 at 08:26 PM.. |
Banned
Banned
Control Group
That HF is nothing to f*ck with, no thanks.
She was the kindest person I ever met |
Unregistered
the Mobil refinery still uses HF and their deluge system works. I worked there off and on as a contractor in the early 80's. Valero Wilmington still uses HF (worked there for 9 years also) but they now use a modified HF that has a higher boiling point so it tends to stay in a liquid longer. the reason deluge systems work on HF (if they are functional) is the HF disolves in the water fog really easy and as such turns from vapor back to liquid so it's more easily cotnailed. They also have containment dykes and other systems to prevent contaminated liquid from escaping the process unit. Valero's deluge system was capable of something like 24,000 gpm or something huge like that. It was remote controlled and aimed and could throw out one heck of a lot of water. they have all kinds of safety systems in place there, that is a very safe refinery. |
