Cars & Coffee Killer
legion's Avatar
I would argue that turning a bicycle and turning a motorcycle are two completely different things. With I bicycle, you lean and the bike follows. With a motorcycle, you lean the bike (which weighs more than you do) and you follow.
5 liters of VVT fury now
-Chris
Old 04-08-2010, 12:35 PM
nostatic's Avatar
I disagree. Both use countersteering, and the physics are very similar other than the weight differences.
Old 04-08-2010, 12:39 PM
legion's Avatar
I found it to be a completely different motion between my mountain bike and my cruiser. YMMV.
-Chris
Old 04-08-2010, 12:43 PM
Driver
Noah930's Avatar
I'm with nostatic. Countersteering works on bicycles and motorbikes, alike.
1990 Black 964 C2 Targa
Old 04-08-2010, 12:48 PM
nostatic's Avatar
Countersteering - Wikipedia, the free encyclopedia
Old 04-08-2010, 12:53 PM
legion's Avatar
From the article Todd posted:
At the same time, the rider technique of applying pressure to the handlebars to initiate a lean is not always necessary, since, on a sufficiently light bike (especially a bicycle), the rider can initiate a lean and turn by shifting body weight, called counter-lean by some authors.[1][2][3] Documented physical experimentation shows that on heavy bikes (many motorcycles) shifting body weight is less effective at initiating leans.[4]
This is exactly what I was talking about. As a kid, I most often rode my bicycle sitting upright without touching the handlebars. I learned to steer by leaning alone. That doesn't work at all on a motorcycle. Countersteering on a motorcycle causes the motorcycle to lean first. I've never tried countersteering on a bicycle (that I know of).
-Chris
Old 04-08-2010, 12:57 PM
Driver
Noah930's Avatar
Perhaps I should clarify: countersteering works on bicycles, as it does on motorcycles. I speak from personal experience.
Old 04-08-2010, 01:19 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Countersteering works on both but is not the most effective way to turn a bicycle. The physics does work, but the rate at which a bicycle can turn because of how light it is can be shockingly quick. I don't recommend it except for VERY low speed. It's okay on a lighter motorcycle. It's virtually a necessity on a big, heavy pig of a motorcycle like a Harley or other big cruiser type.
Anyway - a moped is like a fat chick. Yeah, they can be fun to ride and good for a thrill occasionally, but don't let your friends catch you on one!
Black Cars Matter
Old 04-08-2010, 01:33 PM
nostatic's Avatar
You did it, just didn't realize it. If you race a bicyle, you most certainly do it.
Next time you ride with no hands, lean and watch what the bars do.
Quote
Old 04-08-2010, 01:41 PM
Dueller's Avatar
For all you motorcycle countersteering naysayers
Jim
1987 Carrera
2002 BMW 525ti
1997 Buell Cyclone cafe project
1998 Buell S1W: "Angriest motorcycle I've ever ridden."
Old 04-08-2010, 01:48 PM
Driver
Noah930's Avatar
Again, I'm with Todd. I've countersteered on bicycles at around 20 mph before. It's like skiing; the faster you're going, the lighter and gentler you are on the control inputs. The underlying principles are still the same. I would argue that the faster you're going, pedal bike or motorbike, the more effective is countersteering.
One of the motorcycle racing schools welded up a bike so that the steering head could be locked straight ahead. Their point was that no matter how much you leaned, without turning the handlebars (countersteering), you could not turn the bike.
Why wouldn't that be the same for a bicycle? If you were to weld the steering stem straight ahead on a bike, would you be able to turn it just by leaning? Why would the physics between riding a bicycle versus a motorcycle be so different from one another?
Old 04-08-2010, 01:54 PM
least common denominator
scottmandue's Avatar
1st soldier: What? A swallow carrying a coconut?
King Arthur: It could grip it by the husk!
1st soldier: It's not a question of where he grips it! It's a simple question of weight ratios! A five ounce bird could not carry a one pound coconut.
King Arthur: Well, it doesn't matter. Will you go and tell your master that Arthur from the Court of Camelot is here?
1st soldier: Listen. In order to maintain air-speed velocity, a swallow needs to beat its wings forty-three times every second, right?
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 04-08-2010, 02:04 PM
jyl jyl is online now
jyl's Avatar
Seems that relative mass of rider and machine should influence the behaviour. Whenever the contact patch of the front tire is behind the steering axis, leaning the machine to the right will tend to steer the front wheel to the right. The greater the weight on the front wheel, the greater this force. (The frame geometry matters too.). The gyroscopic action of the front wheel will try to resist this steering. The greater the mass of the spinning wheel and the higher the rate of spin (I.e. the greater the angular momentum) the more the wheel will resist being steered. On a bicycle, the front wheel has mass of 1 lb and is spinning slowly, so not much resistance to steering, while the rider's mass places let's say 80 lb of weight on the front wheel. On a motorcycle, the front wheel has a mass of 10 lb and is spinning faster (since motorcycle are usually going faster), while the weight on the front is let's say 300 lb. It looks like the ratio of steering force to gyroscopic resistance would be higher for the bicycle. If true then the bicycle's front wheel would be more easily steered by leaning. Kind of a good high school physics problem, reduce everything down to net torque on the steering tube and compare.
Old 04-08-2010, 02:40 PM
When you countersteer, you don't just lean.
For a left turn, to countersteer, you lean and actually turn very, very slightly to the RIGHT.
Works on a bike and a BIKE.
Old 04-08-2010, 03:00 PM
drag racing the short bus
dd74's Avatar
I've heard it said that with a bicycle, one steers with their hips. This must have something to do with placement of body weight and lean. I could perceive much of the same with a motorcycle, only the motorcycle can be steered in the same way, but this has to be done at a much higher speed because the motorcycle is heavier.
The Terror of Tiny Town
Old 04-08-2010, 03:08 PM
SAIGON 68
johnnywishbone's Avatar
Hijacked?
"Been thinking about a first motorcycle, or maybe something like an aprilia city scooter."
BUY A PRE-OWNED JAPANESE BIKE 600cc OR SMALLER. $2,000.00 OR LESS. PLENTY AROUND IN THIS DEPRESSION. INSURE IT. RIDE IT. DON'T WORRY ABOUT THEFT. DON'T WASH OR WAX IT. AFTER A YEAR, YOU'LL KNOW WHAT YOU WANT TO DO.
Old 04-08-2010, 03:10 PM
Somewhere in the Midwest
MotoSook's Avatar
If you can find one get a Suzuki Bandit 400. They should go for less than $2000 and being a major Japanese brand should be cheap to maintain.
Like this one:
1991 Suzuki Bandit 400cc
Old 04-08-2010, 03:41 PM
racer's Avatar
Get one you can fit on comfortably. I would also not go bold with displacement for a first bike. Check out a place like craigslist... lots of 250-500cc "first bikes" out there for sale. Don't let the small cc or "low hp" fool you, as you can still get to 60mph quicker than most cars. Log a thousand or two miles on a smaller bike before you buy something too big and heavy for your lack of experience.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 04-08-2010, 04:45 PM
Formerly bb80sc
Vipergrün's Avatar
Hey everyone, thanks for your responses!
Ok, to set the record straight, yes, I have "ridden" bikes before, but never owned one, and never rode legally. That's obviously not the right approach.
Im a husky guy, 5'9 and 200+ lbs.
I will defnately do safety courses, get licensed, etc. I'll probably wear my track helmet and will certainly wear safety gear.
Im not being naive about accidents, I take the porsche to the track and understand the risks, but it's also about minimizing risk.
Long ago I wanted a Suzuki Katana, love the Hurricane as a kid. I'll check out some of the bikes you all mention.
thanks again!!
-Brad
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 04-08-2010, 05:36 PM
JCF JCF is offline
Here's my 15 min commuter.
But then one of the routes I take is through woods and fields.
Du must schwein haben
'67 901/05 rebuilt 2.2
Bultaco Metralla 62 "XDina"
'68 BMW R69S
Old 04-09-2010, 03:09 PM
