Formaldhyde. The new Radon...
AutoBahned
1. Buy horizontally louvered windows.
2. Install louvered windows in the vanagon 3. Install vanagon sliders in your house 4. You'll have cool louvers in the van, and genuine German safety glass sliders in the house. Win-win. |
AutoBahned
around here, all windows or glass that are under 30"(i think its 30") must be tempered glass.
Is that a state code, because it's not one of the requirements of the ICC code IIRC.
AutoBahned
Outstanding job!
Before I posted, I checked the ICC code again and it calls for tempered glass within a 24" diameter of either side of a door.
For tempered windows, it has to meet all three requirements, not just any one one of the three. Building Codes Tempered or laminated glass must be used in the following locations: Glazing in doors and enclosures for hot tubs, whirlpools, saunas, steam rooms, bathtubs and showers. Glazing in any portion of a building wall enclosing these compartments where the bottom exposed edge of the glazing is less than 60 inches above a standing surface and drain inlet. Glazing adjacent to a door where the nearest exposed edge of the glazing is within a 24-inch arc of either vertical edge of the door in a closed position and where the bottom exposed edge of the glazing is less than 60-inches above the walking surface. EXCEPTION: Tempered is not required when there is an intervening wall or other permanent barrier located between the door and the glazing. Glazing in fixed or operable panels, other than those locations described in items 2 and 3 above, that meets all of the following conditions: Exposed area of an individual pane greater than 9 square feet Exposed bottom edge less than 18 inches above the floor Exposed top edge greater than 36 inches above the floor One or more walking surfaces within 36 inches horizontally of the plane of the glazing EXCEPTION: Tempered is not required when a protective bar is installed on the accessible sides of the glazing 34 inches to 38 inches above the floor. The bar shall be capable of withstanding a horizontal load of 50 pounds per linear foot without contacting the glass and be a minimum of 1-1/2 inches in height. Glazing in any hand railing regardless of height above a walking surface Glazing in walls and fences used as the barrier for indoor and outdoor swimming pools and spa when all of the following conditions are present: The bottom edge of the glazing is less than 60 inches above the walking surface on the pool side of the glazing The glazing is within 5 feet of a swimming pool or spa deck area Glazing in walls enclosing stairway landings or within 5 feet of the bottom and top of stairways where the bottom edge of the glass is less than 60 inches above a walking surface NOTE: Refer to Section 2406 - Safety Glazing, 1994 Uniform Building Code for reference of the above information. Quote:
AutoBahned
That does looks really great!
Are you leaving the wood raw/sealed or painted? I like the contrasting color the way it is now. |
