help with check engine codes
First I have been on all the mbz forums and those guys dont have a clue. My daily driver is a 98 mercedes c43, the cel was on with codes 170 and 173. I replaced the maf and now it misses at 3k and above and engine code 170 173 and now 110, you guys have any ideas. I may have to break out the p-car for a daily driver and really dont wanna, Thanks, Kevin
Get the AutoEnginuity software and cable package and it will be a life saver. I have had it for over 3 years now and it is used mainly on the F350 Dually but I have also used it on the Mini and the wife's Caddy. No more guessing and cheaper than the dealer for an older daily driver car.
Friend of Warren
I don't know squat about Benzes, but if it didn't miss prior to changing out the maf and now it does, first thing I would check for would be a vacuum leak. Might have missed a hose when you replaced the maf.
Kurt V No more Porsches, but a revolving number of motorcycles. |
A lot of the after market MAF sensors that we purchase for just about any car are bad. Those 100 codes are likely multiple fuel trim and multiple cylinder misfires. Unless it's an actual BOSCH MAF you're playing with a moving target.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
I believe that those first two codes are indeed maf related codes. If you have already replaced the maf, I would be looking for any air leaks in the air intake tract. Any unmetered air leak that is downstream of the maf sensor, will cause running problems, and will also set maf codes. Good luck
No left turn un stoned |
Also , look carfefully at the crankcase ventilation hoses, I think these are tied into the air intake pipe as well.
Take a look at my reply on benzworld. Most of us mercedes guys do have a clue.
Mike |
Certified Pre-Owned
I think code 110 (P0110) is the air intake temp sensor. I would look for something loose... ?
'84 Carrera Coupe |
Here's a list of trouble codes: OBD 2 Fault Codes Reference Guide
I would try to clean the MAF first, cant hurt. |
Thanks for all your info guys i have had more responses here in one afternoon then in a couple days over there, Kevin |
Are the codes the same for all OBD II cars?
What I came up with matches the others posted: P0110 IAT Circuit Malfunction P0170 Fuel Trim Malfunction (Bank 1) P0173 Fuel Trim Malfunction (Bank 2) |
No hoses on my R&R of the MAF on a W163.
And BTW - you can get a Bosch for low $$ at Germanstarparts.com
David 1972 911T/S MFI Survivor |
The dreaded CEL - it just showed up on our newest truck at work - less than 150 miles.
poof! gone |
My thoughts exactly. On my Mercedes I could hear the intake manifold sucking air in....
