Kevin Stewart's Avatar
help with check engine codes
First I have been on all the mbz forums and those guys dont have a clue. My daily driver is a 98 mercedes c43, the cel was on with codes 170 and 173. I replaced the maf and now it misses at 3k and above and engine code 170 173 and now 110, you guys have any ideas. I may have to break out the p-car for a daily driver and really dont wanna, Thanks, Kevin
Old 05-26-2010, 11:22 AM
John Rogers's Avatar
Get the AutoEnginuity software and cable package and it will be a life saver. I have had it for over 3 years now and it is used mainly on the F350 Dually but I have also used it on the Mini and the wife's Caddy. No more guessing and cheaper than the dealer for an older daily driver car.
Old 05-26-2010, 11:47 AM
Friend of Warren
I don't know squat about Benzes, but if it didn't miss prior to changing out the maf and now it does, first thing I would check for would be a vacuum leak. Might have missed a hose when you replaced the maf.
Kurt V
Old 05-26-2010, 11:49 AM
Scott R's Avatar
A lot of the after market MAF sensors that we purchase for just about any car are bad. Those 100 codes are likely multiple fuel trim and multiple cylinder misfires. Unless it's an actual BOSCH MAF you're playing with a moving target.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-26-2010, 12:58 PM
fastfredracing's Avatar
I believe that those first two codes are indeed maf related codes. If you have already replaced the maf, I would be looking for any air leaks in the air intake tract. Any unmetered air leak that is downstream of the maf sensor, will cause running problems, and will also set maf codes. Good luck
No left turn un stoned
Old 05-26-2010, 01:07 PM
Also , look carfefully at the crankcase ventilation hoses, I think these are tied into the air intake pipe as well.
Old 05-26-2010, 01:08 PM
Take a look at my reply on benzworld. Most of us mercedes guys do have a clue.
Mike
Old 05-26-2010, 01:59 PM
Certified Pre-Owned
BGCarrera32's Avatar
I think code 110 (P0110) is the air intake temp sensor. I would look for something loose... ?
'84 Carrera Coupe
VincentVega's Avatar
Here's a list of trouble codes: OBD 2 Fault Codes Reference Guide
I would try to clean the MAF first, cant hurt.
Old 05-26-2010, 02:59 PM
Sorry but i have owned mercedes for several years and i rarely get any answers at the forums.
Thanks for all your info guys i have had more responses here in one afternoon then in a couple days over there, Kevin
Old 05-26-2010, 04:59 PM
A930Rocket's Avatar
Are the codes the same for all OBD II cars?
What I came up with matches the others posted:
P0110 IAT Circuit Malfunction
P0170 Fuel Trim Malfunction (Bank 1)
P0173 Fuel Trim Malfunction (Bank 2)
Old 05-26-2010, 07:59 PM
No hoses on my R&R of the MAF on a W163.
And BTW - you can get a Bosch for low $$ at Germanstarparts.com
1972 911T/S MFI Survivor
Old 05-26-2010, 08:35 PM
The dreaded CEL - it just showed up on our newest truck at work - less than 150 miles.
vash's Avatar
here is a great list.
Listing of Diagnostic Trouble Codes for 1996+ Mercedes
poof! gone
Old 05-26-2010, 08:53 PM
Originally Posted by fastfredracing View Post
...I would be looking for any air leaks in the air intake tract. Any unmetered air leak that is downstream of the maf sensor, will cause running problems, and will also set maf codes. Good luck
My thoughts exactly. On my Mercedes I could hear the intake manifold sucking air in....
Old 05-27-2010, 09:47 AM
