canna change law physics
red-beard's Avatar
Ford F150 - Any years, models, engines to avoid?
I expect to be buying a used F150 this year, assuming my deals with Mexico go through.
It has to be a 4 door Crew Cab and 4WD. I'm looking for Value here. I have looked at the Lincoln LT as well, since it is basically a Ford F150 with all of the options.
Again, any years, engines, etc, to avoid?
In some respects, I'd prefer a Super Duty F250 with a diesel, but those seem to be a bit pricey, even for the lower end units.
James
Red-beard for President, 2020
Old 08-20-2010, 09:55 AM
pwd72s's Avatar
The 5.4 gas V-8 has a good reputation, as far as I know from guys talking about their pickemups on the Mustang boards...
Old 08-20-2010, 09:57 AM
Laneco's Avatar
Alot of the 5.4 Triton engines (maybe others as well) had issues with the spark plugs. The metal fails and the plug either strips or removes a chunk of cylinder head metal. Don't mean to say this is common, but there is a Ford Factory repair kit for it (time-cert)... Our local mechanics keep them in stock. They are even known to blowout of cylinder head by themselves. Changing the plugs is not a happy-happy joy-joy event either as with each turn of the spark plug took you are wondering if it's going to come out OK or come out very very badly.
This is not to say this is a bad vehicle - far from it, this is a good, smooth running, strong engine. But it is a very widely known problem.
Spark Plug Ejected From Engine - Ford Problems.com
angela
Hello
Old 08-20-2010, 10:43 AM
You do not have permissi
john70t's Avatar
I think the mid/late 90's F150/E150 had two gas tanks with a cross-over pump which sometimes caused trouble with rust/sediment/electrics.
Old 08-20-2010, 10:49 AM
Here's a bit from my experience. I have had about 60 F-150's and F-250's over the last dozen years (contractor).
2004 to 2009 - get the 5.4. The 4.6 was anemic then and the trannies prone to failure. Also, regardless of engine size, the front rotors have made-in bearings that are prone to failure. Not much to do but replace - fortunately they are not that spendy. These trucks have a great ride!
2010 (maybe 2009) - 4.5 is a 3 valve - much smoother, better power, better tranny.
2003 and earlier - completely different truck. Engines are solid, most common problem we've had is an occasional bad coil pack. They do not have near the ride of the 2004 and later trucks.
Hope that helps.
1972 911T/S MFI Survivor
Old 08-20-2010, 11:05 AM
Oh yes, I second the thought about staying away from the two tank trucks. This is a definite weak point in the early F-250's.
Old 08-20-2010, 11:06 AM
red-beard's Avatar
Thanks for the replys. I expect it will be 2004 or later model. Most of the ones I've looked at were the 5.4 liter. Good to know about the plugs, I'll make sure that they are changed first thing and have anti-sieze installed on them.
James
Old 08-20-2010, 11:26 AM
We have had a spark plug failure exactly as described - but only once, and on a pre 2004.
Old 08-20-2010, 11:31 AM
I'd avoid the ones with a blue oval on the front...
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 08-20-2010, 11:37 AM
Hendog's Avatar
I picked up an '04 F150 with 5.4l and went out and bought an extended Ford factory warranty right away. The spark plug issue wasn't a problem since they were replaced once prior. The intake gasket did develop a leak however and was covered by the wty, but I doubt it's a common problem. The clutch pack in the rear differential is known problem; mine is starting to slip on tight right turns under load from a dead stop. Turn a hard right, apply the brakes a little to load the diff, and then apply some gas to move the truck. There is a TSB on this problem. Having said all that, I really like the truck.
Henri
Owned for 21 years: '87 Carrera coupe Venetian blue
Old 08-20-2010, 11:54 AM
red-beard's Avatar
No problem, I'm really looking for a MK LT
James
Old 08-20-2010, 01:13 PM
Try not, Do or Do not
Henry Schmidt's Avatar
Any Tundra is a better choice than the F150
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 08-20-2010, 01:29 PM
I wonder which would be cheaper to maintain in the long run. The Ford parts are very inexpensive, and we get 300K hard miles out of them before we sell them for 10 - 15% of the purchase price ($2-3K).
Old 08-20-2010, 01:54 PM
A930Rocket's Avatar
On the F150 forums I belong to, the spark plug issue is known, but not a real concern. The accepted method to avoid blown out plugs is to install them dry and 28 ft lbs.
Edit: I have 188k miles on my 01 SuperCrew, with just regular maintenance.
Old 08-20-2010, 02:04 PM
Senior Member
Superman's Avatar
What you should want is one o' them ol' F150's with the 300 CI straight six. Good power, torque, gas mileage and reliability. Folks are still waiting to see how many miles it takes to wear those motors out.
Mocha 1978 911SC. "Coco"
Old 08-20-2010, 02:16 PM
Hi Dave
Not trying to start anything here just stating my experience.
I was a Ford guy and after a buying Tundra I wouldn't even consider a Ford. All thing considered including maintenance costs.
The only issue I have had is brake rotors and cryogenic treatment fixed that. I guess diving into corners and trying to get a 4600 lb truck to take a set is hard on brakes.
Henry Schmidt
Ph: 760-728-3062
Old 08-20-2010, 02:53 PM
chapo's Avatar
As my Tundra owner said after towing his 23 ft toybox, guess I need to buy a big boy truck.
Patrick
Old 08-20-2010, 07:55 PM
Tundra 5.7L@381 hp 400@3600 rpm
Ford 5.4L 310@5,000 365@3,500
The experts say:
"The last time we compared the Tundra and F150, the Tundra was safer and more powerful than the F150. The Tundra had more standard safety equipment, a better tow rating, more horsepower, bigger brakes, and better overall performance. While Ford will finally be adding standard Roll Stability Control, there’s no mention of improving the 5.4’s power or tow rating, or improving the braking system."
Now if we're talking diesel why would you want an F150?
Henry Schmidt
Ph: 760-728-3062
Old 08-20-2010, 08:39 PM
red-beard's Avatar
Diesel would be for an F250.
Note: I must have a truck with a GVWR over 6000 lbs...
James
Old 08-20-2010, 08:55 PM
chapo's Avatar
Now Henry, you know how JD Power operates right? Ask anyone in the business. Much like the BBB spend money with us or else. BTW the data is from 07.
Patrick
Old 08-20-2010, 09:15 PM
