Slackerous Maximus
"high compression motor has pressure release valves"
Good thing too. My experiments with an 'intake valve only' system (I was trying to cut down on emissions) didn't pan out.
2002 custom softail chopper
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
Free minder
Bwahahahaha! ...what else can I say?
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Driver
Isn't that what you get when your high compression motor puts a rod through the side of the case?
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
I know it sounds goofy, but I had a Yamaha dirt bike or such that had a pressure release valve, that was operated by a thumb lever or such, that made the bike easier to start. Once started, you let go, and off you went.
I've always referred to a rod through the block as "custom ventilation."
Regarding the motorbike, is it an air rear suspension bike? That might explain the "release valves." angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
There were times when I wished my Norton had it. Damn thing would kick back and try to throw me over the handlebars.
Unoffended by naked girls
Compression release. Common in high compression motors.
The Yamaha 360 enduro was a single-jug bike that had the bar-mounted release.
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
one of gods prototypes
my honda 350x/blaster had a pressure relieve valve.....it was operated by a cable attached to the kick start for easier starts.....it is simply a lever which bumps open the exhaust valves so it'll start easier.....
so yes.....LOL
Brought to you by Carl's Jr. |
Slackerous Maximus
I guess the real story here is my lack of mechanical knowledge. Looks like a common feature on larger displacement bikes that are kick started. You learn something new everyday.....
Don't be too hard on yourself. Its not just for high-compression kick started but mainly high compression in ratio to what you use to turn the engine over. Lots of small diesels have compression release simply because the starter size is smaller. The big CC motor cycles have them even without high compression sometimes because they have to turn an engine and a primary (and sometimes a goofy 6" wide belt) with a tiny motorcycle starter and battery. Your 748S engine is high compression but doesn't need compression release most likely because its high compression with only 748cc's instead of high compression with 2100cc's.
beancounter
Yup.
My bro's 1964 Cheoy Lee sailboat is sporting the original Volvo MD-1, 1 cylinder diesel engine. We call it the one-lung'r. The compression release is nothing more than a lever on the valve cover that forces one of the valves to remain open. You press the starter button, wait a few moments for the starter (doubles duty as the generator) to spin up the massive flywheel, flip down the compression release and she chug, chug chugs to life.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
Big inch Harleys get that way primarily from extremely long strokes. Try 4 3/4" or 5" strokes on a two cylinder motor with 11:1 compression. You just can't mount a big enough starter, or a big enough battery to drive that starter on a motorcycle, even if it is a Harley. No human alive could ever kick one over. Hence the compression release.
You guys who love to knock Harleys should try riding a big inch stroker Harley sometime, like something in the 120-140 cubic inch range. Granted, they don't live long at those displacements, but OMFG, do they have torque. And a sound and feel you will simply never experience anywhere else. When you whack that throttle open, one hell of a lot more than acceleration starts to happen - the whole damn bike shakes so hard it blurs your vision, it's damn near impossible to hang onto the grips or keep your feet on the pegs, much less your ass in the seat. And the noise will make your ears bleed... I've ridden a couple that were honest-to-god superbike fast, where their owners claim 10 second quarter miles. Let me tell you, they accomplish that in a whole different way. Nothing the least bit refined or genteel about it. There is just so much noise, vibration, and all around commotion, plus the unsettling suspicion that something might just fly out of that rear jug at any second. You know, the one aimed right at your crotch.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Detached Member
My 1930 Rudge Whitworth motorcycle also has a compression release because it hasn't got a kick start, you pull in the compression release to slightly open the exhaust valves and roll it down a hill to get everything turning you dump the compression release and off it goes. Am I missing something?
Hugh |
You do not have permissi
A pressure release device would be a good application for cruising on just a few cylinders for good milage, or a hybrid start sequence.
Detached Member
Maybe, provided you can turn off the fuel injection to those "off" cylinders. I would imagine it would run rough. I think Caddie made something like that in the 90s and it was a disaster.
Hugh |
Dog-faced pony soldier
Yeah, "D-O-D" (Displacement on Demand"). I wouldn't touch one of those cars with someone else's 10-foot-pole.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Fast Acting, Long Lasting
My DT 360 had one, my XL 250 had one, and my DR 350 had one.
I don't know why a DT 360 had one though, being a two stroke with a long kick start lever and all.
Eighteen ways to burn fuel. |
Still Doin Time
My old school pro street bike = 93 CI - 3.5" bore X 4 13/16" stroke - 13:2 compression. I hve a manual coarse-thread bolt with a wing nut threaded into the rocker box on the front cylinder that just holds the exhaust valve open. I hit the starter, get the engine whirling over (if I'm lucky) pull the choke once, then open kill switch. If all goes as planned - which it sometimes does all H3ll breaks loose and I back off the threaded bolt by hand - then let it warm up
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
A free-riding open cylinder with an individual trottle should only remove some bangs per rotation from the flywheel, I'm guessing. |
