slodave's Avatar
I doubt it in hot conditions. After you turn the engine off, the fan isn't moving anymore and the engine temp rises quite a bit really fast. I questioned my dad about the practice of cooling down the engine (turbo) in his plane. I mentioned about the sudden rise after engine shutdown. It does spike. A lot of his engine is logged and can be reviewed on a computer later.
Old 07-01-2011, 12:09 AM
Arizona_928's Avatar
yeah heat soak.
Now does a bag of ice on the intercooler of turbo cars really work?
dolor et pavor
Copyright
Old 07-01-2011, 12:10 AM
rnln's Avatar
when I first got the car, for several months, I opened the lid when I got home to see and hear the engine runs before I come in
Fat butt 911, 1987
Old 07-01-2011, 12:20 AM
crustychief's Avatar
I know you can harm a light airplane engine and cause cracking around injectors and such by pulling power and descending while full rich. I figured if the engine ( my 911's ) was in static air then no harm could come of it. I guess by opening the lid you increase the convective cooling flow quite a bit though.
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 07-01-2011, 12:35 AM
A930Rocket's Avatar
If you have been on the boost, then the IC will be hot. The ice will make a bag of water, but that's it. No engine cooling at all. Best to let it run a few minutes instead.
Old 07-01-2011, 01:47 AM
Super Moderator
cstreit's Avatar
Originally Posted by crustychief View Post
I open my decklid (no fan though) when I drive on really hot days ( 100 plus ) is it like shock cooling in an airplane? I didn't even think about that!
I think he was kidding....
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 07-01-2011, 06:18 AM
I often check the oil level after I get home. The car will be parked in the same spot on a level garage floor. When I shut it off I close the lid. If it cools down in 2 hours instead of 4 what difference does it really make? At the autocross the engine never gets that hot to make a difference.
Old 07-01-2011, 07:40 AM
Make Bruins Great Again
Por_sha911's Avatar
If its really hot out or I've been running it hard I'll let the engine idle for 30 seconds in the garage. After it is shut off I'll pop the hood.
Joe
Old 07-02-2011, 10:05 AM
Free minder
Aurel's Avatar
Did ya notice the engine lid has a big rectangular opening on it?? I guess Porsche engineers did that for cooling purposes. When I want to cool down my house, I do not feel the need to open the screen door either .
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 07-02-2011, 10:14 AM
pwd72s's Avatar
I did raise the lid...under the "can't hurt-might help" theory...I do the same to my now H20 cooled cars...to keep wax melting heat off the hood...
Old 07-02-2011, 11:49 AM
Control Group
Tobra's Avatar
I figure it is easier on the rubber if you pop the hood, especially if you just got done getting it really hot
Old 07-02-2011, 02:35 PM
A930Rocket's Avatar
Are you talking about your car or your sex life?
Old 07-02-2011, 04:05 PM
Information Junky
island911's Avatar
A930
That's similar to what I do; but I'll drive the last minute or so at low load/high RPM. My thinking is that the fan speed is brought up, and the cylinders are pumping mostly air. --pumping air thru, inside and out. ...and because the car is moving, recirc is not an issue.
Old 07-02-2011, 04:10 PM
Unregistered
sammyg2's Avatar
that's stupid..everyone knows hot air drops.. (read this in green text..please)
Just like how race cars speed up when they hit the grass
Old 07-02-2011, 04:26 PM
