"YOU CANT RACE A CAB."
ODDJOB UNO's Avatar
Originally Posted by trekkor View Post
This cannot fail.
KT
the power of a RESTRAINING ORDER is a BEE-U-TEE-FULL THANG!
he wants to build the fence. he HAS TO GET PERMITS! and right there zoning will say "GET A SURVEY!" PERIOD!
as a matter of fact when before i had the 3 semi trucks of block and cee-ment show up and dump their load.............my licd bonded insured registered azroc contractor demanded a survey from me before he would touch it. and he made it clear since he had done alot of "these" walls.............build it 1 foot in on yer property. and sure as POO..................it worked to my favor.
clown boy non attorney................veers the other way when he sees me now.
if there are TROUT..........there are BEARS!
Old 08-03-2011, 05:20 AM
Neighbor wanted to put a driveway in a narrow right of way that he technically did not have right to. Saw him out there one day with a chain saw cutting down trees (heavily wooded) and surveying. This right of way bordered on 3 of my neighbors properties, none of us wanting what was once woods behind out homes now a driveway. Had to bring in lawyers. Was able to terminate him using this for any access. $30K later its all settled. It's tough to not want to go over and hit him with a shovel when I see him out cutting his lawn. The bigger that jerk, the more you may need some legal means.
Old 08-03-2011, 05:31 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Tell him to get a survey. If he doesn't you run the risk of losing a slice of your land down the road if he claims and maintains the piece of land uncontested for a period of time (usually several years). Raise hell and don't back down. Get local building and planning officials involved as necessary. DO NOT TRUST MARKERS OR PINS FOUND. How do you know they haven't been moved or aren't placed in error? This is why a new survey by a licensed surveyor is required.
Short money for the peace of mind.
And DEFINITELY baby-poo yellow. No bout adout it.
Black Cars Matter
Old 08-03-2011, 05:44 AM
wdfifteen's Avatar
Originally Posted by TheMentat View Post
Quite simply, it is his responsibility to keep his stuff on his own property. If you have walked him through your calculations and there is still disagreement, then he should hire a surveyor. If you are really concerned about what he thinks of you, tell him that you are doing him a favor by trying to clarify things beforehand, rather than with any "unreasonable" subsequent owners of your property.
EXCELLENT!
This is what you should do.
Old 08-03-2011, 06:14 AM
I think this is a good approach. He's obviously a douche so deceiving him shouldn't be too hard. In the mean time, pay for the survey. He wont. The fact that he is going to build a fence should be reward enough for your trouble. You'll never have to talk to him again.
Old 08-03-2011, 06:23 AM
You do not have permissi
john70t's Avatar
75 acres, and he wants to build right now onto an unknown exact property line?
That doesn't sound reasonable, rational, or very neighborly.
There may also be a certain number feet set-back from the property line required. It may even be many feet. This info will be found in the country building statutes/code.
In the meantime, serve him paperwork if there are no cooler heads in his family.
Old 08-03-2011, 07:21 AM
Surveys can be disputed. Just getting "a" survey isn't always the answer. The survey I had (and I had several because of refinancing) was not in complete agreeement of the one he had. His was some historic copy from the farmer he bought the land off of that used landmarks like trees. But since he had been using this for his property lines for the dozens of years he owned it and I knew it didn't agree I let it go. It was only off a few feet. But those feet made a big difference when you need a minimum width for a driveway. I actually own about 4 wooded acres, but the house is situated right in the corner next to this numbskull. Since, we have planted numerous pine trees and focus on the area of our property where most of the land is. It took the legal representation to come up with a survey that satisfied both parties. I'm not completely bitter. He now can never place a driveway there and ownes about 5 acres of land that is completely land locked behind my property. Maybe I'll offer him $10/acre?
Old 08-03-2011, 07:27 AM
The Unsettler
stomachmonkey's Avatar
It's your property and you have every right to protect it. Don't see any argument against that.
Old 08-03-2011, 07:35 AM
Rick Lee's Avatar
Whose survey really counts? When I sold my first house, the buyer had a survey done and it came back that my fence was 18" on the neighbor's property. But I had never touched the fence since I moved in and I also had a survey done at the time I bought the place. Eight yrs. between those two surveys and the fence was never touched. Which one was right? I ended up having to escrow something like $300 at closing to move the fence and make the issue go away.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Danimal16's Avatar
First thing is send him a registered, restricted delivery letter telling him of the encroachment. Your State's laws may allow for a prescriptive taking, which such a letter will prevent.
Record the line survey that you had performed, this will further protect your line.
Start taking care of the lawn that he has been taking care of to assure your property rights.
Good luck
Dan
Old 08-03-2011, 07:46 AM
ODDJOB UNO's Avatar
when i bought my house 20000yrs ago, i had it surveyed. the southern hillbilly who moved in pulled some crap and my stake markers. that is A FELONY class 6. stake markers in az. have a plastic uv proof cap that have survey date, surveyors ID, and some other crap.
it is then recorded BY LAW BY THE SURVEYOR as a LEGAL DOCUMENT and it aint cheap.
anyway southern hillbilly disputed the markers, raised hell, and HE had to resurvey after i proved with PICTURES where the markers were on the day of the survey. so he gets it surveyed............and guess what? i was RIGHT and HE WAS WRONG! since he was running a biz out of the property(horsey feed biz), all my neighbors and myself dawg piled his worthless moron azz, and sicked county zoning on him. county zoning shredded him into pieces and he moved. then the place sat for a couple of years empty(2.5 acre R-43 parcel).
then clown boy non attorney bought it. as we all know the infamous "baby poo yellow painting of MY WALL INCIDENT", he TOO had his azz handed to him in spades, when he disputed my claim. county zoning went back and saw how many times i have had it surveyed, agreed with my survey, and clown boy non attorney paid at least a $1000 bucks plus for a SURVEY THAT SHOWED MY WALL 1 FOOT IN ON THE PROPERTY LINE! DUH you freeking MORON i told ya that!
hahahahahahaha LMFAO! slice dice mince tag em and bag em!
all the marbles in OJU court.
cuz thats how i roll.
if theres EVER a TIME TO BE DEAD NUTZZ "RIGHT"..................now is the time.
Old 08-03-2011, 07:58 AM
AutoBahned
RWebb's Avatar
suggest use of a projectile weapon
Old 08-03-2011, 03:14 PM
Detached Member
Hugh R's Avatar
Got to Zillow.com and put in your address, it may well give you the answer, it did for a neighbor of mine.
Hugh
Old 08-03-2011, 03:20 PM
Run smooth, run fast
Heel n Toe's Avatar
$30K out of whose pocket?
- John
Old 08-03-2011, 03:21 PM
The Unsettler
Friend of mine lives a couple of houses away from this debacle.
Neighbor dispute leads millionaire to put toilet bowl decor in front yard | Sun Journal
Seaman is unmoved by the complaints, and offers his fellow residents a quirky caveat.
"You should be nice to your neighbors," he said. "They can make you wish you never lived here."
"I want my two dollars"
"Brandon Won"
Old 08-03-2011, 03:47 PM
Banned
If the people that did the survey you have a copy of are still around call them and have them locate the missing corner, they will flag up the existing corners and it really shouldn't cost an arm and a leg. Then if the guy builds on what you consider your property, you have a problem, but he will have to prove you wrong. You will have a recent survey, he has nothing.
Old 08-03-2011, 04:03 PM
Registered Usurper
DARISC's Avatar
Cracks me up.
Hell, I'd buy Seaman a beer; sounds like a real character.
I wonder if he's aware of a precedent, re whether his collection is 'art', that dates back to The Armory Show in NYC back in 1917.
Google Marcel Duchamp's famous sculpture 'Fountain'.
'82 SC RoW coupe
Old 08-03-2011, 04:16 PM
$30k split between the 3 neighbors. In retrospect it was done the wrong way. My neighbor works for an oil company that uses the firm K & L Gates. The offered to do this for a discounted fee since they work with him professionally. Discounts on fee's that are over $500/hour don't amount to much in the long run. I got a copy of the bills and it had all the breakdowns of $150 faxes and other mindnumbing figures. I could of got someone out of the green sheets for far less.
Old 08-03-2011, 04:52 PM
peppy's Avatar
Be careful with fences, in Virginia they can bill you for half of the costs. I think it has something to do with protecting your land from thier livestock.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 08-03-2011, 05:06 PM
p911dad's Avatar
Our property is locally known as where Dave made Sean move the fence. You can imagine the struggle. The previous owner (Dave) made the back neighbor (Sean) remove a 300+ foot fence and relocate it to 1' off the correct property line (local code) after Sean encroached on Dave's (now ours) land. Sean had the fence erected while Dave was away, and placed it an average 6' on Dave. The crazy thing is this whole area is a well surveyed subdivision with maps on file in the county offices. The pins aren't hard to find. That fence doesn't look like much but damn. it cost a ton to get it in the right place!
In this case Dave paid for the survey, how that finally worked out I don't know. I do know it was messy, but Dave prevailed in the end. Sean moved on after the business was done. I was told Sean felt it was just some woods and who would care, anyway.
Old 08-03-2011, 05:07 PM
