D idn't E arn I t
RANDY P's Avatar
Originally Posted by drb930 View Post
GH85,
I have a nice RV Cam (Crower 250 HDP), adjustable steel timing gear & chain set, and pushrods that you could have for $50.
I will guarantee it good, not even 10,000 miles on them.
I also have a set of what were brand new 406 casting heads with stainless steel valves and poly locks, but they wont fit a 305 block.
I also have a nice 350CI factory forged steel crank, all ready to go balanced for 1700-1800 grams rotating assembly.
I build a full roller motor, (converted a Gen-1 block using all factory parts with V-6 lifters) for my Elco 357CI with fuel injection and a 700R4.
PM me your phone number, and I will talk your ear off!
Thanks,
Dave
Ok, what's the trick to getting that thing licensed in CA?
Nice.
rjp
AOC/Hogg 2028
Old 09-30-2011, 11:17 AM
I am about ready to order my new engine for my 86 El Camino. I will probably order this:
GM Goodwrench - 10067353 - New Chevy 350 CID, 5.7L , V8 - Universal Crate Engine, Factory Replacement for 71-85 GM Cars & Trucks
It is the older style 350 with a two piece main seal, but my intake will bolt right up. I will probably need a new flex plate but that is less than 70 bucks. If I go with a later model engine like this one:
GM Goodwrench - 12518298 - NEW GM 1987 - 1995 5.0L, 305 CID, 8 Cylinder Engine
my intake will not fit and I would need a different intake. The amazing this is I could buy a 1986 engine but is costs $750 more!
Now I really need to figure out my exhaust. The current stock exhaust manifolds are the exact same ones that were on the 350 from what I can find from the part numbers. If I stick with my current manifolds the old exhaust will bolt up and I am done. I can do everything for under 2 grand.
If I change to headers I will need to redo the exhaust and likely go with a dual exhaust. That will cost some bucks. I hate the sound of headers and prefer the quiet of manifolds. The ram head manifolds I have found all point down right in the middle and would not fit my application.
I need to find some muffler shop that has been in business for ages and has a pile of old ram head manifolds in the back from guys switching to headers.
Old 11-08-2011, 02:03 PM
[QUOTE=GH85Carrera;6359651 I hate the sound of headers and prefer the quiet of manifolds.[/QUOTE]
I just don't understand this. Is this in English or a foreign language or something?
To each their own. I'd love to have something that I could run headers and mufflers and no cat on. I love the sound.
I'd go with the 350, swap the flexplate and stick with the exhaust manifolds if I were you. (assuming the exhaust manifolds do indeed fit the 350 which I suspect they probably do.
Old 11-08-2011, 03:18 PM
least common denominator
scottmandue's Avatar
Because you have insisted this is no race car and just for economical transportation.
Will a V6 fit in there?
Maybe same power and better gas milage?
Crazy talk I know.
Gary Fisher 29er
2019 Kia Stinger 2.0t gone
1995 Miata Sold
1984 944 Sold
Old 11-08-2011, 04:02 PM
Crazy talk I know.
It'll be more expensive to bolt a V-6 in where a V-8 already lives. With the V-8 there are several parts that will swap from the existing engine to the new engine. To swap in a V-6, you'd have to buy a complete engine instead of a long block.
Old 11-08-2011, 05:16 PM
pwd72s's Avatar
Pay yer money & make yer choice...
Edelbrock.com - Crate Engines - Small-Block Chevy - Introduction
Old 11-08-2011, 05:18 PM
I'm still in the LS1 camp....
Old 11-08-2011, 05:28 PM
You do have rear end choices for your G body, bolt in.
80's Olds 442 or Buick Grand National turbo 8.5" 10 bolt posi, bolts right in
1987 Carrera
Old 11-08-2011, 07:27 PM
Yea, that is true, but they are very rare, and demand is high.
I ordered the crate 350 Goodwrench engine. It will arrive next week. Everything I need to do th engine swap for $1,721.55, even the break in oil & oil filter.
Old 11-09-2011, 11:08 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Make sure you have the oil priming tool that goes in the distributor hole. the oil system must be primed before you start it. I've seen people make this mistake before with SBC's.
Old 11-09-2011, 11:31 AM
Unregistered
sammyg2's Avatar
if it's already been test run then he won't need to do this, it's just to prime the pump for the first time.
if it hasn't been test run then it's a very good idea.
Old 11-09-2011, 11:35 AM
What other “while I am in there” things can add a few HP and not cost a lot?
I have a 2004R transmission. It is a 4 speed with a full lockup torque converter & I have a limited slip rear end. That part of the drive train is fine and will not be touched.
All this talk of engine upgrades - if you don't have a shift kit in the 2004R, I can tell you an automatic can be transformed by a good quality shift kit. I've put in dozens of these for friends and family over the years. I wouldn't think of owning an automatic without one.
Tranny Source Rex
Rex
1975 911s and 2012 Range Rover Sport HSE
1995 BMW R1100RS, 1948 Harley FL
Old 11-09-2011, 11:52 AM
Tranny Source Rex
+1 on the shift kit.
Old 11-09-2011, 12:27 PM
It has the shift kit. It has a full lockup torque converter. The rear end is a limited slip rear.
Old 11-09-2011, 08:14 PM
Just a basic overhaul kit. Stay under budget.
Old 11-10-2011, 05:40 AM
