broken gate- how would you fix?
We came home tonight and noticed that our electric gate was broken. How would you fix it if it were you? I attached a picture of where it broke. I was thinking about drilling a hole through it and threading a rod to reconnect the two pieces. I would just need to find someone that could help me with that though.
Suggestions? Gate opener mechanism is from Rutland which apparently went out of biz. ![]() Thanks, Neil
Neil '73 911S targa |
In the shop at Pelican
Pictures of the pieces that thing connects to please.
It's difficult to tell without knowing what the other side of that break connected to. Your suggestion of a threaded rod might be the best solution.
Edit - Jason beat me to the first reply
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Family Values
Bubble gum, duct tape, zip ties and bailing wire. If you need more to fix it, replace it.
- Joe Necessity is the plea for every infringement of human freedom. It is the argument of tyrants; it is the creed of slaves. - William Pitt |
You do not have permissi
A threaded rod will be difficult to match up both sides with precision.
A 90deg drill guide might help drilling, as will shiming/clamping the pieces in place for marking, but the fix will be weaker(smaller diameter) than the original. Camfering the edges and adding a perimeter weld would be stronger, IMO. |
Weld it.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
This look like it?
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
That's it Pete! I'll take a picture of the other end in the morning. I wish I could just buy the hydraulic part alone and not a whole new kit.
I assumed the frame pivot was iron/steel as well, because hollow square aluminum will usually break before a 3/8-3/4" steel stud.
Check with a magnet? |
Platinum Member
Senior Member
Superglue!
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
it is simple to fix...using a welding machine
UnRegistered User
Is the inside of that piece threaded into the pinned end that has broken off? Some of them were adjustable by threading the connecting end in/out.
What type of metal is the outside/inside? If both ends are decent steel, maybe sleeve the broken end to the actuator and weld it up.
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
![]() I'm assuming here that This Piece is screwed into That Piece and This and That and The Other are all steel. If that is correct, get a bolt or piece of threaded rod that is the same as This Piece, take the threaded rod or bolt and The Other Piece to your friendly local welding shop and have the new threaded piece welded to The Other piece. Screw it all back together.
^^^ This.....or that......or the other
Unregistered
The answer to all of life's questions is McMaster carr.
My bet is you can find one of these that will work. McMaster-Carr |
Could you gently heat the aluminum with a small flame but not the steel inside then try and back the steel out with a bolt extractor? Of course you would need to have it in a vise.
Paper Member
What do you think caused it? Weak design? Does the gate open and close smoothly?
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Here is a picture of the offending parts. It looks like they used cheap "pot metal" to connect the two pieces. I think Sammy's idea of getting a replacement part similar to McMaster sounds like the way to go. I will need to find a machine shop that can drill and tap a hole in the existing part.
![]() Thanks, Neil
