abides.
3d Modeling Question
Ok... i know there are a few engineer/designer types out there with 3d modeling experience.
How do I drill radial holes in a round/spherical part? Like if I wanted to model a wiffleball? I don't remember ever doing something like this in school, and I can't find any relevant tutorials or forum posts. FWIW I'm using Inventor, but I'm guessing it's probably a similar operation in Solidworks or whatever else is out there these days.
Graham 1984 Carrera Targa |
The Unsettler
Bump
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Slackerous Maximus
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. |
My "generic" approach for a line of radial holes around the equator of a sphere:
- Revolve a couple of concentric arcs about an axis. This creates the shell of the sphere. - "Extrude cut" a hole from the center of the axis "through all" the entire sphere. - Rotary pattern the extrusion about the axis. A true wiffleball will require a CAD tool with surface topology pattern capability. I don't believe that's Inventor... |
Max Sluiter
Might be able to do something with the sheet metal or warp functions. It depends on the hole. Otherwise I would setup a plane and a couple axis, extrude cut a hole through the spherical shell, then rotary pattern it about several axes.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Information Junky
The pitch will be different, at different "latitudes" - so you'll need to create a few circular patterns.
make a hemisphere and mirror
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
+1. This is how I would do it in ProE.
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
In Inventor, place a work plane on the cylinder or sphere, sketch a circle on the plane and extrude a hole.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
abides.
Thanks for the tips, I'll give them a shot.
