How fast can a Mustang go?
1987 GP White 930
1977 Ford Bronco
Old 12-20-2011, 12:04 PM
Burn the fire.
Brando's Avatar
It was an automatic. Does that make a difference?
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 12-20-2011, 12:06 PM
pwd72s's Avatar
I saw 140... Get caught going past 100 on any Oregon road, and it's a $2,000 minimum fine, loss of license for a minimum of 30 days, and possible confiscation of the car. So, I guess I'm not going to make such a test.
(edit) I'm wondering if he went to an aftermarket aluminum driveshaft...I've heard tales of those having balance problems, causing vibrations at higher speeds. Pretty impressive speedometer climbing up until the end....especially since the title says it's a V-6?
Old 12-20-2011, 12:09 PM
Slackerous Maximus
HardDrive's Avatar
Bet the guy left a pile in his underwear. Pretty good acceleration. It took right off from 80.
2014 Cayman S, PDK
Old 12-20-2011, 12:36 PM
B58/732
BlueSkyJaunte's Avatar
My old man is a television repair man. He's got this ULTIMATE set of tools. I can fix it!
ΜΟΛΩΝ ΛΑΒΕ
Old 12-20-2011, 02:58 PM
Team California
speeder's Avatar
One more reason to stick w/ 911s. Hey, any Porsche fans here? I really like Porsches.
Old 12-20-2011, 04:20 PM
nostatic's Avatar
Doesn't it depend on how high the cliff is?
Old 12-20-2011, 04:32 PM
Max Sluiter
Flieger's Avatar
Until it reaches terminal velocity. Even then a beetle can beat a 997 Turbo S cabriolet to a certain distance.
Old 12-20-2011, 04:42 PM
Non Compos Mentis
Yeah- I've got a well-set-up 944!
Old 12-20-2011, 04:53 PM
pwd72s's Avatar
With no way to know if it's driveline will let go at 135...
Old 12-20-2011, 05:01 PM
nostatic's Avatar
Depends on the cliff...
Old 12-20-2011, 05:09 PM
Non Compos Mentis
I had my old 944 Turbo past 135 a few times (Professional driver, closed course, don't try this at home).
I currently have a 944S which is good for more than 135, but then there is the race car- An early 944 prepped to SCCA's ITS Class. With such limited prep allowed, and the rules requiring the windows to be open, there is no track I've been on with a long enough straight to get past 130 or so.
At least the driveline has never let go (yet).
Still tempted by the 2005-09 Mustangs. Nice cars.
Old 12-20-2011, 06:45 PM
Slackerous Maximus
HardDrive's Avatar
My 911 will go 155mph in pretty short order. Or so I'm told.
2014 Cayman S, PDK
Old 12-20-2011, 07:17 PM
Did you get the memo?
onewhippedpuppy's Avatar
First dibs on pushing the Mustang off the cliff!
‘07 Mazda RX8
Old 12-20-2011, 07:22 PM
pwd72s's Avatar
Gimme a large enough check, and you'd be welcome to do so...I'd like a nice bit of coin to add to my Boss 302 fund.
Old 12-20-2011, 07:32 PM
entertaining the idea
UconnTim97's Avatar
I'll gladly let you push my 944 over a cliff for a much smaller check... Lol
Old 12-20-2011, 07:37 PM
Bandwidth AbUser
Jim Richards's Avatar
Quote de onewhippedpuppy
I'll go big. $50.
Old 12-20-2011, 08:35 PM
No Band
futuresoptions's Avatar
I'm thinking that the driveshaft taking a dump at 140 was some king of fail safe built into the Mustang... probably had to do with cafe standards or sumtin...
He was a helluva plumber and his outfit was self explanatory
Old 12-20-2011, 08:45 PM
Laneco's Avatar
Strong engine. Seriously. That's a strong NA V6.
angela
Hello
Old 12-20-2011, 09:10 PM
Jim Bremner's Avatar
From another site is that the car is speed limited to 112 ( car taped hda the Governor removed.) and that the drive-shaft is a thin-wall design to reduce weight to increase mpg.
So it's Bush's fault.
Old 12-20-2011, 11:15 PM
