canna change law physics
Reloading and Primers
I've had a reloading press for a while and I'm finally going to start to do a little reloading.
Is there a list someplace on what caliber uses what primer? I've been looking around on some of the websites and there doesn't seem to be a list. A little help
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
The Unsettler
Ask Jeff, don't ask Jack.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
James, have you bought any of the reloading books such as the one by Lyman or RCBS? They cover loads of all power ranges, primers to use and so on. I would visit a local shop in your area that deals in reloading supplies and ask questions. If the guy behind the counters starts ranting against this or that, try some place else. Just do not blow your self up!!!!
19 years and 17k posts...
The "recipes" that I use (Lee die documentation, books, etc...) all list the primer size, near the dimensions of the case and completed cartridge.
Art Zasadny 1974 Porsche 911 Targa "Helga" (Sold, back home in Germany) Learning the bass guitar Driving Ford company cars now... www.ford.com |
I just picked up ABCs of Reloading. I'll take a look through.
There are only four primer sizes available; large rifle and small rifle, large pistol and small pistol. The size used is dictated by the case into which it will be seated. Generally speaking, .30-'06 and belted magnum case head sizes take large rifle primers, and the .223 / 5.56mm case head sizes take small rifle. With handguns, generally speaking anything .38 caliber and smaller take small pistol; .40 and up take large pistol.
The primer pockets on each of these four general groupings are all different sizes, even though large rifle and large pistol look about the same, as do small rifle and small pistol. They are not. Rifle primer pockets are about .0005" to .001" bigger in diameter, and just a touch deeper than pistol case primer pockets. Pistol primers are, therefor, too loose to be safe in rifle cases. Don't mix them up. Each of these four sizes are further divided into "standard" and "magnum". This has nothing to do with whether they are used in standard or magnum calibers, believe it or not, nor the physical size of the primer, but rather indicates how much priming compound it contains, along with how "hot" it burns. In very broad terms, standard primers are for lighting light to medium charges of fast to medium burning powders, and magnum primers are for lighting bigger charges of slower burning powders. This is the only aspect of all of this that can get confusing - it is common practice to use standard primers in magnum cases with some powders and some bullets, and an equally common practice to use magnum primers in standard cases with some powders and some bullets. That is where recognized sources of reloading data come in - they will all list the primer used in a specific combination. Changing primers in a given load can and will change pressure and velocity developed by that load. Not necessarily just changing from a standard to a magnum primer, but also when changing brands of primers, even if both brands are the "same" as far as standard or magnum. In other words, changing from a standard CCI primer in a given load to a standard Federal primer in the same load will result in different pressure and velocity. This isn't a bad thing, but rather something to be aware of, and also a pretty good way to get that last little bit of refinement out of a given load. Speer has what is probably the best manual available for basic reloading information such as this. It has several chapters explaining everything you will ever need to know about primers, cases, powders, bullets - the works. The Lyman manual is excellent for this as well. Both offer far more than simple lists of loads for various calibers; they are very good tutorials on the hobby of reloading in general. Some other manuals supply comprehensive tables of loads for every caliber on earth, but are lacking in the nuts and bolts instructions on how to use the equipment to assemble the loads, or why certain primers are used with certain powders in certain applications, and that kind of "in depth" information. The Speer and Lyman manuals all cover this stuff in great detail.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
use Winchester primers. One size fits all. Hehe, not really. As Jeff said it's one or the other. Winchester cost a few cents more a box but they are very good primers. Lots of bang.
That's a good book. Also get a good current reloading manual (I have Lyman) and read it. Probably a good idea to pick up a couple of manuals. I have an older Speer manual which has different load information from the Lyman. It would be a good idea to find a real person (as opposed to imaginary ones like me) with relaoding experience to work with.
'86na, 5-spd, turbo front brakes, bad paint, poor turbo nose bolt-on, early sunroof switch set-up that doesn't work. Malo periculosam, libertatem quam quietam servitutem. |
A Primer primer.........
Not really, but if anyone is interested, montroseauctions.com has a big firearms auction this Saturday with several lots of primers up for auction. At least one of the lots contains 3 cases (yes, cases) of primers! There are about 8-900 guns for auction and probably 3-400 other lots. The catalog is 53 pages long! Happy hunting.
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
My bad.........
That is "montroseauction.com, not montroseauctions.com
Winchester produces nothing but "ball" powders these days. Powder burning rates are controled a couple of different ways; size of the kernels or flakes and / or deterent coatings. Traditional extruded powders (they look like little pieces of pencil lead) lean more towards the size of the kernel than any deterent coatings to control burn rate. Modern ball powders (the kernels look like just that - little round balls) rely almost completely upon deterent coatings to control burn rate. This makes them notably harder to ignite than the old extruded powders. Hence, Winchester's use of "hotter" primers accross the board, since all they produce and use are ball powders. Being "hotter" may or may not make them better suited to a given load in a particular rifle or handgun. I will say I have seldom obtained best accuracy with them, with the notable exception of black powder match rifle loads. Even when using Winchester ball powders (760 in the .375 H&H, 296 in the .357 mag, .44 mag, .45 Colt, etc.) I've typically wound up with either CCI or Federal magnum primers. A lot of folks swear by Remington primers, which are generally the "mildest" of the lot. There is a prevailing feeling in the shooting world that the mildest primer that will reliably light the charge provides best accuracy. I'm not convinced. I've used dozens of bricks of Remington primers over the years and have not found that to be the case. Anyway, primers are kind of a "last thing" in the process of load development. When I get a new gun, I typically start with proven powders and bullets, and whatever suitable primer I have on hand at the moment. As I work my way through different powders, charges, and seating depths with a given bullet, I will zero in on a combination the gun seems to like. Then, and only then, will I start fiddling with primers. I'll back the charge off a few grains and work back up with a different primer. Sometimes I see some improvement or deterioration in group size. Sometimes it makes little difference. But, like I say, it's always the last thing I play with. All primers are "good" primers these days, with no one brand of better quality than any other. It's all about suitability of application.
I love reloading threads for the input you guys here provide.
Just out of interest, has anyone had a primer go bang whilst seating it? I sit there with my eye and ear protectors on and hold my breath each time I pull down on the press. I'm quite new to reloading and still struggling to get under 1MOA.
Nick '72 2.4E |
1966 - 912 - SOLD
take all the projectiles and weigh them out and separate them by weight. i use a digital scale that does a tenth of a grain. you will see a range of weights that vary by one or two grains. I found that by keeping the projectiles together grouped by weight my grouping tightened up quickly.
i was too tired to be pretty last night! |
What firearm, in what caliber, do you reload for and shoot? There are some combinations or firearm and chambering that are simple incapable of the mythical one minute of angle. Funny, modern gun writers and the pulp magazines they feed have somehow convinced the shooting public that any old gun in any old caliber simply must shoot moa or it's next to worthless. Hogwash. Nothing could be further from the truth. The simple fact of the matter is that most rifles will never achieve that loft panacea, and there is absolutely nothing wrong with them. Quote:
There are usually other factors that have a far greater influence on accuracy. Bullet selection itself is probably the most important; a quality bullet of a weight suitable for the rifling twist in the given firearm goes a long ways. Seating depth is probably the single most overlooked factor in accuracy, or the lack thereof. It's amazing how sensitive some rifles are to this single factor. Nail those two, and typically any reasonable powder suited to the cartridge and bullet weight, and any reasonable charge of that powder, will shoot well.
1966 - 912 - SOLD
yes Jeff ultimately, these bullets are built for this gun; and these are built for this gun-
only reason a primer would go bang is if you tried very hard to press a boxer primer (the kind u normally get) into a berdan case.
Sorry if I've hijacked this thread. I'll start a new one if necessary but I guess redbeard's question was comprehensively answered.
I shoot a Sako 85 in 6.5x55 Swedish. I can get 1 MOA with factory ammo so I guess I'm just being picky. Really I'm reloading for the cost savings, not accuracy but it would be nice to get it right. I don't target shoot competitively, just for fun on things like running deer and boar ranges. For deer stalking 1MOA is more than adequate. I bought some PPU bullets which were useless and have moved to Sierra Match 120g. I just bought some 107g and 140g too. I got the groups smaller by playing with the seating depth. Sako brass and Viht N160 powder.
Nick '72 2.4E |
The 6.5 Swede is kind of a quandry. Factory rifles are typically chambered to accept military ammunition, which was originally loaded with big, long, 160 grain round nose bullets. As a result, the throats are very long. So long that lighter spitzer shaped bullets just can't be seated out very close to the origin of the rifling before their bases would be out in front of the case neck. So, they have to make quite a jump accross all of that free bored throat before they engage the rifling. Not very conducive to accuracy. That, and the old Swede typically has a very fast twist rifling, like one turn in 7 1/2 inches, in order to stabilize that long for caliber 160 grain bullet. The obvious answer is to use those long 160 grain bullets. Hornady has re-introduced theirs after a few years out of production. Lapua has a 155 grain bullet that both of our little Swedes just love. Sierra used to have one, but discontinued it years ago (I managed to squirrel away half a dozen boxes, but have since used them up). The old Swede made its reputation on these bullets, and they do penetrate like there's no tomorrow. I've never been able to get the short 120 and 140 grain spitzers to shoot as well in this caliber. They shoot great in more "modern" 6.5's, like the .264 Winchester magnum, .260 Remington, 6.5 Creedmoor, 6.5x.284 Norma, and stuff like that. These more modern chamberings, however, are typically throated much shorter (many won't chamber the long 160 grain round noses) and the rifling is a bit slower. The modern thinking seems to be that these lighter spitzers are "better" than the old round noses, because we can get more velocity out of them, they are more streamlined, and therefor they shoot flatter. Meh... gimme that big, long round nose. It's what the Swede built its reputation on, as the "little gun that could". With that bullet, it kills all out of proportion to its size. And most rifles tend to shoot them better.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" Last edited by Jeff Higgins; 03-15-2012 at 10:16 AM.. |
just got off the phone with my brother. he gave away the dillion progressive reloader.
damn. damn damn. there goes my dream of shooting alot alot.
poof! gone |
