Quick baseboard + laminate floor question
I have a small section of wall that is a little off-kilter from the rest; it's between two doors, and there's a bit more of a gap between the flooring and the walling thatn everywhere else. Should I handle this with a wider baseboard, or should I cut a super-thin piece of laminate and try to slip it in there?
Old 04-25-2012, 02:39 PM
BRPORSCHE's Avatar
Send a message via AIM to BRPORSCHE
I would go with the wider baseboard. It's fairly common o leave a small gap for expansion.
-Tom
'73 911T MFI - in process of being restored
'73 911T MFI - bare bones
'87 924S - Keep's the Porsche DNA in my system while the 911 is down.
aka "Wolf boy"
Old 04-25-2012, 02:47 PM
rnln's Avatar
thick baseboard
Fat butt 911, 1987
Old 04-25-2012, 02:48 PM
craigster59's Avatar
I'd go thick baseboard. If you do decide to place a thin piece of laminate, place it along side the wall and place your pencil in a metal washer and roll along the wall as you scribe/ mark the laminate. This will reproduce the uneveness of the wall onto your workpiece.
Old 04-25-2012, 03:10 PM
What?!?!
DonDavis's Avatar
Certainly a wider baseboard is easier.
But, are you replacing all baseboard? If you have a wider section that differs from other walls, will it be obvious? Maybe the super-slim piece makes the rest of your project go a little better? Knowing what you've told me, I'd prob go with the super-slim piece.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
2002 Subaru Impreza WRX, 5speed
2014 Tundra SR5, 4x4
1964 Land Rover SII A 109 - sold this albatross
Old 04-25-2012, 03:12 PM
Zeke's Avatar
Baseboard plus a baseshoe is the classic way.
Old 04-25-2012, 03:57 PM
1/4 round and shoe mold are different. Shoe is typically taller than it is wide. Shoe mold looks better in my opinion.
Old 04-25-2012, 04:46 PM
Thanks guys! If you ever have questions about SAN, LDOM, HPVM, ESX, Linux, HP-UX, Solaris, AIX, or networking, lemme know
Old 04-25-2012, 06:31 PM
Move the wall.
Old 04-26-2012, 05:10 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Baseboard + shoe - you'll never tell and it'll look clean.
Black Cars Matter
Old 04-26-2012, 05:46 AM
Banned
Do it the right way and slice a piece of laminate.
Wider or furred base will make the base proud where it ties into the jamb casings.
Old 04-26-2012, 06:16 AM
Zeke's Avatar
Shoe can be 1/2 x 3/8 or 3/4 x 1/2 with a very gentle round over, the radius being about 1/4.
Old 04-26-2012, 08:09 AM
I broke down and ripped a small strip to patch in. What a PITA! Cutting it was easy; getting it to click in was difficult.
Old 04-26-2012, 07:50 PM
AutoBahned
RWebb's Avatar
HP-UX
hey! that is just Unix 5 in drag
Old 04-26-2012, 09:34 PM
You do not have permissi
john70t's Avatar
I've heard 1/8" gap to the wall is correct for expansion, and easy to cover.
Also, use a flexible "Japanese" saw to cut the door mouldings up slightly so they don't restrict expansion.
Lay the thing on a hard/thick slippery plastic surface to protect the floor.
Old 04-27-2012, 05:22 PM
I've put on the baseboard, which would not have even come close to covering the gap; if you look close you can see the line between the two planks.
Old 05-19-2012, 04:17 PM
Unconstitutional Patriot
turbo6bar's Avatar
Was there a sale on brad nails, or do you simply enjoy using the nailer?
Otherwise, good job. The baseboard without shoe or quarter-round looks clean.
Set the brads with a nailset. Putty and paint.
Old 05-19-2012, 04:42 PM
3/8" to 1/2" gap for traditional floors.
Old 05-19-2012, 05:24 PM
john70t's Avatar
Thanks for the correction, I was probably thinking of the thin engineered flooring.
Materials expand differently. Natural wood swells more across the grain than lengthwise. That expensive underlayment with a gap helps bubbles and pops in the tight, noticeable places. It's worth it to tape the seams well and pay a little more for something that let's the wood slide.
As a caveate, a moisture barrier is only a bandaid and may make the material below(subflooring/joists) mold and rot.
Moisture control is important as well:
-Too little moisture during the winter (for us northerners), and huge shrinkage/gaps appear.
-Too little moisture, and the gaps can clash, buckle and pop up in waves across the surface.
Old 05-20-2012, 07:53 AM
