canna change law physics
BK,
The advantage of the mini-split systems is that they can be retrofitted into homes not setup for AC. You don't run air ducts, instead you run the copper lines only. You CAN just replace the compressor. If you are getting 0 amps on one leg, it sound like something is disconnected or the motor is bad. How big is the condensor? How many tons of cooling? It looks like a 3 or 4 ton unit by size. Again, you can buy a whole new Condensor for only $1500. If you find a person who does AC on the side, like an apartment complex super, install should be less than $500
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Unoffended by naked girls
0A on one leg MAY be the connector on the compressor housing is burned through. This can be repaired by use of a Term-Lok kit.
Term-Lok Manufacturing Inc - Haines City, FL- Welcome
Dan 1969 911T (sold) 2008 FXDL www.labreaprecision.com www.concealedcarrymidwest.com |
You do not have permissi
If it's tripping the breaker, something big is not turning.
For those Pelicans located in the hot/sunny areas of this country, prevention can prevent quite a bit of discomfort. 1). On a milder day, if the wind and comes from the south, put a shade overhang over the deck and a water mister/swamp-cooler for the air blowing through the house. 2). On those scorcher days, close everything up, and open the basement vent windows to bring in cooler air. It's a constant 50-60deg 4ft below the surface.....everywhere in the world. |
From the description it sounds like the start winding. The capacitor and the inductor cause a phase shift to the start winding which induces a rotating field that induces current in the rotor. No rotating field it sits there and buzzes until the thermal protector kicks off.
Rick 88 Cab |
Desertt5
s-c= 2.4 r-c= .9 s-r= 2.9 Compressor toast? Thanks
Semper Fi |
What does it do when you try to start it? Is the capacitor its normal shape?
Rick 88 Cab |
Desertt5
Yes the cap was normal shape. Went ahead a picked up a new one hoping, no change. The compressor makes noises likes it is trying to work but only gets hot. It was 135* on the case yesterday after I tried it again for only a couple minutes.
Semper Fi |
Retired Member
Try a hard start kit. It's wired in parallel with the compressor start capacitor. It's a $25 gamble.
80 911 SC sold 17 Tahoe 07 Z06 Corvette
Do you still have 0A on one leg?
