Home of the Whopper
Home AC troubleshooting
Recently moved into a new house.
Turn the air on Friday night and it is not very cold.
Time to start troubleshooting!
Found one of the nastiest return air filters I have ever seen:
That had to be it, right?
Nope! So troubleshooting continues.
Indoor coil looks pretty clean.
Outdoor coil?
Are you kidding me?
How many of you keep your AC running while cutting the grass?
How many of you will continue to keep your AC running while cutting the grass?
Also found a cut wire to the compressor.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller
Old 05-29-2012, 06:01 AM
Home of the Whopper
15 minutes with shop vac and hose:
That's as far as I got.
Tonight put it back together, cross my fingers, and see what happens.
Old 05-29-2012, 06:05 AM
I clean my coil every spring before I crank up the AC. It is never that dirty. Obvoiusly the PO had no service calls on the unit. Mine is never that dirty. I do leave my unit running when I mow my yard but I sure don't throw the cliiping at the unit, I use the mower's bagging system.
Old 05-29-2012, 06:24 AM
Does that pink wire go to the capacitor? Why would someone cut that?
Did you use it as a heat pump for heat?
Rick
88 Cab
Old 05-29-2012, 07:18 AM
Zeke's Avatar
Some hack may have cut the wire because it kept tripping the breaker.
Old 05-29-2012, 07:52 AM
I wouldn't think it would start without that capacitor.
Rick
88 Cab
Old 05-29-2012, 07:59 AM
Home of the Whopper
It is a heat pump with gas back up.
No idea why somebody would cut a wire ~1" away from a connector.
I hope I can reconnect the wire and fire it right up. We will see!
In the past, I never shut down the AC while I was cutting the grass either.
But like Glen, I changed my filters several times a year and cleaned the coil annually.
I think I will start shutting down the AC just because.
Old 05-29-2012, 09:25 AM
T77911S's Avatar
i just cleaned mine too.
took the fan off like you did. you can buy a spray can of coil cleaner. i spray the coil inside and out, then use the garden hose to clean it from the inside out. then i take a coil cleaning tool and go over it and then hose it one more time- if its really bad.
my yard is very sandy/dusty. the outside unit gets pretty dirty.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 05-30-2012, 10:04 AM
canna change law physics
red-beard's Avatar
You people turn off your AC? Ever?
James
Red-beard for President, 2020
Old 05-30-2012, 11:40 AM
madmmac's Avatar
Just a guess, you never had the home inspected.
Did you buy or are you renting?
madmmac AKA Mitch
1984 Factory Turbo Look
2006 4Runner
1998 TRD Supercharged 4Runner (Sleeper)
Old 05-30-2012, 12:31 PM
Well? Did it run?
Did you stick an ohm meter on it? S-C R-C R-S (sum) R-Case
Rick
88 Cab
Old 06-04-2012, 11:13 AM
You do not have permissi
john70t's Avatar
Mine too, mainly because of a few trees that shed year-round.
Some natural wind barriers help though.
Old 06-04-2012, 11:41 AM
john70t's Avatar
(green) just attach some jumper cables in the box to fix this (/green)
Old 06-04-2012, 11:44 AM
Rick Lee's Avatar
I'm gonna make the wild guess that the damage is done. That looked awful and speaks to years of neglect. There's a good spray to use for cleaning outdoor coils. I change my filter on the first of every month the unit is in use. I also send my tenant a 12 pack of filters so he does the same.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 06-04-2012, 11:45 AM
I saw the aerosol cans of spray at Lowes last week......is this what you mean, Rick?
I've seen the service companies use a tank sprayer with a mixture....maybe i could make up my own?
Getting toasty out - like to get through the season without any drama...
Old 06-04-2012, 11:50 AM
john70t's Avatar
Renting or a new home purchase?
That's an older unit, and if not cooling now, the damage may have already been done. They leak regardless especially if not run several times a year. The circulated oil conditions the seals and prevents leaks.
Not sure about the R-12 replacement costs/proceedures. All new ones use R-134A.
Look at the SEER rating label. Each number higher equals a significant improvement in efficiency. 20% or more i think. Depending on the zone and usage, replacement now will save a lot of money and discomfort.
There should be two tubes running into the house to the furnace, one hot straight from the compressor and one cooler/ambient return.
Old 06-04-2012, 01:38 PM
I think your are thinking of automotive AC systems. I have never heard of a home AC unit running R-12 or 134a. It is likely R-22.
Old 06-04-2012, 01:46 PM
red-beard's Avatar
New home AC units use 410a, in the pink canister
James
Old 06-04-2012, 01:47 PM
Yea, but that is an OLD unit.
Old 06-04-2012, 01:53 PM
red-beard's Avatar
SEER is a seasonally adjusted version of EER. It is a ratio of energy use to cooling.
A 14 SEER unit compared to a 13 SEER unit is ((14-13)/14)*100 more efficient, or in this case, about 7%. A 19 vs a 13 SEER would be almost 32% more efficient.
James
Old 06-04-2012, 02:03 PM
