Home of the Whopper
Home AC troubleshooting
Recently moved into a new house.
Turn the air on Friday night and it is not very cold. Time to start troubleshooting! Found one of the nastiest return air filters I have ever seen: ![]() That had to be it, right? Nope! So troubleshooting continues. Indoor coil looks pretty clean. Outdoor coil? ![]() Are you kidding me? How many of you keep your AC running while cutting the grass? How many of you will continue to keep your AC running while cutting the grass? ![]() Also found a cut wire to the compressor.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller Last edited by BK911; 05-29-2012 at 06:04 AM.. |
Home of the Whopper
15 minutes with shop vac and hose:
![]() That's as far as I got. Tonight put it back together, cross my fingers, and see what happens.
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
I clean my coil every spring before I crank up the AC. It is never that dirty. Obvoiusly the PO had no service calls on the unit. Mine is never that dirty. I do leave my unit running when I mow my yard but I sure don't throw the cliiping at the unit, I use the mower's bagging system.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Does that pink wire go to the capacitor? Why would someone cut that?
Did you use it as a heat pump for heat?
Rick 88 Cab |
Some hack may have cut the wire because it kept tripping the breaker.
I wouldn't think it would start without that capacitor.
Rick 88 Cab |
Home of the Whopper
It is a heat pump with gas back up.
No idea why somebody would cut a wire ~1" away from a connector. I hope I can reconnect the wire and fire it right up. We will see! In the past, I never shut down the AC while I was cutting the grass either. But like Glen, I changed my filters several times a year and cleaned the coil annually. I think I will start shutting down the AC just because.
i just cleaned mine too.
took the fan off like you did. you can buy a spray can of coil cleaner. i spray the coil inside and out, then use the garden hose to clean it from the inside out. then i take a coil cleaning tool and go over it and then hose it one more time- if its really bad. my yard is very sandy/dusty. the outside unit gets pretty dirty.
canna change law physics
You people turn off your AC? Ever?
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Just a guess, you never had the home inspected.
Did you buy or are you renting?
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
Well? Did it run?
Did you stick an ohm meter on it? S-C R-C R-S (sum) R-Case
Rick 88 Cab |
You do not have permissi
I'm gonna make the wild guess that the damage is done. That looked awful and speaks to years of neglect. There's a good spray to use for cleaning outdoor coils. I change my filter on the first of every month the unit is in use. I also send my tenant a 12 pack of filters so he does the same.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
I've seen the service companies use a tank sprayer with a mixture....maybe i could make up my own? Getting toasty out - like to get through the season without any drama...
Old dog....new tricks..... |
Renting or a new home purchase?
That's an older unit, and if not cooling now, the damage may have already been done. They leak regardless especially if not run several times a year. The circulated oil conditions the seals and prevents leaks. Not sure about the R-12 replacement costs/proceedures. All new ones use R-134A. Look at the SEER rating label. Each number higher equals a significant improvement in efficiency. 20% or more i think. Depending on the zone and usage, replacement now will save a lot of money and discomfort. There should be two tubes running into the house to the furnace, one hot straight from the compressor and one cooler/ambient return. Last edited by john70t; 06-04-2012 at 01:40 PM.. |
New home AC units use 410a, in the pink canister
Yea, but that is an OLD unit.
A 14 SEER unit compared to a 13 SEER unit is ((14-13)/14)*100 more efficient, or in this case, about 7%. A 19 vs a 13 SEER would be almost 32% more efficient.
