-   -   Help!! Kremer 930 Slant Nose (http://forums.pelicanparts.com/off-topic-discussions/713347-help-kremer-930-slant-nose.html)
speeder 11-01-2012 08:09 AM
From memory:
New copper rings at base of jugs? Yes.
The sealant you refer to should go between cam housing and heads. You are calling the heads "Jug assembly"?
When I built my last air-cooled 911 engine, I used a special grease on the base of the cylinders that is no longer available. For the life of me, I can't remember what it was called.
Re-use head stud nuts? Yes. These do not fail on Porsche engines. Only the studs. If you're engine has the early '80s studs on it, you should seriously consider changing all of them while the engine is apart. Others will break. :cool:
spuggy 11-01-2012 08:31 AM
Originally Posted by look 171 (Post 7063412)
Pump gas and 1 bar of boost?
State-mandated E10 and factory wastegate/stock spring and a stock coil puking dialetic causing a hard misfire (like a rev limiter) @ 6,000 RPM. Which is a shame, because the motor makes peak HP @ 6,200 with a K27/HF, I seem to recall.
VDO mech gauge reads 12.5PSI max boost; always has, no overshoot.
I have all the bolt ons with major internal work, 3.4L and SC cam. 1 bar boost, pump gas and barely got 364 at the wheels. I have heard from some that they will get upwards of 380-390 at the wheels.
Don't think you can compare different dynos on different days like some would have you believe; too many conversion/compensation factors.
Little issue using dyno charts from the same dyno with the same operator to compare AFRs and power curves (and, to a lesser extent, before/after figures). Although different temps/air densities will skew the readings too.
Checking AFR's is mostly what I'm there for. Although improved figures on the same dyno are generally a sign you're doing something right :)
spuggy 11-01-2012 10:24 AM
Originally Posted by 81Kremer930 (Post 7063190)
We are going to update turbo with a K27-7200,
Better than the 3DLZ boat anchor, but still 20+ year old technology (fitted to late 930's, the 930S and the 3.3 965's, I think).
The current range of zero-clearance K27 hybrid turbos from Kevin (Ultimate Motorwerks) will probably out-perform that by a wide margin; spool faster/more predictably as well as flowing more at the top. They have a compressor map that works better for the car, so impart less heat to the charge air (physics isn't just a suggestion, so some heating from compression is unavoidable). If you're buying another turbo anyway, I'd look into that, unless you have a killer deal on a used one.
Many are tending towards ball-bearing turbo's now for faster spool, but K27 variants tend to win on the "bolt it on" compatibility front... Many folks handle the hybrid K27's, Turbocraft and Rarlyl8 both do.
Heh. I watched a 930 lump getting dropped recently, and was shocked how tiny the stock cold side was... Just didn't look right... :)
turbokraft intercooler, and fabspeed heater box/headers and exhaust.
Both good choices in my book.
The front bumper I have never seen before, consequently neither has anyone else I have spoken to.
The very early factory slants didn't have pop-up headlights either (they used the 944 motor/buckets later, IIRC). They used a variety of solutions, from one to two square headlights, to a single large round one. Pre-M505 option availability, these were Special Wishes (Sonderwunsch) cars.
That square headlight/bumper arrangement looks like it might be adapted from the Euro 944 S layout. Don't really know what the 951, or the 944 S2 look like under the ABS airdam, but they also have lights in the bumper, it seems...
Lots of info on factory slant prototypes, special wishes and production cars in this thread http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/447083-slantnose-slant-nose-slope-m505-factory-930s-documents-registry-ultimate-flachbau.html
In particular, check out this http://forums.pelicanparts.com/4457674-post116.html photo of a factory-produced Special Wishes car in 1980 with two square headlights per side in the bumper.
81Kremer930 11-03-2012 11:23 AM
Well..... We have now torn the motor all the way down... deciding to replaced all bearings and seals, piston rings(2 oil rings broken), even though the bearings all look new and cylinders still have cross/hash markings. This thing is pretty unbelieveable, forged pistons, balanced crank, everything is polished. Americans couldn't even figure out disc brakes in 1981. We still have to get the one broken stud out.. but with a little heat, the rest came out easy, so we're hoping for the same fortune on the last one. I appreciate those links on the special wishes vehicles. There is some serious history about these slant nosed vehicles. I am still hesistant to change the front bumper, even though the DP935 style is available(pretty sweet looking).
When going back together with this engine, what type of silicon-based material is used to seal the case? The paste stuff going between the jugs and camshaft housings I located, but I spoke with a local Porsche mech. who told me to buy this stuff from VW, said it handles heat/gasoline more effectively than the loctite.
speeder 11-03-2012 12:07 PM
Just don't touch the inside of the cylinder/jugs. You know that, right?
fastfredracing 11-03-2012 12:43 PM
Loctite 574 has always been used to seal the case halves, and cam carriers to head interface, and it works well, but others have been using threebond 1194 with great results. I just used it on my last two builds, and has worked out real well. I used a small foam roller to apply it.
It is a little harder to work with, really sticky, messy, and sets up fast, but seems to provide a far superior seal than 574.
This thread will be very helpful to you and your wrench.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/284737-complete-engine-sealant-thread.html?highlight=complete+engine+sealant+thre ad
I have not had a chance to chime in here yet, but I have been following this thread, and I love your car. Never seen such unique colors on one. Keep up the good work.
aigel 11-03-2012 09:50 PM
You really should buy Wayne's engine rebuild book and read it before starting re-assembly. There are a lot of small things and tweaks that need to be done in order to put the engine together right. For starters, you need to clean the hell out of the case and make sure all oil passages and squirters are clear. You also need to decide what new studs you want to install - there are several options.
Good Luck!
G
81Kremer930 11-05-2012 08:04 AM
The inside of the Jug.... We are going to have all the parts.. case, jugs, etc sent to a local machine shop for cleaning only. The engine looks almost new on the inside. I am not to sure what you mean by not touching them(jugs).. we were going to have the valve seals replaced...The engine will be reassembled by a local shop who's expertise is Porsche... This thing is complicated...
81Kremer930 11-05-2012 08:13 AM
We are going back together with 993 TT studs. From what I have read and gathered these are the best/stock out there... They have some coating on them to stop the surface from deteriorating like the older ones..
speeder 11-05-2012 08:24 AM
If the the cylinders are Alusil or Nikasil, (they will be one of the two), you cannot hone them at all. It will damage the surface. Not even the dingo balls on a drill. Nothing. Although a hot tank at a machine shop, (the giant automatic dishwasher-like machine with citrus-based solution), will dull them nicely IME.
The good news is that those cylinders do not wear. I'll bet that there is zero wear on them--no ridges whatsoever, nothing. Just re-ring with Mahle rings and follow an aggressive break-in process for the rings. I had 100% success re-ringing my Alusil SC engine. Some will tell you that it cannot be done, they are speaking from 2nd or 3rd hand knowledge as opposed to experience.
And 993 studs are great! Good luck and keep us updated!
81Kremer930 11-05-2012 05:02 PM
Originally Posted by speeder (Post 7072676)
The good news is that those cylinders do not wear. I'll bet that there is zero wear on them--no ridges whatsoever, nothing. And 993 studs are great! Good luck and keep us updated!
Youre right about the cylinders looking new.... the cross-hashes are still in them! Pretty unbelieveable. All we're going to do is have parts hot tanked, and then go back with reassembly and new parts! Ill get some pics up soon.
spuggy 11-07-2012 06:26 PM
Aren't the 993 studs divilar? They have an appalling reputation for breaking; like immediately after the heads are torqued on assembly, in some cases. Do a search.
I've been very happy with Henry Schmidt's head studs; "SuperTech" - Pelican carries them. Your builder will probably be more familiar with ARP.
Either of those would be a better choice.
Do NOT put the motor together with stock rod bolts - that's the Achilles heel of the 3.2/3.3 motors. Use ARP.
aigel 11-07-2012 10:12 PM
The 993 TT has dilavar and the NA has steel.
http://forums.pelicanparts.com/911-engine-rebuilding-forum/644752-993-head-studs-two-types.html
I don't think it is as clean cut as you say spuggy. Steve Weiner apparently uses the 993 TT dilavar with very good success. (as you can learn in that lenghty thread posted above!)
G
81Kremer930 11-08-2012 06:03 AM
The 993 TT studs are divilar.. with a coating to prevent/stop the corrosion at the base where they're exposed at the case. From the information I have read, and from others by word of mouth here locally, these studs are as good a choice as anything out there without going aftermarket.... I spoke with Steve, he seemed to confirm the others stating these studs would be a fine replacement.
I know that people have different experiences with different engines... I have a feeling that a lot of our difficulty with this particular car is the fact it's sat somewhere outside under a mitten for years.
aigel 11-08-2012 08:37 AM
Sure sounds like you have done your research! Steve is an institution and if he says he hasn't seen these fail, you can be sure that they are good. The thread I posted has practically all viewpoints on this subject, so I don't want to start cooking it up here. ;)
I have to say, the more I look at the pictures of your car every time I come to this thread, the more I like it. I'd love to own an 80s turbo one day. When I bought my 993 I was contemplating a 930 but decided to go with the 993 for better daily driver capability (a/c).
G
spuggy 11-08-2012 09:32 AM
G
Heh. That thread didn't exist when I selected SuperTec studs 6 years/30,000 miles ago.
I respect anything Steve says, for reasons that should be obvious. On the other hand, Henry has a pretty clear (and diametrically opposed) opinion.
Not the first time I've encountered conflicting opinions from highly-respected folks who know what they're doing. Seriously doubt it'll be the last.
Bottom line; pay your money and make your choices :) I've had no reason whatsoever to regret mine - and I sincerely hope you're as happy with any you may make.
81Kremer930 11-09-2012 06:36 AM
Spuggy, youre right. The decisions we make have either positive or negative consequences and once the decision has been made; we all deal with their respective outcomes. I have a feeling we will be okay from what I have read... I am actually more concerned with the piston ring issue(which to use, either Goetze or Mahle).... This project has so many facits that I have never really experienced before... Only time will tell.. I need to get some pics up, I will try to do this today!
Aigel, thanks for that.... We are hoping that this car turns out the way we want it to. It should look and drive fantastically if all goes well.... and since we have torn it all the way down, things should be looking up!
81Kremer930 11-15-2012 04:31 PM
pics and parts!
Well, all the parts are back from machine shop, they look great, and there are probably 1000 nuts, bolts, wires, looming, caps, etc to go back into place!!
This should turn out great with fresh motor, clutch, exhaust, intercooler etc!
http://forums.pelicanparts.com/uploa...1353025724.jpg
http://forums.pelicanparts.com/uploa...1353025749.jpg
http://forums.pelicanparts.com/uploa...1353025771.jpg
http://forums.pelicanparts.com/uploa...1353025791.jpg
http://forums.pelicanparts.com/uploa...1353025834.jpg
81Kremer930 12-13-2012 10:35 AM
The engine is assembled for the most part, it's in time, but the tech that timed the engine recommended changing the chain tensioners with a hydraulic aftermarket version driven by oil pressure.
Anyone familiar with these type(hydraulic)?
Should we just purchase new oem/Porsche style tensioners? What's the advantage of the hydraulic if any?
aigel 12-13-2012 11:05 AM
You need to read up on chain tensioners. It is a long story.
Until the hydraulic tensioners (also called Carrera tensioners) came out on the 3.2 carrera, Porsche had issues with failures on the mechanical jobs.
Here a good post - it includes a mod I learned at Jerry Woods that you should add to the hydraulics as well!
http://forums.pelicanparts.com/911-engine-rebuilding-forum/157121-jerry-woods-chain-tensioner-mod.html
Cheers,
G
