LinkBack Thread Tools Rating: Thread Rating: 1 votes, 2.00 average.
mikester's Avatar
Send a message via AIM to mikester
I hate melamine/particle board! Need to repair something
I have a cabinet in my kitchen that the little folks who have infested my house tend to hang on more than I care for.
The top hinge on the cabinet is pulling out of the particle board frame.
Trying to figure a way to repair it...I was contemplating drilling an oversized hole, large enough to remove the area that is pulling out and putting a solid plug in its place with some titebond. The hinge will cover the repair but if not I can put a layer of the veneer I'm sure over it.
I'm concerned even the plug will end up getting pulled out unless I were to put some sort of anchor for that into the particle board. Maybe I'm over thinking this...
Here are some pictures. I could always simply move the hing but that would require drilling out the cabinet face for the hinge.
-The Mikester
I heart Boobies
Old 11-23-2012, 11:20 AM
RETIRED
Joe Bob's Avatar
You could put two more holes in the hinge further back.....countersink them.
Sand and fill the stripped ones. Put screws in them as well. It's obviously a constantly used door and it seems to be over stressed.
BTDT....I had three door monkies in diapers at the same time....
2012 ML350 3.0 Turbo Diesel
Old 11-23-2012, 11:26 AM
cashman's Avatar
Consider urethane glue like gorilla glue. Put a little glue in the hole. Put the screws in and clamp it. The glue will foam and penetrate the particle board. It will also foam around the screw. Should give a strong bond.
1989 911 Carrera Cab
25th Anniversary Edition
Euro Pre-Muffler, SW Chip
There's nothing better than: Listening to "Going Down the Road Feeling Bad" ,as I, "Go Down the Road Feeling Bad"
Old 11-23-2012, 11:44 AM
If the hinge is full overlay drill a 3/8" hole from the front at the same height as the screws. Run the new screws into the dowel.
Or go to Home depot and look at their furniture building bits. They will have the same thing in steel.
Old 11-23-2012, 11:48 AM
craigster59's Avatar
Two toothpicks in the holes, break them off an screw the hinge back in. Yeah, I'm a lazy ass...
Old 11-23-2012, 11:59 AM
You are on the track that I would try. Use a hardwood dowel for the plug. Then make sure to drill it for the screw. Should do the trick.
I hate that material. I'm in the process of repairing doors that have their faces made of some sort of manufactured woodish material. Any place the finish is broken or chipped the material starts to absorb moisture and swell.
I'm soaking the area with thinned epoxy to stabilize it then refinish.
All of the cabinet doors are having the same issues, I'll be replacing them.
Just the wrong material for the job, especially here in the islands.
Good luck,
Richard
Old 11-23-2012, 12:23 PM
Mike,
What's on the other side of the cabinet and what size screw came out of the plate on those Blum hinges? Is there another cabinet on the other side it? If so, that makes the two sides added together 1 1/2". Use a 1 1/4 sheet flat head metal screw and screw the hinge back into place. The screw will tie the other cabinet together making it much stronger unit. Another fix is to drill a 1/4" hole and insert a dowel and gllue it in place, trim it flush, insert screw again. 5/8" screw is max but it will hold.
Old 11-23-2012, 12:38 PM
mikester's Avatar
It's open on the other side so I can't do anything around there.
Gorilla glue is a nice idea - I have that and understand how it works and that it will fill the area in but I'm not sure it would provide the strength needed to support the screws.
The screws are about a half inch long - not much too them but seem pretty normal for the application.
-The Mikester
I heart Boobies
Old 11-23-2012, 12:58 PM
fastfredracing's Avatar
Have you given a larger diameter screw a try yet?
No left turn un stoned
Old 11-23-2012, 01:16 PM
Old 11-23-2012, 01:27 PM
mikester's Avatar
The sawdust around the original hole would not hold a screw small enough to get a decent bite.
-The Mikester
I heart Boobies
Or a metal plate with 6 wood screws into the cabinet. Then two sheet metal screws through the hinge.
Offset the hinge by the metal thickness.
Old 11-23-2012, 01:29 PM
Drill those 2 holes large enough to get solid material. Glue/pound (gorilla glue is gud) a tapered solid hardwood plug into the holes, drill pilot holes for the same screws. I have a bunch of plugs if ya need em'. Free is a gud price.
JPIII
Early Boxster
Old 11-23-2012, 02:06 PM
Can't you just move the hinge up a 1/2 inch?
Old 11-23-2012, 02:50 PM
coulda, woulda, shoulda
johnco's Avatar
insert nut and machine screw
John
74 911s
Old 11-23-2012, 03:09 PM
DanielDudley's Avatar
Cabinet makers nowadays use an oversize threaded insert into the MDF, and a screw that goes into the insert.
John Beat me to it.
Old 11-23-2012, 03:10 PM
canna change law physics
red-beard's Avatar
Case savers for wood
James
Red-beard for President, 2020
Old 11-23-2012, 03:24 PM
Ronbo's Avatar
This may be the lazy man's method, but I've used it more than once with great results.
Ron
'88 Coupe (formerly)
Old 11-23-2012, 03:34 PM
mikester's Avatar
Not without sinking the other side into the cabinet door.
Not impossible but less than ideal.
-The Mikester
I heart Boobies
Old 11-23-2012, 03:37 PM
johnco's Avatar
the threaded insert works great and I've used them many times with this type of material. should be able to sit on that door after using these. lots of prefab cabinets/bookcases come with these or similar type installed at the factory
John
74 911s
Old 11-23-2012, 03:46 PM
