Hads930's Avatar
Oh yeah, buy Wayne's book!
Old 01-10-2013, 07:53 AM
Grappler
Rodsrsr's Avatar
Dropping the motors the easy part, but your all leaving out the fact that once the motors removed it undoubtedly turns into a "while your in there" project.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 01-10-2013, 08:19 AM
Checked out
McLovin's Avatar
With a leak that bad, there's a good chance it's just the oil pressure sender on top of the engine.
If that's it, it's a $10 part and 1/2 hour of time to replace.
Seems crazy to me to drop an engine without first finding the source of the leak.
Old 01-10-2013, 12:33 PM
syncroid's Avatar
As others have stated, don't drop the motor yet. Get the thing steam cleaned first and reevaluate the leaks. My money is on the oil return tubes leaking. Secondary leaks being thermostat oring, oil pressure switch, and cam feed lines. None of these require pulling the engine.
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 01-10-2013, 12:42 PM
Detached Member
Hugh R's Avatar
Cam feed lines, and three oil return tubes cost me a day or less and less than $100 IIRC, not a drop of oil in 8 years.
Hugh
Old 01-10-2013, 01:34 PM
Grappler
Rodsrsr's Avatar
Thats what I thought, but for some reason I said thermostat in my eariler post. Going back and forth between the Porsche and an American CTS gets confusing at times.
Grappler
Know Gi / No Gi
Old 01-10-2013, 01:43 PM
peppy's Avatar
What dDan said. I pulled mine and it took five years to get it back together.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 01-10-2013, 04:16 PM
Checked out
McLovin's Avatar
Most oil leaks, esp. ones that spring up that quickly and are leaking that much, can be fixed easily with the engine in the car.
so the odds are highly in your favor that you don't need to take the engine out.
Old 01-10-2013, 04:23 PM
Well, I will cross my fingers that an drop won't be needed.
How do I go about getting the engine steam cleaned? Is there somewhere I can rent one or is it better to drive the car to a place that does this??
Rick
1984 911 coupe
Old 01-10-2013, 04:48 PM
Hell Belcho
Nostril Cheese's Avatar
They usually have a place you take the car to, put it up on a lift, and then spray the underside. Call local detailing shops. Im sure they will know.
Old 01-10-2013, 04:56 PM
Ok will do. Thanks!
Rick
1984 911 coupe
Old 01-10-2013, 05:02 PM
Can you take a picture of the underside of the motor and post it?
Might be something obvious that someone will see.
Scott
'78 SC mit Sportomatic - Sold
Old 01-10-2013, 05:34 PM
Senior Member
Superman's Avatar
'Tis a piece of cake, man. The thing that takes the longest is removing the twelve CV joint bolts.
In the Pacific Northwest, all you need to do is announce the date, put beer in the fridge, fire up the barbecue, and the crew shows up.
Maybe Texans aren't as friendly or helpful as us liberals, but it works like a charm in the Pacific Northwest. Then we post pictures.
Mocha 1978 911SC. "Coco"
Old 01-10-2013, 06:21 PM
Well, I have a feeling that Texas Pelicans would be just as ready to lend a hand (and relieve me of some beer and barbecue ribs...) but I guess we'll see if the time comes!!
Now I have to talk with the wife about how to get a little elbow room in that garage...
Rick
1984 911 coupe
Old 01-10-2013, 06:58 PM
VincentVega's Avatar
Yep. I helped on a few engine drops, and dropped the engine on both my 73E and my '95 993C2. No big deal.
Jim! I still have 'the pallet' in the garage.
Clean it up first and ID what's leaking. Fix what makes sense now, you might not need to drop it. Once you do, keep Pelican on speed dial.
Old 01-10-2013, 07:09 PM
canna change law physics
red-beard's Avatar
Ya got that right!
James
Red-beard for President, 2020
Old 01-10-2013, 08:48 PM
Did you get the memo?
onewhippedpuppy's Avatar
Did you literally use a pallet? Because I did, and figured I was the only one redneck enough to do so. Strap engine to pallet, strap pallet to floor jack, carefully balance and block often on the way down to avoid disaster. It actually worked pretty well, though now that I'm not poor I'd just go buy a transmission jack instead.
‘07 Mazda RX8-8
Old 01-11-2013, 07:32 AM
But of course. Custom cut to fit the engine, used on several local cars. Used a motorcycle jack though. Yeah, redneck I guess. Works great.
Old 01-11-2013, 07:34 AM
Bandwidth AbUser
Jim Richards's Avatar
As you can see here, the m/c jack and pallet under engine, and tranny jack under, you guessed it, the tranny. Works like a charm.
Jim R.
Old 01-11-2013, 07:39 AM
