Plug Gap
Got an ignition tune up kit for the E30, plugs, wires, cap, rotor, coil. Looking at the Bosch plugs. On the box it says that they are gapped to .031. Car manual say to set gap at .027. I checked the gap on the plugs and are showing all to be .029. So does it really make that much difference between .028 and .027 gap?
Did you get the memo?
My guess is that the margin of error is at least .001 when setting the gap. Between the human eye and your gapper, nothing is perfect. I'm surprised you can even set it, with most of the plugs going to a fine wire center electrode or multiple ground electrode, most can't even be gapped.
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Hell Belcho
Dont worry about it. Only thing you really need to worry about is NOT running Platinum plugs in these engines.
Saved by the buoyancy of citrus. |
Flat Six
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Now in 993 land ...
I always go with the lowest spec found. It will only go up from there.
G |
Flat Six..PM sent
