I just want to salute the many experienced pilots and their shared wisdom on PP. Gentlemen, well done!
You don't want to be these guys:
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
Thanks for the video. I think this demonstrates well a small aircraft with 3 adults in it trying to climb sloping upward terrain. I believe that a car can climb better a steeper gradient road than a marginal small aircraft can climb a similar gradient. More power the better and 2 engines are better than one but not so economical.
Almost Banned Once
- Peter |
Try not, Do or Do not
We had a Cessna 180 in the family for 40 years but when I took my family on trips especially at altitude, I used a Cessna P210 that was at my disposal.
Safety and comfort made the extra expense well worth it.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Gary H 1978 911 SC
When that plane touched down the first time in a failed takeoff attempt the video should have ended. D.A. must have been over 8500 ft. A total crash due to bad judgement.
Gary H 1978 911 SC |
Senior Advisor
hot air+high altitude+heavy weight= bad performance. The key is engine performance in warm, high airports/ Always check the DENSITY ALTITUDE that is what the engine operates at. you might have great performance at sea level with 4 people but next day at 5000' and high OAT, the performance of the engine might be half!!! no climb, no speed, no chance. Good pilots check this
08 Cayenne Turbo |
![]() I've heard that it's a beautiful flight both ways - taking off from Lake Union and landing at Victoria Harbor in front of the Empress Hotel, and then doing the same in reverse after you've had "tea" or lunch at the Empress - and I'm sure the pilot can make adjustments to the flight to accommodate your wishes. On a beautiful sunny day, that would be totally awesome. This is quite a year for you, eh. ![]() Please take photos for us... Rog _ |
A 172, with 4 souls on board, ain't got enough power to pull a sick whore off a piss pot.
Edgar 1984 Porsche 944 bone stock 1995 Mercedes E320 wagon 1970 Honda CB350 mint!!! |
Seattle Plane Ride
I have flown Puget Sound in a single engine plane quite a bit. It is a pretty place to fly.
Two suggestions: The float planes (Kenniwick Air) are a unique opportunity. As an car guy, you will enjoy the rumble of a radial engine. If you are going to tour the mountains, seriously consider chartering a twin. Every single engine plane goes on "auto-rough" when flying at night, over water or over mountains. This is especially true if your family is in the plane. I never had a place I needed to be enough that I was comfortable flying single engine at night. It just creates one more risk that I do not need to add. We all have to figure out our risk tolerance. OTOH, I always felt more comfortable in a single engine plane than on a motorcycle on the road. |
2000 Boxster S (gone) 1972 911s Targa (sold) 1971 911t coupe roller (sold) 1973 911t coupe / 3.2 (sold) Gruppe B #057 |
As he climbed the density altitude(as mentioned above) became a factor as the air got thinner and he stalled into the trees. Yes you are right the shoulder harness could have reduced the serious head injuries in this situation. |
Bill is Dead.
It may have been on another forum, but I thought it was here... anyway, a couple days after the videos hit the Youtube, this crash was discussed at length.
The conclusions were: The plane was overloaded and DA was high. The pilot made critical errors in judgement, from not consulting W&B and performance charts, to not aborting the takeoff when he was running out of room I searched, but cannot find the discussion.
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
To paraphrase Dean Wormer, "High, hot and heavy is no way to go through life, Son".
1996 FJ80. |
Bill is Dead.
Ok... I found it on one of the other forums I frequent.
The plane is a Stinson 108-3. The airport is Bruce Meadows Airport [U63]. WPR12LA283 Stinson 108-3, N773C: Accident occurred June 30, 2012 in Stanley, Idaho - News & Events - Aviation On the other forum, it was estimated that the plane was at max gross, and that the DA that day was 11,000 ft. Quote:
![]() ![]() ![]() For fun, here is another Stinson that cannot seem to get off the runway: Scary Take off!
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. Last edited by cashflyer; 04-14-2013 at 12:03 PM.. |
