Banned
speeder's Avatar
Why is gasoline octane lower in Colorado?
This has baffled me for some time and I never remember to ask here. Their regular is 85 octane an mid is 87, everywhere else 87 is minimum.
I would think they'd need higher octane there with the mountains, what gives?
Old 07-12-2013, 07:36 AM
Liberal Prawn
foxpaws's Avatar
At high altitude you have less air going into the cylinders- it is like lowering the compression rate. Less pressure at ignition. The lower the compression rate the less octane you need to keep the 'knock' away...
'Such are promises - All lies and jest - Still a man hears what he wants to hear - And disregards the rest. Lie la lie, lie la lie la lie la lie' Paul Simon
'87 Black Targa "Welpe" • '93 Cadillac Allante "Amante" • Various other boring cars
Old 07-12-2013, 07:44 AM
Functionista
manbridge 74's Avatar
There is less air inhaled with every gasp. Engine can be human or mechanical, doesn't matter. So less power made equals less actual compression needing less octane.
Also, engines last longer here if not started outside in negative temps/driven up mountain passes heavily loaded etc, as they are stressed less all things being equal.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 07-12-2013, 07:45 AM
Functionista
Fox beat me by a minute. More concise as well.
Jeff
74 911, #3
Old 07-12-2013, 07:46 AM
Liberal Prawn
foxpaws's Avatar
Ah, she isn't just a PARF know it all - she actually does know something about cars...
Old 07-12-2013, 07:47 AM
Functionista
Which is why you should strafe the tech section more (insert appropriate icon here).
Jeff
74 911, #3
Old 07-12-2013, 08:03 AM
Send a message via AIM to fintstone
...or living in Colorado.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-12-2013, 08:10 AM
Liberal Prawn
foxpaws's Avatar
I used to - however, when someone claimed that their string and masking tape method of aligning a car was going to give them more accurate results than a laser aligner - I sort of gave up. (I know alignment really, really good )
Old 07-12-2013, 08:30 AM
Functionista
Don't let one bad apple ruin the bunch. Alignments concern many variables that most, even trained alignment techs, will miss.
Jeff
74 911, #3
Old 07-12-2013, 09:23 AM
motion's Avatar
85 here in Montana as well, although Costco regular is 87.
From what I understand, the lower the octane, the more horsepower. Win!
'95 993 C4 Cabriolet
Bunch of motorcycles
Old 07-12-2013, 09:37 AM
canna change law physics
red-beard's Avatar
nope
James
Red-beard for President, 2020
Old 07-12-2013, 09:43 AM
Registered Abuser
MT930's Avatar
They used to water down the beer as well ?
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 07-12-2013, 09:58 AM
red-beard's Avatar
Coors light IS water...
James
Old 07-12-2013, 10:03 AM
Max Sluiter
Flieger's Avatar
Fuel with lower octane rating does have a greater heating value than higher octane according to the Bosch book, but "gasoline" varies a whole lot, especially from continent to continent- like Europe to US to someplace like Africa.
However, if you use lower octane in a car that needs high octane it will change ignition timing and maybe even valve timing if it is new enough and that will decrease efficiency and counter the extra energy you get so that your milage doesn't get any better. the higher compression ratio allowed by higher octane will make up for the lesser energy density (unless you use something like Methanol which is about 1/2 the energy density of average gasoline).
Old 07-12-2013, 10:10 AM
Functionista
Not entirely correct. Higher octane stuff is more resistant to uncontrolled combustion events, ie detonation. More fuel economy might be had using lower octane but each engine might be different in what it "likes."
Jeff
74 911, #3
Old 07-12-2013, 10:11 AM
Liberal Prawn
foxpaws's Avatar
I believe that is an insult to water....
Old 07-12-2013, 10:27 AM
red-beard's Avatar
Poppycock!
Conventional Gasoline - about 87 octane
116090 BTU/GAL
"White Gas" aka Naptha, about 70 Octane
116920 BTU/GAL
MTBE
93540 BTU/GAL
ETBE
96720 BTU/GAL
Ethanol
76330 BTU/GAL
Hydrogen Data Resource Center: Hydrogen Calculator
petroleum refining : Octane rating -- Encyclopedia Britannica
James
Old 07-12-2013, 10:45 AM
Max Sluiter
Flieger's Avatar
Gasoline,
Regular: 0.720-0.775 kg/liter 41.2-41.9 MJ/kg
Premium: 0.720-0.775 kg/liter 40.1-41.6 MJ/kg
Bosch Automotive Handbook, 7th ed. page 331
Old 07-12-2013, 10:49 AM
Functionista
@red-beard
Yes, but you are misconstruing things a bit. More ethanol content or octane percent allows one to run higher compression all things being equal.
Jeff
74 911, #3
Max Sluiter
Flieger's Avatar
@red-beard
Ethanol is an octane enhancer, but an octane rating is an octane rating. If you have 87 octane pure gasoline you will have greater energy content and therefore better milage than 87 octane E10 but the engine will still knock at the same compression ratio and therefore will have similar thermal efficiency.
Old 07-12-2013, 10:52 AM
