Well......if someone wants to get serious about this concept I would tell them to call Obama. No doubt he'd throw a quick $250M at it....even if it's destined to fail....
10 E92 M3 13 Jeep GC Limited 98 Jeep Cherokee 87 951 C3 Stingray |
Exotic Vehicles are here
"Y" <- My favorite question... + '68 911 + Helping your business to get more business: http://myWWWapp.com Last edited by 1-ev.com; 11-04-2013 at 08:48 AM.. |
1966 - 912 - SOLD
The ADA will insist on making the tube bigger to accomodate the fat people-
then there will be that one fatie that doesn't quite fit and then it will be shut down due to non compliance- and the fattie gets a check for their inconvience-
i was too tired to be pretty last night! |
Brittle system. Elegant in theory, very little tolerance for malfunction. That is my overall impression.
Banned
You Obama haters should confine your posts to PARF.
It'll be legen-waitforit
Ok I did read the whole thing and great Alpha draft. There is still so much to figure out, but I like the open source Idea where can I download alpha 0.1
![]() I don't know if I would say the engineering sound until it's tested, but his people have done their homework. Still WAY more to do on the safety and recover side, and I am still thinking not everything environmental (external to the tube) has been taken into affect, but hopefully some retired NASA engineers and other people that have actually accomplished things will add to the effort and make it viable. I would recommend he go to a smaller trial system strictly for cargo to start, then take the lessons learned from it, the UPS or Fedex tube for example. At least someone is thinking outside to normal parameters...
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
canna change law physics
A little research into the "air bearings" which really should be called air casters.
Air Caster Floor Specifications and Floor Requirements for SOLVING Air Bearing material handling equipment. Floors for Air Casters For these to work properly, the inside of the tube, after welding, will need to be honed. 2% of the diameter of the bearing. Since the bearing is 3.5' x 4', the effective diameter is A=pi(d^2)/4 or d=sqrt(A*4/pi) = 4.22. Honing will need to be to 0.085" on an 88" tube. That is pretty darn close tolerance. This is +/- 0.1%. Metering tubes for measuring flow accurately are +/-0.25% for just the first pipe diameter. An alternative to metal honing would be coating the inside with an epoxy compound and then honing that. Again, extreme tolerance are required to make the air caster work. http://www2.emersonprocess.com/siteadmincenter/PM%20Daniel%20Documents/Meter-Tubes-DS.pdf 0.005" inches.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Regenerated User
No one hates Obama, but we all know he is incompetent to hold that office. He should be in Hollywood co-hosting a morning show with Kelly Ripa. We'll wish him well when gets there.
My uncle has a country place, that no one knows about. He said it used to be a farm, before the motor law. '72 911T 2,2S motor '76 BMW 2002 |
AutoBahned
the entire inside of the tube, after welding, will need to be honed??
Doug, go to PARF. Good bye.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
The energy cost to heat all the water, run a big enough suck machine and other control functions for this 'tube" will be staggering......where are the cost savings ?
Edgar 1984 Porsche 944 bone stock 1995 Mercedes E320 wagon 1970 Honda CB350 mint!!! |
You'll have to have expansion joints at, say, every pylon...
What happens when an air bearing encounters a spot that is not to those specs? Let's say a small dent or ripple in the tube, a weld that wasn't completely ground down or that cracks, or the deformed hole left by a rifle bullet? Does it make a difference that the bearing is traveling at 800 mph?
I'm imagining a situation where the 800 mph bearing hits a local deformation in the tube, and rips the tube like a fish being gutted. |
B58/732
I say we just build a giant air hockey table and load people up onto pucks that will bounce between LA and SF.
ΜΟΛΩΝ ΛΑΒΕ I don't always talk to vegetarians--but when I do, it's with a mouthful of bacon. |
Not surprisingly, other people/companies have introduced improvements on the idea. This one addresses some of the tube & welding issues:
Autodesk's Idea to Knit the Hyperloop Out of Carbon Fiber - Businessweek
Silver '88 RoW Carrera Grey '06 A4 Avant |
I see you
Six Flags might want this!
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Information Junky
I think that the producer of this vid read this thread. ...and added a few items.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Cars & Coffee Killer
Hyperloop's biggest problem is that it is lead by a charlatan who consistently overpromises and underdelivers.
Some Porsches long ago...then a wankle... 5 liters of VVT fury now -Chris "There is freedom in risk, just as there is oppression in security." |
Unregistered
Elon musk's greatest talent is showing us how to spend our money.
If he wants to use HIS money (only), then I will support his hyper-loop ideas completely. If he is once again trying to tell us how HE should spend our money, then he can go pack sand. |
