techweenie's Avatar
Porsche going all-Turbo?
That's the rumor - future 911s...
YouTube
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 10-21-2014, 10:51 AM
Checked out
McLovin's Avatar
Video link didn't work.
But an all turbo lineup would not be surprising, it seems like the future for many car companies.
BMW is pretty much already there. All 4, 6, 7 series BMWs are now turbo'd. All M cars are turbos. And most of the 3 and other series, too.
Old 10-21-2014, 10:56 AM
techweenie's Avatar
Try this.
1969 coupe hot rod
Old 10-21-2014, 11:01 AM
canna change law physics
red-beard's Avatar
I think it could make sense. Smaller engine in the lower priced vehicles, reduce weight.
James
Red-beard for President, 2020
Old 10-21-2014, 11:15 AM
All Porsche 911s to get turbos in 2015? - Autoblog
I love you guys outside this forum
-Eric
techweenie's Avatar
'Lower priced' being in the $90K range...
:-0
1969 coupe hot rod
B58/732
BlueSkyJaunte's Avatar
Since they're owned by VW, and VW has more turbocharged vehicles on the road than any other manufacturer, it makes sense.
ΜΟΛΩΝ ΛΑΒΕ
Old 10-21-2014, 11:22 AM
:-0
And 'reduced weight' being in the 3000lb range #porkche
1960 356 Super 90 - EFI'd
1989 190e 2.6
1991 964
Old 10-21-2014, 12:07 PM
winter-hater club member
nynor's Avatar
last i checked, the 911 was in the 3400 lb range.
"COOL PRIUS!" - Nobody Ever
Old 10-21-2014, 05:26 PM
Slackerous Maximus
HardDrive's Avatar
I don't see anything wrong with it. If their base model become a turbo 4....then yeah. Me no likey.
2014 Cayman S, PDK
Old 10-21-2014, 05:55 PM
Anywhere from 3042-3500 depending upon options, and that includes the turbo which is the fat bastard of the group.
Old 10-21-2014, 06:00 PM
Whats wrong with a Turbo 4? If it packs the same whallop as the old 6? I'm pretty impressed with the new turbo 4 cars floating around.
I bet the Focus ST with its turbo 4 would surprise you.
Old 10-21-2014, 06:29 PM
Slackerous Maximus
HardDrive's Avatar
I don't need a reason! I'm a grumpy old cuss, thats why! Now leave me alone whipper snapper.
2014 Cayman S, PDK
Old 10-21-2014, 06:31 PM
Bill is Dead.
cashflyer's Avatar
6>4
Old 10-21-2014, 06:43 PM
Did you get the memo?
onewhippedpuppy's Avatar
I'm yet to experience a 4 that feels as good as a 6. It's much harder to dampen the torsional vibration of a 4. BMW replacing their super smooth straight 6 with a turbo 4 in some models was an epic fail for enthusiasts. Go compare a Subaru flat 4 and a Porsche flat 6 and get back to me. Power output is just one small part of the story.
Old 10-21-2014, 07:21 PM
True Matt. But in the days of being required to increase fuel efficiency... Some tradeoffs will be required.
And I'm surprised how quiet the ecoboost on my escape is. several times now I have hit the start button twice because it didn't sound or feel like it was running...
Old 10-21-2014, 07:38 PM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Last year didn't Porsche bragged about how they were able to achieve remarkable performance both off the line and top end without having to go turbo?
No matter, I think it the right thing the do and while your at it super charge the line as well!
Michael D. Holloway
https://5thorderindustry.com/
Old 10-21-2014, 07:48 PM
Max Sluiter
Flieger's Avatar
And yet, when you add the extra 2 cylinders suddenly your crankshaft has torsional vibration problems... even Aston Martin couldn't make an inline 6 work at Le Mans in the LMP class. Flat 6 crank is a little shorter and stiffer than an inline 6 so Porsche has done well, but remember the first long stroke ST's and RSR's? And the 917's central PTO to get around the vibes?
Boxer engines have no net reciprocating forces since each piston cancels the other, but they do have moments which don't cancel from the opposing forces. A boxer 6 has only 6th order and higher moments, so very small, boxer 4 has 2nd order and higher moments, which is not as bad as the 2nd order forces that cause an inline 4 to bounce. Boxer twin has net primary moments, so kinda big, but since it is a moment you can more easily dampen it with widely spaced, soft mounts.
Bottom line is that a boxer 4 strikes a nice balance between, um, balance, and a rigid crankshaft, which allows higher rpm and more boost.
Old 10-21-2014, 08:21 PM
Max Sluiter
Flieger's Avatar
I will say that nothing sounds as good as a 911 flat 6. Well, maybe a 917 or a Ferrari V12.
The question is whether it is worth the extra hundred pounds for the sound, and whether you are going to make full use of the extra cylinders to get 50% more power.
Old 10-21-2014, 08:22 PM
I look at it as Porsche going back to their roots... don't forget the first 15 model years were 4 cylinders.
1987 535is, 1966 GTV, 2015 F-Type R, 2013 991 C2, 2011 E550c, 2007 997 C2S, 1987 911, 1958 356 1600s, 1956 356 1600s
Old 10-21-2014, 08:33 PM
