Team California
Oil pipeline questions, not political:
Since I pay shockingly little attention to the whole Keystone Pipeline imbroglio, I know very little about oil pipelines. I know that oil moves through them, that's about it. Would the KXL be above ground or below? Combination? How deep, if buried? I would imagine that it has to be underground at least partially, it can't be barren farmland all the way from Alberta to Nebraska, though it mostly is for sure.
Do they have to go out and buy the land rights from each and every land owner for 1200 miles to install it under their land, (or on top of)? What if someone says no? Could one hold-out snafu the entire thing? Sorry for the (probably) dumb questions, and yes, I'm aware that there are millions of miles of pipeline already installed in the U.S., so these are general questions not only for the KXL, other than that is the only big oil pipeline project at the moment. Also, I assume that there are large shut-off valves every so many miles, (how many), in order to stop the flow if there is a leak? Is that what the small number of permanent jobs created by its construction include? Sort of night watchmen who will sleep for the next 30 years unless it bursts and they have to man the switch/valve? Like I said, I know nothing about these things. The questions are serious, if dumb. TIA.
Denis |
I'm sure eminent domain comes into play for most of the land. But I hear one indian reservation is making a fuss and it will require a serious reroute to bypass them. I don't think eminent domain works with indian reservations.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
The Unsettler
Eminent domain is useless. It would be analogous to Canada claiming eminent domain on our side of the border.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
The answers to most of your questions will simply be "yes". It will be both above and below ground. The depth will vary depending on soil and ground water levels and a myriad of enviro entail laws.
It is a continuing job for thousands to keep a pipeline running. From the pump stations to cleaning pigs and security. Imbeciles like to shoot at pipelines for some reason. It's all a huge undertaking that only makes sense when compared to transporting it by rail. |
It's hard to find objective information, as the pros and antis have competed to yell the loudest. This is a pretty good overview of some of the issues: Keystone XL Pipeline | StateImpact Texas
I have some of the same questions you do. As to eminent domain, the states it is running through apparently are letting corporations condemn and seize private land for the use of the pipeline company. In my view that is a horrifying prospect, but it isn't new. There has been a lot politicing over this, but not a lot of objective educating of the public.
Banned
basic supply vs demand
less domestic oil if more is exported by this pipeline good for oil corpRATs bad for drivers |
TransCanada CEO says 42,000 Keystone XL pipeline jobs are 'ongoing, enduring' | PunditFact
Team California
I don't want to read the answers in PARF, interspersed with pages and pages about "corprats" and "*******s". Please go away. |
Politifact? Seriously?
Half my town is employed on the pipeline. The other half fish. We have engineers, welders, chemists, hydrologists, machinists, pilots, drivers, geologists and a host of other professions. Most are contractors working for oilfield services companies. There are a dozen small time haliburtons around. They may not meet whatever criteria politifact used. But they're still employed. |
our family has some land up near the red river (texas side) been in the family over 100 years, no one lives there anymore, but we have a natural gas pipeline that runs across the property, I know we get payed for the pipeline not sure how much, we have an attorney that manages the property.
The Keystone pipeline in Oklahoma is done and completed. It goes from Cushing, OK to the border with Kansas. Cushing, OK is the largest oil storage facility in the world.
3 Impressive Storage Tank Facilities » Castagra
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
canna change law physics
1. Below ground, except where control and pumping equipment come into play. Below the permafrost line, so it varies.
2. Usually they pay "rent" to a landholder. Eminent domain comes into play, but usually they try to negotiate before that happens. It gets costly in court for both side. ![]() 3. Not just shutoff valve but pump stations. And all of this infrastructure needs to be maintained. And the equipment gets sent out for repair. Lots and lots of jobs doing all of this.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
The oil is already coming south. At present it is being transported by rail car. This is much more expensive and much more dangerous than using a pipeline.
Here is the Alaskan Oil pipeline from Prudhoe Bay to Valdez. 800 miles and used up to 12 pumping stations. With the reduced oil from the area, only 5 are needed now. I expect the KXL will need more stations for the same distance since the oil is much more viscous. It will also need to be heated periodically.
RIGZONE - How Do Pumping Stations Work?
hi Denis.
max
max |
Targa, Panamera Turbo
I remembering reading that the temperature of the crude is elevated to increase flow. Not sure if that is true or not - would seems that the pipe would need serious insulation over thousands of miles of crude. Plus the energy required to heat it would be high - then again the energy to pump it is high.
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
Specific heat is about 1/2 that of water, 0.51 BTU/lb-deg F
"On ABC’s This Week, host Martha Raddatz quizzed the leader of the company that wants to build the pipeline, TransCanada CEO Russ Girling, about the project’s job creation potential. Girling cited TransCanada’s estimates for 9,000 total positions, and Raddatz countered with estimates from the U.S. State Department, which is tasked with a recommendation on the project to President Barack Obama because it crosses international borders. "There are others who say the jobs will not be so great, going as low as 4,000 jobs, and that the jobs will only be here for a couple of years," Raddatz said. "The State Department, you mentioned the State Department, says that once the proposed project enters service, operations will require approximately 50 total employees in the U.S." Girling conceded that actual operating jobs top out at 50 ..."
Unregistered
It is illegal for domestically produced oil to be sold overseas. Any Canadian oil that gets shipped by this pipeline will reduce the price of oil in the gulf, further benefitting consumers. The keystone pipeline will increase domestic supply and drive down prices to the consumer. It will pretty much eliminate the influence of foreign producers like OPEC. it's what we've always wanted, a way to tell the middle east producers to take a hike. Energy Independence. It will also reduce profits for most oil companies as supply increases and oil prices drop. There are already a whole bunch of pipelines in the us, almost ALL are underground. The only reason the trans-Alaskan pipeline was above ground was because of permafrost. ![]() And all it takes is a grant of easement onto a property and a potential fee for temporary loss of use and a noninal rent agreement. They dig a trench, lay the pipe, fill in the trench, and you'll never know it's there. modern pipelines are protected with serious instrumentation that can detect and stop a leak. They have all sorts of electronics that monitor corrosion, thickness, integrity. They send "pigs" down the line periodically that inspect the pipeline as they go through, taking measurements and pictures. It's pretty high tech. There are booster pumping stations all along the route with isolation valves. Last edited by sammyg2; 11-18-2014 at 02:44 PM.. |
