Bill Douglas's Avatar
car battery question
My Corolla is meant to have a cca (cold crank something..) 330 battery. Will a cca290 battery be OK. I know it will go flat quicker, but will it stuff the car's charging or other eletronics? thanks
Old 04-07-2015, 03:14 PM
300hp 1800lbs is the goal
pksystems's Avatar
I hope that is for a warm weather car. My DD battery has 750 CCA
CCA (Cold Cranking Amps) is for winter starting.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 04-07-2015, 03:22 PM
I believe the "a" is amperage.
I personally wouldn't go below the recommended amperage, but others may disagree...
Guy
'87 944 (first porsche/project car)
If it is a high mileage car and you live in a hot climate you should be fine with a CCA that is less than recommended.
Old 04-07-2015, 06:11 PM
Thanks Paul, thanks Guys. It's an old Corolla so doesn't need much to spin up the starter motor. Plus it gets driven fairly much everyday.
Old 04-07-2015, 06:40 PM
Did you get the memo?
onewhippedpuppy's Avatar
Agreed with the others, probably ok in moderate weather. Nothing is harder on a battery than cold weather.
‘07 Mazda RX8-8
Old 04-07-2015, 08:15 PM
CCA= cold cranking amps. I would not scrimp on a battery..
Old 04-07-2015, 08:50 PM
A higher CCA battery will have more starting strength in the cold months. My diesel truck has TWO 1150 CCA batteries.
Old 04-08-2015, 04:59 AM
T77911S's Avatar
correct. although i dont know how much more CCA you need in the winter. yes the engine will be harder to trun over but the bigger problem is what the cold does to the battery itself. pull up a tech sheet on a battery. on the one for one of my UPS's the float voltage goes from 2.27v percell at 77 degrees to 2.29v per cell at 68 degrees.
a lower CCA does not mean it will go dead sooner. think of it as power that the battery can put out. does your car require 330A everytime it starts? probably not.
although 330a is pretty small for a car battery. most are in the 6-700 range at least.
i usually just buy cheap advance batteries these days. i dont know if you are really getting your moneys worth out of a more expensive battery now.
exception. a lot of new cars "require" a certain battery like my mercedes. perhaps it is due to the internal resistance.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 04-08-2015, 09:41 AM
Thanks Guys. It doesn't get too cold, or too hot, around here Matt so I think I'll get away with it. Yep, a cheap one is good. I don't want to buy a battery that is worth more than the car
Old 04-08-2015, 12:44 PM
You do not have permissi
john70t's Avatar
Batteries and tires should be the very last thing to scrimp on for a few measly extra bucks.
The rest of toyota will last forever. Guaranteed.
Old 04-08-2015, 10:17 PM
