Any ideas on an AC vent that doesn't stay in position?
My 1986's left-most dashboard vent flops closed a few moments after I aim it where I want. It's a killer b/c that vent is one that can aim the AC right on the drivers face.
Is there a way to tighten the preload or something on it so the louvers stay where they are put? I'd buy another if I had to... how are they removed?
Ken
1986 930 2016 R1200RS
Old 06-19-2015, 09:14 AM
1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Super glue ?
Old 06-19-2015, 09:19 AM
Did you get the memo?
onewhippedpuppy's Avatar
Glue would work if you never wanted to move it. Are they still available new? I think they just snap in from the front. Most of the time it's a plastic vent guide mounting into a plastic frame and they just get loose with age.
‘07 Mazda RX8-8
Old 06-19-2015, 09:40 AM
Eva
911SauCy's Avatar
No glue...
Grab some clear silicone, yes like tub and tile kind, and strategically place a little pearl of it on a solid surface but where the mobile part of the vent passes by. This will fill a bit of a gap, give the moving part of the vent some friction so it will stay in place and it won't always be stuck in the same position.
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 06-19-2015, 09:46 AM
Use a toothpick to hold it open. Paint it black. Tell people it's from the Black Forest.
Old 06-19-2015, 10:21 AM
A930Rocket's Avatar
I super glued mine.
Old 06-19-2015, 03:16 PM
I stuck an earplug in one of the holes on my work truck, works like a charm, holds both the horizontal and verticle flaps. Probably not the look you're going for though.
Old 06-19-2015, 08:02 PM
Little foam plug or cut a C shaped piece to hold it one position.
Old 06-20-2015, 09:09 AM
Try black dental floss. Tie it around one of the pivots. You need to create friction against the slats.
Old 06-20-2015, 11:29 AM
RETIRED
Joe Bob's Avatar
Cram a match book cover with into it a condom stapled to it....
2012 ML350 3.0 Turbo Diesel
Old 06-20-2015, 01:18 PM
Leadfoot Geezer
rcooled's Avatar
Put a drop or two of blue Loctite in each of the pivot points...use a toothpick to apply it if access is limited. Once dry, it'll provide just the right amount of friction to hold the vent in any position.
'13 BMW 335i coupe - current DD
Old 06-20-2015, 01:55 PM
911 enthusiast
tmadden2's Avatar
I used two little pieces of rubber trim, both cut about 1/16" too long to keep a little lateral pressure. Been holding great for two years now with no adhesive.
Old 06-20-2015, 06:39 PM
Felt tape on the inside wall.
Old 06-21-2015, 03:22 AM
Go-Kart Mozart
JAR0023's Avatar
I tried that and it didn't work. What did work was about and inch or two of a black zip tie. The clamp end keeps the zip tie from falling into the vent. Gimme a few and I may can come up with a photo. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 06-22-2015, 05:50 PM
Platinum Member
dad911's Avatar
Did you actually try this? I've seen locktite ruin plastic in other applications.
Old 06-22-2015, 06:03 PM
Go-Kart Mozart
JAR0023's Avatar
Zip Tie
86 Carrera
H. L. Mencken
Old 06-22-2015, 06:05 PM
