220 Volt or 110 Volt Spa
Wondering what is the better?
5 person hot tub spa |
Detached Member
220 if you have it. Cheaper.
Hugh |
Don't even think about a 110. Even the 220v ones vary with 20,30, 50 amp models.
A 110 is enough for a bath tub. If you want it to heat or and have multiple jets alternating between the two, you need a 220 30 amp. If you want it to heat and jet at the same time, you need a 50 amp. We got a top of the line one free from a neighbor for the cost of moving it. He couldn't sell a $10,000 new, 10 year old now, jacuzzi for next to nothing. Go on Craigslist, these things are dirt cheap. Mover was $400. Bo |
"220, 221, Whatever it takes."
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
220 is the way to go given the choice |
The model I have autos elects based on available amperage. I ran 220 30 amp as that's all my electrical panel could handle...
Don't forget to include the cost of rewiring your panel to feed the spa. It was $800 in material alone... And it was a bear to run as the house was already drywalled at the time.... |
abit off center
480 3 phase and you will get a fruit basket every Christmas from San Diego Gas & Electric®
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Edministrator
Just make sure it's grounded properly...
Good post? Leave a tip! O - $1 O - $2 O - $3 |
With a ground fault detector. Lots of places in the house they are overkill, in a spa they are needed.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Dog-faced pony soldier
If you have to ask...
Seriously - a 220 circuit is simple and easy to do.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Seen on Craigs list, 110 volts,will match the colors of the back yard. So my wife wants it. Just asking about the pros and cons of the differing voltages, kind of liking the plug and play idea of it of course I would plug into a Gfi I outlet.
The cons on a hot tub are your wallet.
Well if it's 110 volts with a pump and heater, there will be no risk of the water getting too hot....or else you need to install an 80 Amp breaker.
83 911 Production Cab #10
I got a 2 persons 1000 litters (~250 US Gallon) the can be on 110V or 220V.
Being the King of Procrastination, after 8 years its still on 110V. The only thing when on the 110V option is when you put the pump on high the heater stop. I keep mine at 104 F (heat up to 105 F) and at -25 F, it will go from 104/105 F down to 102 F in the 20 minutes high pump cycle which is exactly the time it take to drink a 500ml beer.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Thread Tools | |
Rate This Thread | |
