Kraftwerk's Avatar
How to remove these center caps?? (Sparco)
Okay, so I have a 'car', temporarily that I am going to sell and keep the wheels.The previous owner gave me a tiny little piece of bent mental/tool he said you will need this for the center caps. He is difficult to reach these days, due to his new distraction GT4!! (--Porsche content!) So how the hell do i get the center caps off the tool seems more like a key.. and there is a tiny hole where it fits. Its the size of a tooth-pick and rather flimsy.
The wheels are sexy as-f. and not made anymore in this center - cap configuration: Sparco Rally wheels, I think they are called.. check em:
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 12-19-2015, 01:53 PM
The Unsettler
stomachmonkey's Avatar
They are just held on with clips.
Put the tool in and gently pull.
"I want my two dollars"
"Brandon Won"
Old 12-19-2015, 03:01 PM
Kraftwerk's Avatar
yeah the tool bent when I tried that.. the tool is really tiny and thin metal ... will try again have you personal experience with these? Thanks..
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 12-20-2015, 08:36 AM
Wilywilly's Avatar
I had some centercaps on a set of after market wheels which had a real small ex head set screw in them to keep the caps on. Is the tool a tiny allen wrench. If so try it that way
Bill B.
63 Little B Coupe
67 SWB 3.63 Hotrod
08 Cayenne S
65 F100
Old 12-20-2015, 09:15 AM
Hell Belcho
Nostril Cheese's Avatar
Set screw most likely.
Did these come off a Ford Focus?
Old 12-20-2015, 10:45 AM
Kraftwerk's Avatar
Here is a picture of the 'tool' I was given to remove center - caps.. it bent when I used it as a mini-pry bar.. there is a small slot in the center where this tool fits.. but nothing inside the hole to 'unlatch'. It remains a mystery.. Wheels are on an MX-5.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 12-24-2015, 02:23 PM
I haven't had experience with that exactly, but 10:1, if you put it in the right way, I suspect it would push a spring bar of some sort. Can you get a better closer shot of the wheel/center cap?
Old 12-24-2015, 03:38 PM
Cory M's Avatar
If tool doesn't work, take wheels off car and pop caps off with a piece of wood and a mallet. Put a towel on the ground or get a helper so the caps don't get scratched on floor when they come out.
Old 12-24-2015, 04:19 PM
THat would be a great suggestion for regular center caps, but if you look at the picture, the center cap in question cover's the lug nuts. I suspect it's hard to get the wheel off without first removing the center caps.
Old 12-24-2015, 05:31 PM
Eric Coffey's Avatar
I would think they are just held in with spring clips as well, and maybe just stubborn due to dirt build up.
Or (and it's probably a long shot), the center cap might have locking tabs and lock into place via rotation. You might try putting the tool in a see if you can get the cap to move CW or CCW to "unlock".
Old 12-24-2015, 06:04 PM
Cory M's Avatar
In that case, drive the car until the tires go flat, and leave it where it stops.
Old 12-24-2015, 06:19 PM
Driver, not Mechanic
If it doesn't move and it should, use WD-40. If it moves and it shouldn't, use duct tape.
Old 12-24-2015, 06:30 PM
Kraftwerk's Avatar
^ I am leaning towards this suggestion.... ^
But I will have a closer look at it after the holiday. Thanks guys.
jt
'83 SC
'96 M3
6 Bicycles
2 Sailboats
Old 12-25-2015, 08:50 AM
I know that reading the instructions is a last resort. But why not contact Sparco for their input.
Cheers Richard
Old 12-25-2015, 10:03 AM
So funny. If you Google 'sparco center cap removal', the first result is a YouTube video, and the second and third ones are your threads, one in the Miata forums and this thread. Hehe.
Old 12-25-2015, 10:06 AM
patz's Avatar
Take the wheel off, stick the back end the mallet or two inch wooden dowel into the back end of the cap. Give it a whack with another mallet.
Old 12-25-2015, 11:10 AM
The Unsettler
How do you suggest he gets the wheel off?
"Brandon Won"
Old 12-25-2015, 11:50 AM
patz's Avatar
Ahhh, the pic didn't come thru on my monitor. Sorry.
Old 12-25-2015, 12:06 PM
Un Chien Andalusia
Aerkuld's Avatar
No experience with those wheels, but I have exactly the same type of tool with my OZ wheels for the center caps. With those I just hook the tool behind the center cap and pull - the center cap is just held in with spring clips and it pulls straight off.
I hope that helps . . .
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
Old 12-25-2015, 12:31 PM
Un Chien Andalusia
Aerkuld's Avatar
If the above doesn't work you'll have to use the sawzall
Old 12-25-2015, 12:32 PM
