A Roto-rooter type services will also be able to run a camera down the line and see what the problem is. The shower is backing up because it is the lowest drain in the system. If there is a blockage it backs up to the shower first. Call a pro.
Old 12-29-2015, 12:47 AM
?...Call a pro.
This....I have a 25' snake, but if that doesn't fix it, then I make the call. NEVER seen a pro pour anything down a drain either....YMMV
Old 12-29-2015, 02:17 AM
creaturecat's Avatar
Is there a clean-out somewhere?
If so, run a snake down it.
Have you already tried a plunger at the shower drain?
Old 12-29-2015, 02:18 AM
Don Ro's Avatar
Just tried a plunger - LOL, it's 4:30 AM here 'n I'm up early trying to fix this deal.
Water hasn't budged after using the plunger.
Clean-put is just a few feet from the back of my house.
I'll look for my snake and do what I can prior to calling in a plumber.
I'd sure like to hammer this down on my own...kinda enrolled now.
You guys are teaching me about it all.
Thanks gents
Don
"Fully integrated people, in their transparency, tend to not be subject to mechanisms of defense, disguise, deceit, and fraudulence."
- - Don R. 1994, an excerpt from My Ass From a Hole in the Ground - A Comparative View
Old 12-29-2015, 02:37 AM
Bland
unclebilly's Avatar
A couple things...
As was mentioned, the blockage is likely between your house and the curb. The reason it comes up in your shower is due to technology developed in the last 2-3 years (Gravity)...
I have never been to your place but I'm pretty sure your shower drain is 2-3 feet lower than your sink drain. Because you have a blockage between your house and curb, the water from the sink flows downhill (this is how gravity works) and since it can't flow out to the sewer line as fast, flows back up your shower drain.
You are lucky you caught this and don't have a bath upstairs.
Likely the problem is roots getting into your sewer line.
A cheap alternative to getting the camera services out is to buy a 30' USB camera off of Amazon or eBay.
Something like this: DBPOWER 2Million Pixels 5M USB Waterproof HD 6LED Borescope Endoscope Inspection Tube Camera these are $22 for example.
We used one to sort out this exact problem at my dad's place 3 years ago. The roots from his grape vines had grown under the house and got into a 4" PVC coupling and were causing the blockage. Rotorooter had angered it out for him. We were able to use the USB camera to precisely find the trouble spot, cut the concrete slab in his garage, dig down the 2-1/2 feet, and repair the coupling with a Fernco and then fill in the hole with concrete.
Old 12-29-2015, 03:26 AM
Don Ro's Avatar
You speak with straight tongue, billy.
Makes sense to me...it will get handled soon.
Thanks!
Don
Old 12-29-2015, 03:30 AM
Bland
unclebilly's Avatar
A plunger won't do anything, your house has a vent stack that vents the sewer line to the roof. When you plunge all you are doing is pushing against atmosphere up the vent stack. Not the blockage between the house and the curb.
Old 12-29-2015, 03:34 AM
Bland
unclebilly's Avatar
The other thing is that getting the roots removed is only a temporary fix because in 6 months to a year, they will grow back.
Old 12-29-2015, 03:36 AM
Don Ro's Avatar
The Borescope Endoscope you suggested sounds decent with a sane price.
Just a bit limp-dicked, however.
Have to come up with a guide wire of some sort if I go for this unit.
Thanks, again.
http://www.amazon.com/DBPOWER-Waterproof-Borescope-Endoscope-Inspection/dp/B016DEZI8U
Don
Old 12-29-2015, 03:43 AM
Bland
unclebilly's Avatar
We were able to slide that bore scope into the clean out at my dad's place without issue. You can have it connected as you run it in and twist the wire as needed to slide it in because you can see what is going on. We connected his to a laptop.
A speedometer cable might be good to stiffen up the wire if needed.
Old 12-29-2015, 03:49 AM
VincentVega's Avatar
Around here you can rent the camera snake but its not $20. Great feature is the distance meter on the machine, then you can pinpoint exactly where the blockage is w/o handling the device.
Old 12-29-2015, 03:53 AM
Don Ro's Avatar
"Great feature is the distance meter on the machine,..."
Do you mean on the borescope unit/program itself?
The unit/program will give distance?
Don
Old 12-29-2015, 04:04 AM
yes, you'll see something like this
nothing like busting up concrete only to learn you are 2' off and need to do it again.
good luck
Old 12-29-2015, 04:08 AM
Bland
unclebilly's Avatar
The cable doesn't stretch but is can helix as you push it in. The key is to watch the camera when you pull back. When the camera (end) starts to move put some tape on the cable at this point, this it the straight cable length to the camera.
Alternatively, tape a tape measure to the cable. This will give rigidity to push it in and a length measurement.
Old 12-29-2015, 04:19 AM
Don Ro's Avatar
I have a 35' tape measure that I could cannibalize.
Tape may be too flimsy.
I do have some flat 1/8" wire that might do.
You guys are great...
Don
Old 12-29-2015, 04:31 AM
Originally Posted by Jim Bremner View Post
pour in 2, 2 liters of coke. let it sit over night and flush.
I thought coke was sold in kilos not liters. That is a lot of blow.
Old 12-29-2015, 04:50 AM
non-whiner
mreid's Avatar
Put the camera on the end of your snake or a wire fish. It will be plenty rigid and much easier to control.
"Too much is just enough."
Old 12-29-2015, 05:09 AM
You do not have permissi
john70t's Avatar
Sump at a lake cottage backed up.
Turned out to be 8ft of tree roots. PVC sections were not glued together.
Condo building backed up.
Poop water coming out of toilets on the first floor.
Turned out to be the cast iron main was peeling internally.
House backed up.
Turned out to be a couple hundred lbs of tp caught in a small bubble of orangeburg pipe.
Ran a 50ft snake in the wee hours, but the clog was a few feet past that.
Rotorooter un-jammed that and did a scope.
Old 12-29-2015, 06:30 AM
Tis the season......for plumbing problems, I guess.
My shower drain is leaking. It is in the overhead of the garage, above the textured drywall.......a fine mess. Soaked thru the sheet rock & dripped on my truck......I'm calling a pro.
JPIII
Early Boxster
Old 12-29-2015, 06:54 AM
ted ted is online now
likes to left foot brake.
ted's Avatar
I would avoid the snake and get a plumber with a trailer type jetter.
The more powerful jetters are $20k+ and do a better job cleaning the inside of the pipe.
Then have him repeat every few years.
Sewer Jetters: Key Facts You Need to Know | Spartan Tool
Old 12-29-2015, 06:57 AM
