LinkBack | Thread Tools |
Rating: ![]() |
That beastie would be a hell of a track car with a couple more gears. The Porsche crowd would be in for a shock......that is an excellent case for "Modern". He's pulling 380HP at the wheels for now (@ 2.0L) at (WAG) 1/4 the price of Porsche power.
JPIII Early Boxster |
Probably a good thing you took out 1st and reverse from your gearbox... JR |
I tried to do it "once" with a 901 box.....I got off gently. Your statement shows a lack of experience...... maybe OK in theory. I now have a Miata. That 6 speed is almost as slick shifting as a T-10. I've never driven a Porsche with the BW syncro set up.......and ,as a result, with hold opinions of them.
I just choose to treat my gearboxes, and everything else, like they should be treated. I don't drive (or ride, in the case of bikes) like a Neanderthal... I'm out of here, I think. Sugardude has his questions answered and I can't stand to listen to red-breard's acid trip again... JR |
gearhead
World's Lightest 930 Transmission
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
canna change law physics
Holy crap! The old transmission part prices are out of control. I remember complaining when sync band went from $20 to $40. Wow. Rebuilding a 901 will be mighty expensive these days.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
gearhead
Price a 1st/R slider for 901 or 5th/reverse for 915. Crazy expensive these days.
Checked out your site. Looks like you do have both clutch and torque biasing type. That's what I was asking, if you had an opinion/recommendation for an enthusiastically driven street car.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() Last edited by masraum; 05-18-2016 at 01:01 PM.. |
Sorry, but could you elaborate on how/why it narrows the gap? I would think the engagement teeth wearing down would increase the gap, unless you are saying the dog teeth make less contact? |
Almost Banned Once
- Peter |
A top notch product which, unobtrusively, dose it's job. Matt is now the HMIC there.
That's what I was thinking. My last car, turbo miata, had one, and it seemed to work well on the street.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
If you were to test how smoothly new engagement teeth plug into a new shift sleeve and compare this against the worn out parts, the difference is quite evident. |
![]() I refreshed my 915 over the winter, and was so damned proud of myself that I couldn't bear to just put it in the garage until it went in the car. Hoping to get the car buttoned back together this weekend, and I am REALLY anxious to see how it shifts. I've had the more typical Borg Warner style transmissions/synchros apart before and it is pretty intuitive when the parts are in your hand. However, even after having the synchros apart in my 915 transmission, I still don't really get it.
Jake Often wrong, but never in doubt. '81 911 euro SC (bits & pieces) '03 Carrera 4s '97 LX450 / '85 LeCar / '88 Iltis + a whole bunch of boats |
Here is a worn slider - Photo is nearly 15 years old!
The slider wear in two ways: 1) The sync band contact spreads metal, making the double pointed areas wider, making it harder for the dog-teeth to engage. And the pointed areas wear against the dog-teeth, rounding, usually because the sync band is worn and not making good contact. ![]() Sorry this first gear slider is a little out of focus, but you can see the rounded points. ![]() The dog-teeth are softer than the slider, so they wear out faster...
A good shot of a rounded, worn slider
![]() Here is my attempt to clean up a 1st gear slider in a 901. I used a file in between the grooves to bring them back to spec. Then I used a dremel to repoint the triangular area. At the time, 1st gear sliders were not just expensive, they were hard to find. A repointed slider with a good sync band and new dog-teeth restored function. ![]() ![]()
Differences between dogbox, dog teeth, syncho, 915, G50, modern gearboxes
Thank you both very much for the pictures and enhanced explanation. |
901 gear stacks before being put back in a transmission
![]() Some fun pictures - really broken stop blocks and brake bands ![]()
Thread Tools | |
Rate This Thread | |
