Sugar Scoops Rule :)
dave 911's Avatar
7 cubic yards of gravel - on the driveway or grass?
What thinks the brain trust? I'm building a paver patio in the back yard, and when I have the gravel delivered, should I have them dump it on the driveway or grass? I'm schlepping it with a wheelbarrow, and the grass would be ~50' closer, and I figure if i put a tarp down that should make it easier to clean up than if on the grass directly. Plus I would be concerned that the driveway (blacktop) may crack due to the weight....Pros / Cons?
Dave
_______________________________________________
'76 911S Targa
'62 VW Type 1 Sunroof
'73 914 2.0 (1st Porsche, gone long ago but not forgotton)
Old 05-15-2016, 08:19 AM
Do you care if the grass dies?
Old 05-15-2016, 08:31 AM
Non Compos Mentis
Grass grows back. I'd save the 50 feet. I'm good at finding ways to do less work.
With a tarp down, if you do it all in one day, the grass will be fine.
Old 05-15-2016, 08:33 AM
Non Compos Mentis
I can drive my pickup into my back yard. I'd get truck-sized loads and shovel it right from the truck. I'd rather move the gravel down once than up into a wheelbarrow and back down again.
No pile on the driveway, no pile on the grass, do a couple loads and call it enough for one day if I so choose.
Old 05-15-2016, 08:35 AM
Kantry Member
oldE's Avatar
How firm is the ground under the grass?
You may end up repairing ruts made by the truck.
Best
Les
Best
Les
Old 05-15-2016, 08:38 AM
Now in 993 land ...
aigel's Avatar
Much easier to shovel off concrete than a tarp sitting on grass! If flat and smith, it doesn't take much energy to push a wheelbarrow 50'.
No mods in my yard for this exact reason!
Have fun!
Old 05-15-2016, 08:47 AM
You do not have permissi
john70t's Avatar
Tarp on top of junk plywood?
Old 05-15-2016, 08:50 AM
Your blacktop/asphalt drive will have no prob with the weight of the gravel...less per sq. in than your car...del truck could be a prob. Shoveling off a tarp is no fun!
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 05-15-2016, 09:17 AM
Bland
unclebilly's Avatar
I have my own tandem gravel truck...
That is about half a tandem load of gravel. A tarp will be fine unless the ground is uneven, then the plywood under the tarp is a great idea. The load will spread to 10-12' wide and will be about 6-8' going the length of the truck.
The truck may rut your lawn (it is only a 1/2 load) and if he had traction issues, he may spin until he locks up his diffs (assuming the truck has lockers).
Old 05-15-2016, 09:46 AM
winter-hater club member
nynor's Avatar
7 yards by wheelbarrow. good luck. i had six yards of compost. it was an amazingly large amount of material to move by wheelbarrow.
"COOL PRIUS!" - Nobody Ever
Old 05-15-2016, 09:54 AM
fastfredracing's Avatar
I had a tri axle load dumped in my grass. I really regretted it . It was for a project, that took me a few weeks to complete , but it took me the whole season to get all the gravel out out of my yard. It made for a ton more work than needed to be
No left turn un stoned
Old 05-15-2016, 10:06 AM
I see you
flatbutt's Avatar
Save the 50 feet and your back but use a tarp. 7 yards is a lot bro!
Old 05-15-2016, 10:26 AM
I wonder how many of those who say "put it on a tarp"....have ever had to shovel up a pile of gravel "off a tarp"...even if it is on plywood. Blacktop with a flat shovel will be easy. Newer wheelbarrows roll easily..esp the dual front wheelers.
98 Honda Prelude
22 Honda Civic SI
Old 05-15-2016, 10:38 AM
UnRegistered User
billybek's Avatar
Will the truck have to back over irrigation pipe to drop the load?
I would put it in the driveway but then I don't have to do the work!
Bill K.
Old 05-15-2016, 10:43 AM
blacktop,flat shovel, 2 day laborers from Home Depot
1995 FZJ80, 1988 Toyota Pickup 4x4
Old 05-15-2016, 10:45 AM
LakeCleElum's Avatar
Bingo - Depending upon your wheelbarrow size (i.e. 2 or 3 cubic feet per wheelbarrow load), it will take 9 to 14 full loads to equal 1 cubic yard. The chart below shows how many full wheelbarrow loads it takes to equal the specified number of cubic yards. A 2 cubic foot wheelbarrow typically has a shallow basin.
Bob S.
73.5 911T
1960 Mercedes 190SL
Old 05-15-2016, 11:53 AM
canna change law physics
red-beard's Avatar
I had 7 tons dropped at the foot of the driveway. I spread that 7 tons one shovel at a time.
James
Red-beard for President, 2020
Old 05-15-2016, 12:09 PM
wdfifteen's Avatar
I'd dump it on the driveway and rent a georgia buggy, but I'm really lazy.
Old 05-15-2016, 12:15 PM
Make Bruins Great Again
Por_sha911's Avatar
Ask the folks you bought it from what they recommend.
Joe
Old 05-15-2016, 12:25 PM
