Information Junky
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Functionista
Nope.
Nowhere close.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
Where do we get all those precious metals for the fuel cells to replace the millions of engines produced every year?
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Exactly. Huge leaps in logic. It's like a reality distortion field surrounds the whole EV myth.
Make Bruins Great Again
"Dreams do come true, if only we wish hard enough." - Peter Pan
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
canna change law physics
Oh - on land based battery systems, one point I like to make to people is that lead is the most recycled substance, more percentage than aluminum. Lithium is not recycled. It is five times more costly to recycle lithium than to buy "virgin".
Advanced Lead-Acid may not be the right battery for mobile applications, but stationary it is.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Air Medal or two
Smoky Yunick took one to the grave
What Ever Happened To Smokey's Hot-Vapor Engine? - Hot Rod Magazine Besides his, there are at least a 100 more designs floating around.
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
https://ask.census.gov/faq.php?id=5000&faqId=5971 |
The problem with the above article is the heating is taking place BEFORE compression. This will further increase the temp and the compression energy in the cylinder. Most times to increase power, you want to cool the air before it enters the engine. Intercoolers are used on multistage compressors to reduce temperature and compression energy in downstream stages. It is a loser for fuel efficiency, but a winner for power.
We could drop down to one car (and even have it be EV) with the other options now available (rentals, zip, lyft). Only complication is gigging when I need to haul gear and if on the same night the wife needs the car. But probably a work around there as well. Gas is overkill for most trips I see people taking - except for those that live in the outskirts and commute 2 hours into town. I don't see how that is a thing, but the "American dream" of home (and car) ownership drives some people to extreme solutions. |
Ok, now the EV thing is making sense. It's not for me. I am not a hamster living in Zootopia. But if you are, then for you it's fabulous because you can recycle everything from the battery to your farts, which are fuel.
I just love the gas is overkill comment. W-O-W. |
Almost Banned Once
A futurist recently predicted that the person who worked out how to do this would be the worlds first Trillionaire.
- Peter |
b) People in urban areas are less likely to own a vehicle due to mass transit. c) Should we just say to heck with the other 20% (more like 50%) let them walk?
I have some of each. They all have their place. I admit my situation isn't typical, but the ICE has peaked as the primary power plant for me. It went from the only "choice" to a real choice of which vehicle/fuel system to use. Choice is good.
Actually, most asteroids are rock.
The largest M type asteroid is Psyche, it is 16th in size order and it makes up 1% of the mass of the Asteroid belt.
It is about 90% metallic and weighs 22,700,000,000,000,000 Metric Tons. The metal should be about 90% iron with the rest mostly nickle. Psyche should contain 18,387,000,000,000,000 Metric Tons. 2014 world production of Iron: 3,200,000,000 At this rate, it would be 5.7 million years of world production. It is a BIT far away. At closest approach, it is about 180 Million miles away (300 Million Kilometers)
Max Sluiter
Fuel cell futures no longer a dream - SAE International "Similarly, the amount of platinum used has already been successfully reduced to nearly the benchmark level of that used in the catalytic converters for internal combustion engines. GM’s Equinox fuel cells used 80 gm (2.8 oz) of platinum and the 2011 Clarity FCV used 30 gm (1.05 oz). Catalytic converters typically use 10 gm (.35 oz), according to Pivovar." Which should go even farther with the right lattice structure: Novel nanocatalysts for fuel cells - SAE International Or you can skip the Platinum all together... Rethinking the route to lower-cost fuel cells - SAE International "Opting for the high end of the pH range has an advantage: it enables replacement of platinum catalysts with cheaper metals like nickel or silver, Yan explained. “A basic operating environment is better," he said, "because many catalytic metals are much more stable, while everything dissolves in acid, including platinum.”"
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
b) maybe (though not sure on those numbers) but that's even better for traffic c) no one is trying to pry your car out of your cold dead hands
Buy and drive what you want. |
EV's using heat or AC in stop and go traffic will be out of juice long before arrival.
Look. You want an EV? Got get yourself one. Just don't ask me to fund poor technology with my taxes.
